![]() Join Date: Feb 2017
Rep Power: 0 ![]() ![]() Thanks: 8
| Not Ranked : 0 score I don't think that running "lower boost" will mess with your afr. My argument here comes with how I'm self tuning my new corksport turbo. For safety I set my wgdc to 0 across the board on first startup. This forces my boost to 14-17 psi off wg spring pressure. Even though I'm "targeting" 20 psi and actually achieving 14 psi my AFRs stay around 11.2. The ECU is much better at correction than you would think. If nothing mechanical has changed from log 93 to 94/95 I would really be suspecting an air leak with intake/vac etc. Sorry I can't be of more help ![]() PS... Confirming proper operation of the BCS also seems like a good theory to the problem... I have nevy experienced a failing one so this could be useful knowledge for me in the future
__________________ MODS: Autotech HPFP (Duh) Cobb SF Intake + TIP. Cobb AP Self tuned CPE Intercooler CPE Catback CS Turbo EBay DP HKS SSQV BOV (Recirc Kit) JBR Boost Tubes 1 Step Colder NGK Plugs gapped @ .28 COBB RMM Damond PMM JBR Shift Bushings Mishimoto Shift Knob Stock BCS (Already Purchased Grimspeed EBCS) Stock Suspension (Planning on purchasing BC Coilovers) |
| The Following User Says Thank You to 180mph For This Useful Post: | Sensei (07-21-2019) |
![]() Join Date: Jun 2013 Location: N. Stonington, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 120
(Thread Starter) | Not Ranked : 0 score I was refering to Pu Manchu's suggestion that a boost leak was the cause of the problem. If the car was losing that much air after the turbo I think we'd see it in the logs. AFR would be rich since the car expects more air to be going to he engine. MAF voltage/flow + boost wouldn't match between logs 93 and 94/95 which they do match. IIRC boost is measured at the intake manifold so low boost with a realatively higher MAF value and rich AFR is what I'd expect out of a substantial boost leak.
__________________ 2009 MS3: Freektune 280/330, CS SRI+TIP, 3" Test Pipe, TR8 FMIC, AT internals, APv3, JBR SSP/CW/SB, JBR RMM 88a, JBR PMM 80, Koni FSD/Stock Springs |
| Low boost issue | nicknguyenle | 2010 MS3 - Troubleshoot/Diagnostics | 4 | 02-05-2018 08:30 AM |
| Boost issue | Rob84 | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 01-01-2015 03:22 PM |
| Over Boost Issue, Boost leak? | vincentspeed3gogh | MazdaSpeed 3/6 - ECU Computer Tuning | 23 | 12-27-2014 02:31 AM |
| Need Help with a possible Boost Cut issue??? | EddyV1987 | MazdaSpeed 3/6 - Big Turbo Builds | 7 | 04-24-2013 04:24 PM |
| Boost issue | sriser66 | MazdaSpeed 3/6 - Turbo Induction | 4 | 03-19-2013 10:40 PM |
