![]() Join Date: Mar 2011 Location: Lenexa, Ks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
(Thread Starter) | Not Ranked : 0 score -8 AN Oil Drain Assembly for GT28/GT30/GT35 Series : atpturbo.com Im sure it would have to be cut to length, Im just trying prep for my turbo install. Maybe I'm wrong about the oil drain line on the MS6?
__________________ 06 MS6- GT2871r, TR11 intercooler, AT internals, ATP DP, JBR TMM, AWR RMM, |
![]() Join Date: Jul 2011 Location: Santa Fe, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score Don't bother atp will tell you to reuse the stock oil return line because of the transfer case on our cars only the stock will fit
__________________ [SIGPIC][/SIGPIC] 1992 miata, track beast here I come with 2 bride seats!! (current)3076r speed6 owner (traded) 2000 camaro 415rwhp thru midwest chassis fab (sold) |
![]() Join Date: Apr 2011 Location: Moreno Valley
Rep Power: 0 ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score i used the stock return pipe that bolts to the block and cut the line and used a long hose with the proper fitting to my turbo came out great! |
Groans: 239
| Not Ranked : 0 score bleh, i had to go custom, 90 degree aluminum heater hose fitting, then stock drain cut in half. connected a silicone heater hose to each end, wrapped it in fire sheath and called it a day.
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
| The Following User Says Thank You to dooderek For This Useful Post: | Zoomer_Esiason (11-14-2015) |
![]() Join Date: Nov 2011 Location: Caldwell, ID
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,042
| Not Ranked : 0 score I think there is a difference between custom and afro-engineered Chinkus lol.
__________________ Old stuff: Stock k04 12.301 @ 113.20 New Stuff: PTE 5858 and Built, not bought, by ME ![]() |
| The Following User Says Thank You to h.h.sk1nny For This Useful Post: | 06Speed6 (02-16-2012) |
Groans: 60
| Not Ranked : 0 score Cut the oem line and weld a -10 fitting on it.
![]() Join Date: Nov 2011 Location: edgewood md
Rep Power: 2429 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,644
Groans: 391
Groaned at 75 Times in 49 Posts
| Not Ranked : 0 score How about people who's oil drain lines somehow got kinked at that bend and need a replacement other than stock? I know there is someone who running -AN fitting and a braided line.....someone please shine some light on this besides saying it cant be done.
__________________ moore automitive 4/13/13 515whp 511 tq Mason Dixon Raceway 11.289 @125 1.845 60' Killah Built Powered By Purple Drank |
Groans: 239
| Not Ranked : 0 score Nub
(Thread Starter) | Not Ranked : 0 score keep in mind I have not looked at the oil drain location so Im not sure of the room available. But I was going to use this low profile fitting on the end of the -10 line. AN Swivel-Seal Hose Ends | ANplumbing.com about halfway down the page. The "low profile 90 degree fitting.
I'm still not sure if that's enough room with the transfer case there
__________________ [SIGPIC][/SIGPIC] 1992 miata, track beast here I come with 2 bride seats!! (current)3076r speed6 owner (traded) 2000 camaro 415rwhp thru midwest chassis fab (sold) | |
| The Following User Says Thank You to ColonR For This Useful Post: | p057 (03-14-2012) |
Groans: 391
| Not Ranked : 0 score hmmmmm post number 8 but im lookin at that and its still sooooo tight Best Oil Drain line solution on ATP Turbos? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Groans: 391
__________________ moore automitive 4/13/13 515whp 511 tq Mason Dixon Raceway 11.289 @125 1.845 60' Killah Built Powered By Purple Drank | |
| Not Ranked : 0 score Ha ha no your right! Hmmm well if the 90° piece can be threaded ALL THE WAY down then it might work but I know some of those pieces won't thread all the way down even if you use a bench vise and pliers and I wouldn't wanna push it to much in case it snaps
(Thread Starter) | Not Ranked : 0 score AN fittings seal with that angle seat, The threads themselves do not do the sealing with those type of fittings.
| Not Ranked : 0 score the stock drain works perfect for stock location turbos. i cant imagine even bothering with anything else. i tried a different line in there and got it to fit but it kinked and my turbo started smoking so i ripped that shit out and went back to stock immediately. no problems since.
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | Captain KR (02-28-2012), p057 (03-14-2012) |
Groans: 391
| v8 convert ![]() Join Date: Sep 2009 Location: (actually in) Tampa, FL
Rep Power: 1203 ![]() Thanks: 2,634
Groans: 220
| Not Ranked : 0 score I did the same thing MS6COP did (old old ass thread) and cut the pipe, removed accordion part of it, and joined both ends with crankcase ventilation hose, used two small T-bolt clamps and it's working great. I'll keep monitoring condition of hose since it's just plain rubber with 1 reinforcement of cloth or nylon or something, but i think it should hold up just fine. This is exactly why, the transfer case is completely in the way. it's even a pain in the ass to just bolt that bottom part of the flange...
__________________ |
| Drain plug for oil? | Wrxified | 2010 MS3 - Torque Specs & information | 35 | 04-02-2011 09:54 AM |
| How often do you drain your OCC? | Oswald | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 12-31-2010 11:54 PM |
| K04 oil feed line & oil drain line | NJSPEED3 | MazdaSpeed 3/6 - Turbo Induction | 12 | 09-14-2009 10:46 AM |
