![]() Join Date: Jun 2014
Rep Power: 0 ![]() ![]() Thanks: 4
| Approved MSF Vendor ![]() Join Date: Mar 2014
Rep Power: 2489 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,022
If you cap or block the hose coming off the wastegate actuator to the ebcs it will give you wastegate spring pressure. This is as long as the bottom port on the actuator is still routed directly to the turbo
__________________ Custom Tuning for Mazdaspeed, Ford, and Subaru ![]() Website- http://www.freektune.com/ PTE 6062 633HP/523TQ First gen2 in 10's- 10.93@137 Atco NJ 11/14/15 ![]() Quickest/Fastest Mazdaspeed First Gen 1 in the 9's 9.94@149.5 4/22/2017 New England Dragway | |
| The Following 3 Users Say Thank You to Justin@Freektune For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Ok, so basically opposite of what I was going to do. This is why I need this forum... Thanks. So, just to double check... I capped the line coming from the wastgate actuator that goes into the boost control solenoid. I also capped the line coming from the intake so I wouldnt have unmetered air. I left everything else as is. That should be ok to run for a few days? Thanks again. |
![]() Join Date: Sep 2011 Location: Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
| Not Ranked : 0 score How are people still breaking these things? Will post for future reference...use a hook (see below, bottom one) and slide it under the hose on the nipple, wiggle it around the outside to break the seal then pull on the hook and hose at the same time to pull the vacuum line off. Makes removing it VERY easy and you won't break shit.
__________________ - 2010 Mazdaspeed 3 Black Mica - - Cobb AP - Self Tuned - cpe HPFP - cpe DP - CS 3" SRI - cpe TMIC - Forge BPV v2 - Grimmspeed EBCS - Denso ITV22 - - SouthBend Stage 3 Daily Clutch - cpe RMM - CS TMM Insert - TWM SB - CS SSP & SW - CS RSB & Mid Chassis Brace - - CS Brake Pads - Michelin Pilot Super Sport - CS Boost Tubes - CS Fog, DRL and Interior LEDs - Horns - Grounds - 20% Tint - |
Yup exactly.
| Anyone using the stock boost control solenoid with an MBC? | madvillain | MazdaSpeed 3/6 - Turbo Induction | 0 | 07-28-2010 08:26 PM |
