 Old 07-20-2019, 07:51 PM   #1
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
prolly a boost leak somewhere between your turbo outlet and throttle body.
94 M
MS6
IS350
The Following User Says Thank You to Pu Manchu For This Useful Post:
Sensei (07-20-2019)
 Old 07-20-2019, 08:46 PM   #2
Sensei's Avatar
Posts: 318   (View Stats)
Sensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the world
It was hot as hell out today so I only messed with the car a bit this evening. I confirmed the hose from the TIP to the BCS is not clogged so that easy fix is not the issue. All the other hoses are in place and look okay but it's impossible to tell for sure without really getting in there.
Originally Posted by 180mph View Post
Ill let someone more educated chime in here but to me it seems something mechanical is going on.
Considering that your LTFTs were at -5 in log 93 before and in log 94 your LTFTs are at -15 I would start by checking all of vac hoses for tight connection.
I am somewhat of a novice compared to the great people on these forums so take my .02 with a big grain of salt.
Thanks
I'm not too worried about the LTFT. They're showing that I could use a MAF cal but not much I can do without paying for a retune and I don't think the LTFT are related to the low boost I'm seeing. If the BCS is the issue and I replace it I'll be getting retuned and the LTFT will get sorted out at that point. The plan for now will be to take the intake off and replace all the 4 mm and 6 mm vacuum lines with thick walled silicone ones. I'll also check that the BCS opens when it gets 12 volts.
I'd think a boost leak causing the loss of 7 psi would throw the AFR way out of wack and the car would have drivability issues. The car feels fine other than the missing power. I'll still give all the FMIC piping couplers and the BPV a look while I'm at it.
2009 MS3: Freektune 280/330, CS SRI+TIP, 3" Test Pipe, TR8 FMIC, AT internals, APv3, JBR SSP/CW/SB, JBR RMM 88a, JBR PMM 80, Koni FSD/Stock Springs
Sensei is offline   Reply With Quote
Low boost issue nicknguyenle 2010 MS3 - Troubleshoot/Diagnostics 4 02-05-2018 08:30 AM
Boost issue Rob84 MazdaSpeed 3 - Engine, Transmission & Driveline 2 01-01-2015 03:22 PM
Over Boost Issue, Boost leak? vincentspeed3gogh MazdaSpeed 3/6 - ECU Computer Tuning 23 12-27-2014 02:31 AM
Need Help with a possible Boost Cut issue??? EddyV1987 MazdaSpeed 3/6 - Big Turbo Builds 7 04-24-2013 04:24 PM
Boost issue sriser66 MazdaSpeed 3/6 - Turbo Induction 4 03-19-2013 10:40 PM
Page generated in 0.24017 seconds with 23 queries
