![]() Join Date: Aug 2019 Location: St. Louis
Rep Power: 0 ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score ![]() Sent from my iPhone using Tapatalk |
![]() Join Date: Jan 2017 Location: Buffalo NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score it goes to the bcs. Happenes too most everyone.I took a demel and reshaped the end the broke and put the hose back on. https://cse.google.com/cse?cx=007197...oken&gsc.sort=
__________________ 2007 speed3 GT. cobb rmm, JbR pmm, Corksport adjustable shifter, twm solid shifter bushings, Sure shift knob, AP3, Autotech, CS turbo, CS occ, HTP 3.5, Depo catless dp, TS Kompact bpv, CS 3port, cpe BlockD, GA V3, DO DVC-30, Cx racing piping, tr1035.. Freektuned 2011 mazda 6 |
So one side connects to the TIP and the other with the broken piece goes to where..? Sent from my iPhone using Tapatalk Last edited by grammates; 09-15-2019 at 01:44 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() Join Date: Jun 2009
| Not Ranked : 0 score That hose goes to a nipple on the electronic boost control solenoid (ebcs). You will have three nipples on it. Two will have hoses. The third will be for that hose, if not broken off. The nipples are plastic and fragile.
So This is what I’m looking at ![]() Sent from my iPhone using Tapatalk | |
| Not Ranked : 0 score Yes, that is the EBCS. Look for the third nipple on it, replace the hose there and reinstall the clamp. If the nipple is broken off, you'll need to replace the EBCS. Consider getting an aftermarket one like what Grimmspeed sells, as their nipples are metal and will not break like the POS factory solenoid.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 09-18-2019 at 01:01 PM. |
| The Following User Says Thank You to MSMS3 For This Useful Post: | grammates (10-11-2019) |
![]() Join Date: Dec 2017 Location: Chico CA for school. Originally From the Bay Area
Rep Power: 27 ![]() Thanks: 16
| Not Ranked : 0 score I broke mine while doing my HPFP install. I was an hour and a half away from home and it was late at night. I babied it home and ordered an OEM one form mazda. In December I swiped a spare off of a speed from a local Pick n Pull.
__________________ 2009 CWP GT MS3 Damond Motorsports RMM PMM and TMM Autotech HPFP Cobb SF Intake Cobb AP Autotech HPFP Corksport RSB+FSB Corksport Adjustable Short Throw Corksport Metal Skid Plate Koni FSD |
Those OEM nipples are plastic and very fragile. Many of us went with Grimmspeed or other aftermarket versions because they have metal nipples. If you get tired of them breaking, consider a permanent solution.
Rep Power: 3746 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| The Following User Says Thank You to Vansquish For This Useful Post: | MSMS3 (01-28-2020) |
(because from what I understood it would run off of the wastegate spring pressure of 10psi?), and drove it home bellow 3k rpm. Hopefully if I do end up snapping it again it'll be so I can swap it out for an aftermarket one.
__________________ 2009 CWP GT MS3 Damond Motorsports RMM PMM and TMM Autotech HPFP Cobb SF Intake Cobb AP Autotech HPFP Corksport RSB+FSB Corksport Adjustable Short Throw Corksport Metal Skid Plate Koni FSD | |
| Not Ranked : 0 score The solenoid is probably no longer opening to vent some air to raise boost above 10psi...You will see after replacement.... Usually if you break the path from EBCS back to TIH, it won't change much because the solenoid would keep working venting in the air instead of venting back into the tih....This can possibly brings an AFR cell because of the small leak created but not much more.... On the other hand, if you break the other boost line going to wastegate, you will overboost a lot like having 100% wg duty...And you would need to cap it until repaired to safely drive the car on spring pressure... And in my memory the oem ebcs just have 2 lines/ports, not 3. The larger third boost line is from turbo boost source to wg directly. If you have 3 lines, it is an aftermarket one...
| The Following User Says Thank You to Jeff23spl For This Useful Post: | MSMS3 (01-28-2020) |
| Not Ranked : 0 score Ah ok thanks for the info. I broke nipple going to the wastegate so, sounds like it would not have been good.
| Lost boost after sure inlet hose installed please help!!! | cdyer603 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 1 | 12-28-2011 07:24 PM |
