![]() Join Date: Dec 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
(Thread Starter) | Not Ranked : 0 score Hey guys! I'm looking for some answers here. Right now I have Cp-e downpipe and running catless. I've never driving the car with the catless downpipe in the summer so I don't know much about this. Is it normal to have a lot of smoke while in wot? I'm talking about the end of the exhaust, Because I see the smoke from the mirrors, and the smell is horrible I'ts about 32F here in Sweden so..
__________________ Mazdaspeed 6 2006 Sp63 Longblock with Mahle and manly, ported head, keyed crank and cams, stiffer springs, GTX2867R IWG, Freaks intake 4 inch,Autotech Internals, Stratified Ebc + GA, CP-E injector seals, CS Custom pipes FMIC, Snow performance stage2 100% meth, Cp-E decatted downpipe, Custom Catback with VareX mufflers, EGR Delete, SURE TMM+PMM+RMM, South Bend Clutch Stage3 Daily, CS rear diff mount, TurbineTech Front diff mount, CS rear swaybar, Racingbeat rear Endlinks, Matt Damond PS cooler, JBR OCC Stage 2, Bosch 3 bar MAP w/ PNP Harness, BC coilovers, Tenzo R Type M 19" 235/35, Sure Shortshift, Xcarlink, Speed performance Aux fan control, Synchronic DV BOV, DBA front rotor, Ebc yellow stuff(FR), EBC greenstuff (R), Stoptech brakelines and Finally, Tuned By Lex @ Stratified Current INFO : tuning is paused due the winter. Waiting to be installed: Cp-e exhaust manifold stock flange with MVR 44 external wastegate and dump tube. |
![]() Join Date: Sep 2012 Location: Elizabeth, NJ
Rep Power: 3180 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,265
Groans: 665
| Not Ranked : 0 score What color is the smoke? |
(Thread Starter) | Not Ranked : 0 score White. I had blue smoke the other day due to the catch can was full of sludge and I think the hole system was cloged , and now it's white. After the cleaning
Groans: 793
| Not Ranked : 0 score No. Black smoke is normal. Not white.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score Have you checked your coolant levels? White smoke generally means water.... |
(Thread Starter) | Not Ranked : 0 score I'll check that tomorrow then, it could also be the meth that is mixed with water?
![]() Join Date: Jun 2009
| Not Ranked : 0 score Getting on it hard with catless exhaust should produce black smoke, like a diesel. Your AFR should be going rich under heavy load. Can you post logs made during WOT conditions? Is your engine oil the proper color or milky? Is your coolant at normal level or does it have any oil in it? White smoke at startup in cold weather is just normal condensation. If on a warm engine it suggests a blown head gasket or a crack in a water jacket in the cylinder head or block. Has it ever been run hot or low on coolant?
(Thread Starter) | Not Ranked : 0 score Milky is my OCC, the engine oil is very normal, no strange smell. Pure engine oil. I will post a log this coming days, will need to send a log either way to my tuner I also changed my pcv Valve, seemed to helped a little. My OCC setup is pcv to catch can, intake side plugged. Valve cover to catch can. And catch can to TIP for vacuum
| Catless DP question | deekspeed | 2010 MS3 - Engine, Transmission & Driveline | 30 | 06-04-2013 08:43 PM |
| FMIC and Catless Exhaust Question | johnspeed3 | Gen2 MS3 General Discussion | 12 | 05-03-2013 06:53 AM |
| Quick question abt CNT Catless DP | xtasy | MazdaSpeed 3 - Engine, Transmission & Driveline | 11 | 01-22-2012 04:02 PM |
