  • 1 Post By ms3blackmica
 Old 08-07-2013, 01:28 PM   #1
Empurfektion's Avatar
Posts: 30   (View Stats)
Empurfektion is a jewel in the roughEmpurfektion is a jewel in the roughEmpurfektion is a jewel in the roughEmpurfektion is a jewel in the rough
Groaned at 6 Times in 2 Posts
Default Boost Fluctuation under WOT
Just recently I have felt my cars boost fluctuating under WOT and was able to capture a log of what has been going on. I haven't made any changes besides resetting the ECU (battery disconnect) when changing out the battery. I'm not sure what's going on and I have done some research and it seems it could either be the EBCS which I have replaced a year ago with a Grimmspeed EBCS or my wastegate.
I have checked all the tubes running to the wastegate and the COBB TIP and they are on there snug. I have the EBCS running in 2 port mode with the 3rd port capped per Grimmspeed. Can someone shine some light on what could be going on here please.
Also, I took my car off Stage 1 tune and have it running stock and am not going WOT or really even driving it until I can get this figured out. Thanks!
Log - 4th -6th gear WOT
Empurfektion is offline   Reply With Quote
 Old 08-08-2013, 02:14 AM   #2
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Was it doing any of this before on the same map?
www.tunedbynishan.com
rfinkle2 (09-03-2013)
 Old 08-08-2013, 02:26 AM   #3
snailD's Avatar
Posts: 3,039   (View Stats)
i just started tuning a kid with a very similar thing going on. I cant visually inspect the car, but i can triple checked the map and it isn't that. this just adds to my suspicion of something mechanical. if the wastegate was faulty would it still work correctly on spring pressure? is there really a way to check it? i havent looked into that yet
 Old 08-16-2013, 02:15 PM   #4
Sorry for the delayed response. I've been getting ready for a wedding.
No, it was not doing it before on the same map. I really think it has to do something with the Grimmspeed EBCS but I can't exactly pinpoint why or how. I emailed Grimmspeed and they say to degrease it and blow it out with a air compressor. I'm not sure how that will fully help but I guess I need to give it a shot.
 Old 08-27-2013, 06:25 AM   #5
Mods, can you delete this post? I'm going to move it to Troubleshooting/Diagnostics.
 Old 08-27-2013, 06:28 AM   #6
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Yo, you know we can move shit, right? lol
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 08-27-2013, 06:40 AM   #7
In 2 port mode, I don't believe Grimmspeed instructs you to cap anything on either the solenoid or the wastegate actuator.
If you can get a high pressure source (compressor etc) to the wga, you should be able to see the wg arm move freely @ around 10 psi.
Last edited by rfinkle2; 08-27-2013 at 06:40 AM. Reason: MSF Database - Automerged Doublepost
snailD (08-27-2013)
 Old 08-27-2013, 07:12 AM   #8
Posts: 2,826   (View Stats)
The actuator arm will start moving at about 10 psi and should fully extend by 18. Max movement is only about 1/2". Be sure to use a pressure regulator and set no higher than 20 psi. If you use pressure higher than that you risk rupturing the actuator diaphragm.
The Following 2 Users Say Thank You to MSMS3 For This Useful Post:
rfinkle2 (08-27-2013), snailD (08-27-2013)
 Old 09-03-2013, 10:02 AM   #9
I'll be sure to take it to the local shop and have them test this out since I don't have the tools to do so. He's a family friend so he never minds doing some quick tasks...
Thanks
The Following User Says Thank You to Empurfektion For This Useful Post:
 Old 09-03-2013, 12:59 PM   #10
OP, there shouldn't be any caps on anything when running the Grimmspeed in 2 port mode.
That being said, it looks as if you are overboosting pretty heavily, and the solenoid is correcting it.
That is where the boost oscillations are occuring from.
 Old 09-04-2013, 03:12 PM   #11
^Agree completely. EBCS doing its job, but the true fix is in tweaking the tune.
I have my unused ports (2 port mode) capped just to keep dirt out. No effect on function.
3 Port Boost Control Solenoid / Boost Question Badinfluence MazdaSpeed 3/6 - ECU Computer Tuning 24 06-24-2013 02:59 PM
boost tuning, not hitting easy boost targets? Caldazar MazdaSpeed 3/6 - ECU Computer Tuning 11 05-18-2012 06:09 PM
Not hitting Stage 2 boost targets (boost leak?) Bubba Ho-Tep 2010 MS3 - ECU Computer Tuning 15 04-26-2012 08:25 PM
Smooth Boost or boost jump. What is causing this, I am baffled. FreeFlyFreak
Cobb ATR Support
9 10-31-2009 01:38 PM
ideally whats the best boost targets for custom tune from full boost to redline? Wenis Prinkle
Cobb ATR Support
26 08-24-2009 06:36 PM
Page generated in 0.31518 seconds with 26 queries
