![]() Join Date: Aug 2018
Rep Power: 0 ![]() Thanks: 1
![]() Join Date: Jul 2017
Rep Power: 33 ![]() ![]() Thanks: 9
| Not Ranked : 0 score Maybe you need to calibrate your MAF for the new intake?
__________________ 2010 Gen 2 Velocity Red - Freektuned ![]() - AP V3 - HPFP - Cobb RMM - Damond PMM - Turbo Back Custom SS Race Pipe - K&N Drop in Air Filter - Bov - Raiden by Lenso Forge Type Monoblock 18 x 8 ET/ 35 Wheels - Falken Azenis FK510 235/40 Tyres - Webasto Sunroof. |
| Not Ranked : 0 score Datalog? Picture of the installed intake ? These cars are maf dependant so as soon as you change the maf pipe size it need to be adjusted. it can be that or so many other things... btw for the rattle, look at thread like ''how too vvt'', it isn't just a matter of lash adjuster...
| The Following User Says Thank You to Jeff23spl For This Useful Post: | jtimms6 (09-10-2018) |
https://www.redline360.com/dc-sports...xoCNEMQAvD_BwE | |
| Not Ranked : 0 score to calibrate maf you need ATR software or a tune but according to your log, you have something else in fault for your 12-13psi...Despite it may still affect the performance a bit. (You can compare inside dimensions to make sure) I suspect something electric/mecanic with the wastegate since the log show a 40-50% wastegate duty and the boost isn't rising. The first step is a boost leak even if it may not be the major problem, you need the system sealed tight prior to do anything else.(Replace inlet filter by the boost tester and listen for leaks...) Then, check the wastegate electric solenoid, remove it and test it. Make sure when you powered it with a constant 12v, it flow freely FROM the wastegate to the TIH and stop when you remove the power. Check hose at the same time to make sure it isn't plugged by dirt or sludge etc. You can also check if the wg arm is tight and secured at rest.
| Not Ranked : 0 score Did you try putting your stock intake back on to see if boost returns to normal?
| Not Ranked : 0 score Unless the new filter is very restrictive, i would expect more than 12-13psi with 40-50% WG duty from a healthy ko4. It seem to react on is own like if the ebcs isn't doing any leak s
(Thread Starter) | Not Ranked : 0 score With the stock intake I still only had 13psi just didn’t think anything of it since I wasn’t still new to the car.. gonna check the wastegate and the lines going to it |
| Not Ranked : 0 score For reference, my K04 on spring pressure was about 10-11psi.
![]() Join Date: Apr 2016 Location: Richmond, VA
| Not Ranked : 0 score I think you have a vacuum/boost leak. Check the hose from the TIP to the EBCS, check the nipple on the EBCS, check the BPV recirc hose, check your hose from the IM to the BPV. Also, logging fuel trims is helpful for diagnosing leaks. Last edited by Solarsurge; 09-11-2018 at 02:27 PM. Reason: I'm retarded at times. |
| Not Ranked : 0 score Stock TMAP sensor?
(Thread Starter) | Not Ranked : 0 score YEs stock sensor and I’ll look over those vacuum lines as well and I can take anoth log with the fuel trims as well |
| Not Ranked : 0 score a leak at the wastegate vacuum line would increase boost. look for something not flowing thru when looking there. A BPV could easily leak enough to drop boost too without making a leaking noise while driving... interesting, mine made a bit more but it was early this summer and i had a DP on stock catback. I bypassed the ebcs vac hose to check something and was like 11-12 with peak at 14...
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... Last edited by Jeff23spl; 09-12-2018 at 10:13 AM. Reason: MSF Database - Automerged Doublepost |
| Low boost 13psi | jtimms6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 3 | 09-09-2018 11:12 AM |
| Not hitting boost targets, not boost leak | ADHDAdditiv | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 28 | 07-18-2014 02:18 PM |
| boost tuning, not hitting easy boost targets? | Caldazar | MazdaSpeed 3/6 - ECU Computer Tuning | 11 | 05-18-2012 06:09 PM |
| Not hitting Stage 2 boost targets (boost leak?) | Bubba Ho-Tep | 2010 MS3 - ECU Computer Tuning | 15 | 04-26-2012 08:25 PM |
| Not Hitting Boost? | KrishyC | Gen2 MS3 General Discussion | 8 | 03-28-2012 09:06 PM |
