  • 1 Post By
 Old 10-11-2018, 06:35 AM   #1
Posts: 2,233   (View Stats)
Bright, the boost season, no cat and no hpfp isn't a good idea.
the first one is a pita to remove but you may just disconnect the flange where the second cat usually connect to inspect the primary with a test light....
btw, rotten eggs smell isn't a perfect proof of a plugged cat, some brand new may smell just because of fuel or a car that remain granny driven and then pushed a bit more...
It could be that, blocking in or out of the engine will prevent the turbo from making good boost...i dont keep cat long enough to test but my sister burned is honda with a plugged one, the valves overlap phase of the engine made it eat some part of the cat internal...
arnold600 (10-11-2018)
Impossible to get my boost target Mini Franki 2010 MS3 - Fuel, Nitrous & Water Injection 33 08-08-2018 04:11 PM
Car not reaching target boost Pacmonk Mazdaspeed3/6 General Discussion 19 10-16-2015 12:22 PM
Not hitting my target boost TheProYodler 2010 MS3 - ECU Computer Tuning 26 08-11-2014 09:02 PM
Not hitting target Boost. PLZ HELP mgramata MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 04-22-2014 09:01 PM
Can not reach target boost MS3SHAY MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 03-02-2014 06:15 PM
Page generated in 0.23703 seconds with 22 queries
