 Old 07-25-2019, 06:20 PM   #1
Sensei's Avatar
Posts: 318   (View Stats)
Sensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the world
A mostly happy ending. I got the GS EBCS installed today and the original issue with the car is fixed. The car is able to achieve boost levels higher than spring pressure.
I do need a touch up tune though. To go along with the LTFTs being further out of spec than recommended I'm also getting some KR up to 1.75 around 3800-4500 and boost seems to be peaking higher at 20.5 psi than some older data logs. I don't do a good job of taking data logs every month or so to check up on the car so I've got no way of knowing whether or not the new EBCS contributed to the higher boost and KR. I took one log which is attached and replicated the KR 2 more times without logging. Either way a touch up tune should sort that out.
I appreciate everyone's help getting this figured out.
2009 MS3: Freektune 280/330, CS SRI+TIP, 3" Test Pipe, TR8 FMIC, AT internals, APv3, JBR SSP/CW/SB, JBR RMM 88a, JBR PMM 80, Koni FSD/Stock Springs
Sensei is offline   Reply With Quote
The Following User Says Thank You to Sensei For This Useful Post:
MSMS3 (07-26-2019)
Low boost issue nicknguyenle 2010 MS3 - Troubleshoot/Diagnostics 4 02-05-2018 08:30 AM
Boost issue Rob84 MazdaSpeed 3 - Engine, Transmission & Driveline 2 01-01-2015 03:22 PM
Over Boost Issue, Boost leak? vincentspeed3gogh MazdaSpeed 3/6 - ECU Computer Tuning 23 12-27-2014 02:31 AM
Need Help with a possible Boost Cut issue??? EddyV1987 MazdaSpeed 3/6 - Big Turbo Builds 7 04-24-2013 04:24 PM
Boost issue sriser66 MazdaSpeed 3/6 - Turbo Induction 4 03-19-2013 10:40 PM
Page generated in 0.24000 seconds with 22 queries
