 Old 05-14-2015, 09:03 AM   #1
Posts: 2,233   (View Stats)
It isn't a stepping motor but an ordinary brush 12v dc motor with only 2 terminals for + and -. (Like a wipper motor or like the washer fluid pump etc) I was surprised too, i was wondering it need something with more features like a step or small servo-motor but it is what it is...
The TB include a 2 step gear box between the TB and motor to slow it down and all other wires are for the TPS signals molded to the plastic cover.
I assume that everything is made in the PCM. It probably include a modulating torque control to increase/decrease motor current to increase/decrease opening against the spring that close it back. More current=more torque against the spring....The TPS keep the control in closed loop to confirm position reached to fine tune the result...But i'm not sure of this last part, it is just what i think it could be according to my industrial electronic knowledge with DC motors controls and drives...
Few pictures from the web but it is exactly what we have on the speed:
inside with middle gear missing: Pay attention to the 2 lugs comming out from the motor on each side of the bottom gear...
TPS at the top and the 2 motor terminals at the bottom:
Similar motor
Not hitting Stage 2 boost targets (boost leak?) Bubba Ho-Tep 2010 MS3 - ECU Computer Tuning 15 04-26-2012 08:25 PM
12psi boost YokiMazoku MazdaSpeed 3/6 - Turbo Induction 27 03-02-2012 05:47 PM
Vacuum leak, but no boost leak? vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 04-18-2010 01:06 PM
atp bcd showing cumputer8 lbs of boost rigor MazdaSpeed 3/6 - ECU Computer Tuning 5 02-02-2010 08:58 PM
wont boost past 12psi kachow22 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 07-23-2009 05:45 PM
Page generated in 0.25166 seconds with 22 queries
