 Old 08-25-2008, 09:15 PM   #1
Ghetto Mods's Avatar
Posts: 52   (View Stats)
Ghetto Mods is an unknown quantity at this point
Default "Built" K04 w/o Clipped Turbine?
Anybody have an opinion on this?
If I got the port/polish and the bigger compressor but without the clip?
Seems like most of the complaints with the modded unit have been stuff like not holding boost, etc... With no clip I wonder if that will go away.
Or will it just create a different set of problems?
All your boost are belong to us.
Ghetto Mods is offline   Reply With Quote
 Old 08-25-2008, 11:05 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
You will need to clip to be able to flow enough for the bigger compressor wheel, one doesn't really work right without the other.
 Old 08-26-2008, 03:00 PM   #3
NEC
subparpunk03's Avatar
Posts: 1,267   (View Stats)
The issue isn't that its not holding boost...
its that in WOT open loop operation (i.e. its not using sensor feedback to control the wastegate duty cycle) it runs the same duty cycle as it would with a non-clipped turbine, and due to the smaller surface area of the turbine, runs slightly less boost. This is pretty easily solved with a BC. The only thing that needs to change is the WGDC, this isn't a problem with the turbine clip at all, its doing exactly what it was designed to do. Its just that now something is different and the tune cannot account for it.
And although the reworked turbo on stock tune / ap reflash isn't boosting as much in open loop through most of the powerband, it IS holding closer to the boost targets when you start getting up towards redline, and its especially noticeable with the full throttle reflashes.
I don't know if anyone who has the reworked on this forum has REALLY tuned for it and posted dynos. You can bet once accesstuner comes out you'll see loads from me, until then, check the thread titled "My big little turbo" for my ap stage 1+ reflash + reworked turbo dyno.
2006 Lotus Elise: Toy car
2007 Mazdaspeed 3: *sold*
2005 Corolla XRS: *sold*
 Old 08-26-2008, 04:18 PM   #4
TiZi's Avatar
Posts: 87   (View Stats)
TiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond reputeTiZi has a reputation beyond repute
Hello fellas. I have the reworker and I have posted my dynos before and after the CPE flash. I have since dynoed the car two more times at two different locations. My numbers have not gone below 330whp and 360tq on each of those dyno runs.
My target psi on the one map is 19 while on the "track" map I have it set at 21 psi. I added a fair amount of fuel down low while slowly puling fuel away starting at around 4000rpm. I mess with the tune daily as I try to find the right combination. I also play with boost parameters as well as trying to use the grid boost map as oppose to the fixed boost setting on the standback.
Nonetheless, I am able to hit my target psi in every gear(Never logged first gear so I don't know about first). The reworked turbo most definetely flows better than the stocker. The problem lies with holding your boost target. I lose boost at around5000rpm slowly dropping to around 14-15 psi by 6500rpm. I have played with this reworker in every way and it looks like it just runs out of steam in the upper rpms.
Is it a worthwhile modification,money wise, most definately if you can tune for it(SB,APwith street tuner or other). Would I recommend it, well I would say look into a bigger turbo such as the gt28 or gt30 or like lallosh gt35 I trule enjoy my set up but I cannot say that I wish my boost would not drop like it like it does in the upper range. Hope you make the choice you are happy with.
07 Speed3 - CP-E Meth Controller..CP-E FC&Cut Flash..CP-E FMIC..CP-E Downpipe..CP-E Standback v2 tuned @20psi..CP-E Fuel Pump..CP-E HKS BOV..Cooling Mist Meth Kit..CP-E Motor mount..RPMC Inlet..DNP Manifold..PG Reworked Turbo..HKS Dual Ignition..Injen CAI..Denso Plugs..Hotchkis Sway Bars..Cobb Springs..GT Spec brace set..Prosport guages..AEM Wideband..TWM Short Shifter..BSD..VCTS delete..Perrin OCC..and NOW DOWN & OUT
TiZi is offline   Reply With Quote
 Old 08-26-2008, 05:22 PM   #5
O.K. got it, need the clip for the bigger wheel.
So what if I go port and polish only?
Waste of $$ Money better spent on other stuff?
Bigger turbo is a no go due to money. I got a wife and two kids so they come first before the car. Man's gotta take one for the team now and again.
 Old 08-26-2008, 06:19 PM   #6
Groans: 60
I wouldn't waste the money porting the stock turbo. I might be able to point you in the right direction if I knew what mods you had?
 Old 08-26-2008, 11:12 PM   #7
SS Installer -
Thanks. Mods are:
Forge BPV
Corksport FMIC (comes with CAI and Turbo inlet)
Vibrant DPBE
Corksport DP
CDFP
Soon to be added (unless somebody talks me out of it) -
PG manifold, MAP clamp and MBC, water/meth inj., and possibly a reflash (CP-E).
Turbo upgrade is a bit too spendy, but if port/polishing a K04 is basically shining up a turd, I can pass...
 Old 08-27-2008, 08:12 AM   #8
Groans: 60
Originally Posted by Ghetto Mods View Post
SS Installer -
Thanks. Mods are:
Forge BPV
Vibrant DPBE
Corksport DP
CDFP
The DNP/PG manifold is a great piece(my DNP fit perfect), but, you'd probably end up with boost/fuel cut because of it..
The CP-E flash would also be another great option, but you'd probably end up with fuel/boost cut if you didn't at least add a map clamp at the same time.
With your mods, your ready for some tuning.
I had all the bolt ons with the stock HPFP and still needed to pull 6% of fuel above 5000 rpms(even with the boost set at 17 psi)-It made a world of difference. 17 psi with no fuel pulled felt like 15 psi with the fuel pulled...
 Old 08-27-2008, 08:44 AM   #9
Awddsm97's Avatar
Posts: 37   (View Stats)
Awddsm97 is a glorious beacon of lightAwddsm97 is a glorious beacon of lightAwddsm97 is a glorious beacon of lightAwddsm97 is a glorious beacon of lightAwddsm97 is a glorious beacon of light
Clipping the turbine will not reduce the amount of boost. It will increase lag/spoolup and increase exhaust flow. Your issue here with small turbo's is the WG spring is not holding the door closed as the turbine pressure increases with exhaust flow. A boost controller is not going to change that. It might help depending on where get your boost source but ultimately it's going to force the WG flapper open.
Awddsm97 is offline   Reply With Quote
Spy Shots: BMW X6 5.0iS puts the "sport" in "sports activity coupe" Haltech Automotive News 0 07-28-2008 06:30 AM
eBay Find of the Day: Porsche 928 T -- as in "Turbine" Haltech Automotive News 3 05-14-2008 07:57 AM
Separate "Appearance" from "Wheels/Tires" KaiserSoze Website Help/Feedback 1 04-21-2008 08:33 PM
Pics Aplenty: MANSORY McLaren SLR "Renovatio" and Ferrari 599 GTB "Stallone" Haltech Automotive News 0 04-08-2008 04:20 PM
Volkswagen drops "Passat" sticks with "CC" for new sedan Haltech Automotive News 1 04-03-2008 04:29 PM
Page generated in 0.29779 seconds with 24 queries
