 Old 07-21-2019, 07:01 AM   #1
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Pu Manchu was likely suggesting a leak between turbo and TB because of fuel trims changing to -15
Escaping air in a pressure zone would normally make the engine run rich. It's clear the ECU is pulling fuel to correct the richness.
At WOT, the leak could be much much worse, which coukd lead to low boost readings.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
Sensei (07-21-2019)
 Old 07-21-2019, 04:19 PM   #2
Sensei's Avatar
Posts: 318   (View Stats)
Sensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the world
The ECU is pulling fuel at cruise however the AFR at WOT is good for all the data logs. At this point I'm pretty confident the issue is with the BCS or vacuum lines to the BCS. Other possibilities would be the PCM not sending the proper signal to the BCS (hope not $$$). Maybe a bad turbo but I think that is less likely. Once the silicone lines come in and the heat lets up I'll be getting to work on it.
2009 MS3: Freektune 280/330, CS SRI+TIP, 3" Test Pipe, TR8 FMIC, AT internals, APv3, JBR SSP/CW/SB, JBR RMM 88a, JBR PMM 80, Koni FSD/Stock Springs
Sensei is offline   Reply With Quote
Low boost issue nicknguyenle 2010 MS3 - Troubleshoot/Diagnostics 4 02-05-2018 08:30 AM
Boost issue Rob84 MazdaSpeed 3 - Engine, Transmission & Driveline 2 01-01-2015 03:22 PM
Over Boost Issue, Boost leak? vincentspeed3gogh MazdaSpeed 3/6 - ECU Computer Tuning 23 12-27-2014 02:31 AM
Need Help with a possible Boost Cut issue??? EddyV1987 MazdaSpeed 3/6 - Big Turbo Builds 7 04-24-2013 04:24 PM
Boost issue sriser66 MazdaSpeed 3/6 - Turbo Induction 4 03-19-2013 10:40 PM
Page generated in 0.23588 seconds with 23 queries
