![]() Join Date: Feb 2009
Rep Power: 141 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
![]() Join Date: Sep 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 145
| Not Ranked : 0 score Yeah, you are getting fuel cut. You need a fuel pump upgrade, and it helps to get new plugs too. PM me for a package deal and Ill hook it up for a great price. Jeff at PG
__________________ All wagon, No traction |
(Thread Starter) | Not Ranked : 0 score the cars brand new and all i have it cobb sri |
| Not Ranked : 0 score Stock cars can get fuel cut. Its a faulty pump design that isnt up to snuff. Some get it with no mods, some dont even get it fully bolted. Its a safety "feature" that closes the Throttleplate which is the jerkyness that you feel to save the motor from death by knock. (super lean condition) 1 step colder plugs also help smooth out the powerband and keep knock down.
| Banned ![]() Join Date: Feb 2009 Location: Inland Empire
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 937
Groans: 701
Groaned at 655 Times in 620 Posts
| Not Ranked : 0 score was this after the ecu reset? because it will take a couple miles and a few WOT runs to get the fuel trims adjusted. does it happen every time? how many miles since you reset the ecu?? you definitely do not need an upgraded fuel pump with just a cobb sri, dont waste your $$ on plugs too. |
(Thread Starter) | Not Ranked : 0 score i put it on yesterday so its only got about 75 miles on it should i resest and try again |
Groans: 701
And yes, if he is cutting and this is causing knock retard, colder plugs will help too But hell, since he doesn't have a dash hawk to datalog, we dont know. Speaking of that, its an excellent data monitoring device that can datalog so we can diagnose problems on here and I would gladly provide one of those too at a great price -Jeff at PG ETA: LONG TERM FUEL TRIMS are not influenced by wide open throttle runs since the PCM switches to open loop calculations. You should let the PCM learn fuel trims for 50-100 miles at low boost/ part throttle only so that it can reference these values in open loop.
__________________ All wagon, No traction Last edited by wassup61; 02-26-2009 at 11:25 PM. Reason: Misinformation in the quoted post. | |
![]() Join Date: May 2008 Location: NOVA
Groaned at 47 Times in 40 Posts
| Not Ranked : 0 score if your getting fuel/boost cut, i don't ever recall it being jerky, i equate it to more a of karate kick its very very very violent, i'm sure others can atest to that i know Darksun can as well. He coined the phrase to me as the karate kick.
__________________ a built motor is not a built motor without being sleeved |
| Not Ranked : 0 score boost cut is VERY jerky like the car hit a wall (fuel cut induced by overboost) fuel cut is light jerks, stuttering, or power loss during a pull (induced by insufficient fuel pressure to support commanded AFR at a given RPM, so the throttle plate closes as the fuel pressure decreases.) This is more noticeable in higher load gears because more stress is being put on the fuel system in 4-5-6 than in 1-2-3. -Jeff at PG
(Thread Starter) | Not Ranked : 0 score ok so tonight i noticed that this stutter doesnt happen all the time and when it does you can kinda hear a difference in the sound of the turbo is there a chance that this is all being caused by a leaky bpv when its under a full load |
| Not Ranked : 0 score Do you have a way of documenting this stutter? Post a datalog.
![]() Join Date: May 2008 Location: Lehigh Valley, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 376
| Not Ranked : 0 score what RPM are you going WOT in these gears? |
(Thread Starter) | Not Ranked : 0 score I mainly only see it in sixth at about 4 4500 on the interst when I go to pass |
(Thread Starter) | Not Ranked : 0 score i checked again this morning and it is actually about 3200 to 3500 when im in sixth |
| Not Ranked : 0 score KR or fuel cut, definately. Pick up a Dash Hawk to datalog this cut. Shoot me an email msfprotegegarage@gmail.com and I can work a great deal for you. -Jeff at PG
(Thread Starter) | Not Ranked : 0 score Ok ill pm u for a price |
(Thread Starter) | Not Ranked : 0 score What plugs do u guys recommend |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,642
Groans: 78
Groaned at 48 Times in 31 Posts
| Not Ranked : 0 score Could be boost cut. You should probably check that out first before you buy a fuel pump.
__________________ In reality I love lenny |
-Jeff at PG
__________________ All wagon, No traction | |
(Thread Starter) | Not Ranked : 0 score ok guys Dashhawk is on the way so hopefully i can fix this problem |
(Thread Starter) | Not Ranked : 0 score OK so i got the dashhawk last night what do i need to log when i do this run |
| Not Ranked : 0 score Log boost, KR, DI fuel pressure, RPM and spark advance |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score ok would it be best to log it in fith and sixth since thats where i can feel the stutter |
![]() | | #25 | ![]() |
| Not Ranked : 0 score I think you'll have enough time to log the whole run... start the log and go WOT through the gears including 5/6 |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score So tonight on the interstate I noticed that in sixth gear at wot I noticed that boost will spike fro around 15 to 19 or 20 and then back to 15 and them back up over and over till I let off. What could be the cause. Fuel press is fine |
![]() | | #27 | ![]() |
| Not Ranked : 0 score I can understand one spike when you first floor it but it shouldn't be going back up repeatedly like that. Do you have a catless DP? Sounds like your car is having problems controlling boost. |
![]() | | #28 | ![]() |
Groans: 78
| Not Ranked : 0 score Post the log.
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score the first run is from second throuhg sixth the second is only in sixth..slowing down and going wot over a few times. sumin is messed up so purple is acctually boost Untitled.bmp 2.bmp |
![]() | | #30 | ![]() |
| Not Ranked : 0 score I am seeing alot of Knock retard towards the top of every loaded gear. Check your inlet hose clamps/ other clamps, 4.9 degrees of knock retard at WOT is A)bad juju B)can be felt Since your car is fairly new and lightly modded, I dont blame your stock plugs. Upgraded 1 step colder Denso ITV22s can help, we stock them, but you don't need them right now. -Jeff at PG
![]() | | #31 | ![]() |
![]() Join Date: Dec 2008 Location: Philly, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
Groaned at 5 Times in 1 Post
| Not Ranked : 0 score What are your LTFT showing? And are your STFT stable? |
| Whats the problem? (Car jerky while in boost) | MattJackson86 | MazdaSpeed 3 - Engine, Transmission & Driveline | 14 | 12-24-2008 11:20 AM |
| Ford's Mulally: Congress feels 'a big sense of urgency' | Haltech | Automotive News | 0 | 11-07-2008 03:10 PM |
| German auto industry also feels the global pain | Haltech | Automotive News | 0 | 10-28-2008 10:10 AM |
| Shifter feels like I'm stirring a pot of chunky PB... | Mifunego | MazdaSpeed 3 - Engine, Transmission & Driveline | 1 | 09-17-2008 09:02 PM |
| Google feels charitable | Haltech | Computers & Technology News | 0 | 04-10-2008 04:41 AM |
