| Not Ranked : 0 score a leak at the wastegate vacuum line would increase boost. look for something not flowing thru when looking there. A BPV could easily leak enough to drop boost too without making a leaking noise while driving... interesting, mine made a bit more but it was early this summer and i had a DP on stock catback. I bypassed the ebcs vac hose to check something and was like 11-12 with peak at 14...
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... Last edited by Jeff23spl; 09-12-2018 at 10:13 AM. Reason: MSF Database - Automerged Doublepost |
| Low boost 13psi | jtimms6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 3 | 09-09-2018 11:12 AM |
| Not hitting boost targets, not boost leak | ADHDAdditiv | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 28 | 07-18-2014 02:18 PM |
| boost tuning, not hitting easy boost targets? | Caldazar | MazdaSpeed 3/6 - ECU Computer Tuning | 11 | 05-18-2012 06:09 PM |
| Not hitting Stage 2 boost targets (boost leak?) | Bubba Ho-Tep | 2010 MS3 - ECU Computer Tuning | 15 | 04-26-2012 08:25 PM |
| Not Hitting Boost? | KrishyC | Gen2 MS3 General Discussion | 8 | 03-28-2012 09:06 PM |
