| Not Ranked : 0 score You IM is separated in 2 set of runner and it move on and off with a vaccuum actuator. It could be a bad solenoid, a vac live, a tear in the actuator diaphragm or just rust/dirt in the moving parts... You car get more load in higher gears and get more time to build boost than in lower gears...
| P2009 Code | IzzysAuto | 2010 MS3 - Troubleshoot/Diagnostics | 5 | 11-13-2016 05:05 PM |
| CEL P2009 no idea what it is | Highestrich4 | MazdaSpeed 6 - Engine, Transmission & Driveline | 7 | 06-12-2016 09:46 PM |
| P2004 P2009 codes | angiehbrown | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 4 | 01-31-2016 08:27 PM |
| DTC P2004, P2009 | f-castrillo | 2010 MS3 - Troubleshoot/Diagnostics | 24 | 07-14-2015 07:27 PM |
| P2004 P2009 codes | Sphinx1983 | Mazdaspeed3/6 General Discussion | 1 | 05-20-2015 08:44 AM |
