![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
(Thread Starter) | Not Ranked : 0 score I've attached a picture of the sensor. It leaks air weather the sensor is plugged in or left unplugged. If this needs to be replaced what is the part number and what is this sensor called? No clue why it's leaking air because it wasn't leaking earlier today and now it is. Is it safe to drive my car with this leak? There's a pretty significant amount of air coming through there. Picture attached.
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score you are not supposed to fill the valve cover with pressurized air or am i missing something
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
Groans: 433
| Not Ranked : 0 score how did you manage to pressurize your crankcase?
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
| Not Ranked : 0 score **whether |
(Thread Starter) | Not Ranked : 0 score no clue why there is air in there. I hooked up the boost leak tester I made the end of my intake. I removed the filter and connected it there and pressurized the system. Ive been testing all morning and part of the afternoon repair a bunch of small hair pin holes all over my cp-e CAI around the MAF sensor. I had 2 clamps that were loose but majority were around the MAF sensor on my CAI. If the crankcase is pressurized is that bad? Maybe i've done to many tests and it's entered that part of the engine, not exactly sure. How else would it get in there?
Groans: 125
| Not Ranked : 0 score its fine, mine does that too, not from that sensor, but you have the breather on the back of the cover for that specific reason. you may want to put a new gasket on that sensor if you can get one, but i wouldnt stress about it |
(Thread Starter) | Not Ranked : 0 score what about the crankcase getting air in it, is that a problem? Like I said this never started happening until after all of my other boost leaks were fixed.
Groans: 125
| Not Ranked : 0 score yea im not sure why it happens. sometimes i get it sometimes i dont. it could be through the pcv system |
(Thread Starter) | Not Ranked : 0 score ok cool
| Not Ranked : 0 score you should plug the bpv hose
(Thread Starter) | Not Ranked : 0 score Ya I did take it off the bpv but i didn't have anything laying around to plug it. I need to find something to plug it. I want to test my bpv to make sure it's not leaking as well. I have the HKS SSQV2 which are known to leak. I'll test that another time once I have something to plug the recirc hose.
![]() Join Date: Jun 2010 Location: li, merrick, new york
Rep Power: 2273 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,757
| Not Ranked : 0 score Cap the valve cover vent line while testing. |
| Not Ranked : 0 score On the intake, the hose that goes from the intake to the valve cover. |
Groans: 433
| Not Ranked : 0 score exactly. When you put the damn cap on the end of your intake, you were pressurizing the crankcase too via the breather from the intake to the vc. Leak testers are best on the compressor inlet at least, but the best best is the beginning of the hot side piping at the compressor outlet.
| The Following User Says Thank You to Chimmike For This Useful Post: | kmac (09-10-2011) |
Groans: 239
| Not Ranked : 0 score lulz, start the car see wat happens
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
| Not Ranked : 0 score The valve cover PCV valve is designed to block air from being sucked back into the crankcase, it is not designed to block air from being blown into the crankcase from the intake because that area never sees boost. You need to block off the valve cover breather hose, it is the big hose near the CDFP that goes to the intake. If you are only leak testing the hot side and you pressureized the crankcase to the point that the oil control valve started leaking then I would say you have a bad crankcase PCV and a bad valve cover PCV.
![]() Join Date: May 2011 Location: Las Vegas NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
| Not Ranked : 0 score anyone know if there is a writeup on replacing that seal? also would like to know the part number...
__________________ 2007 MS3 Black Mica-Totaled @98500 on 09/2014 ![]() Current Car... 2009 MS3 Black Mica GT JBR TRU 3.0 Widepath full intake, BNR S3 v1, GS EBCS, 3 BAR , Forge BPV V2, Autotech internals , Denso Itv22, CNT Downpipe, CX-Racing piping with Cobb v2 core, Cobb AP v2, JBR RMM, JBR PMM, JBR TMM, JBR Oil Catch Can, EGR Delete, JBR TIG, Toyota Seals, HTP battery tray, DashHAWK Zoom Zoom |
Groans: 111
| Not Ranked : 0 score L3K9-10-2D5A
![]() Join Date: Jul 2014
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score I had the same issue with the same seal. It's nothing to worry about. Just cap off the vc when your testing for leaks. Even if you replace that seal it'll still leak. If you still want to replace it you can buy a oem replacement seal from edge. I don't know the part number off hand. Replacing the seal is pretty straightforward as well. Just take the valve cover off, pull the sensor out, then you can pop the old seal out and swap it with the new one. |
Groans: 111
| Not Ranked : 0 score Don't even bother replacing it. After a while it will stop leaking. But it takes a while before all that oil becomes like a gunky glue and seals the seal (!!).
| Boost leak? | mrQQ | MazdaSpeed 3/6 - Turbo Induction | 16 | 04-09-2011 02:09 AM |
| Vacuum leak, but no boost leak? | vbt101 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 23 | 04-18-2010 01:06 PM |
| Boost Leak(need help | phantomspeed3 | MazdaSpeed 3/6 - Turbo Induction | 30 | 05-21-2009 10:19 AM |
| Boost leak? or something else? | GOT 2RBO | MazdaSpeed 3/6 - Turbo Induction | 11 | 05-01-2009 04:27 PM |
| Boost leak or what? | TotallyNotAmused | MazdaSpeed 3/6 - Turbo Induction | 12 | 04-15-2008 05:33 AM |
