  • 1 Post By mrjoshyman
  • 1 Post By mktx01
 Old 11-24-2015, 06:59 AM   #1
mrjoshyman's Avatar
Posts: 238   (View Stats)
mrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to behold
Default Cobb BPV Maintenance
I was just reviewing the instructions for the cobb BPV http://www.licmotorsports.com/sites/...BPVinstall.pdf and they mention you should remove the entire BPV at every oil change, remove the piston and potential regrease if it isn't moving smoothly. seems kinda like a PITA to me. I've had my BPV on for probably at least 5 or 6 oil changes and have not done that.
for those of you who have the cobb bpv have you been doing this maintenance and if so have you found it necessary to re-lubricate the piston?
mrjoshyman is offline   Reply With Quote
 Old 11-24-2015, 07:01 AM   #2
robbspeed's Avatar
Posts: 1,074   (View Stats)
robbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the world
Groans: 50
People go 30,000 miles without an oil change and their car still works. Doesn't mean it's ok to do. Follow the maintenance preocedure.
2011 Mazdaspeed3 w/ tech package
Totaled/ R.I.P.
robbspeed is offline   Reply With Quote
 Old 11-24-2015, 07:05 AM   #3
mrjoshyman's Avatar
the reason I'm asking is that seems a bit like overkill...i mean to my knowledge nothing similar has to be done to the stock BPV
 Old 11-24-2015, 07:27 AM   #4
robbspeed's Avatar
Groans: 50
We're not talking about the stock bpv. I had a forge bpv from the previous owner that called for the same thing. So I put the stock one back on because I didn't feel like lubing it up every oil change. So I'm gunna suggest that you put the stock one back on if you dont want to follow cobbs maintenence procedure.
Do you want that piston to seize one day cause you didn't follow the maintenence schedule? That would be terrible for your turbo.
Totaled/ R.I.P.
 Old 11-24-2015, 02:40 PM   #5
mrjoshyman's Avatar
thanks for your input. I'm well aware of the hypothetical risk. I posted because I am looking to hear from folks who actually have the cobb BPV if they've found it needing frequent lubrication
 Old 11-24-2015, 03:28 PM   #6
[R]usty's Avatar
Posts: 2,204   (View Stats)
I own the Cobb BPV so I can speak to this. Yes clean it and do it often. Mine starts to flutter a bit every time I'm getting close to my oil change interval. I vent 50/50 so it does get dirtier more quickly. I can remove, disassemble, clean, lubricate, reassemble and install in about 10 minutes. Do it while you're waiting for your oil to drain. I also suggest you stick to the lubricate Cobb recommends. I've used about 5 different lubricates but the APR stuff works the best. Hope this helps.
2010 Mazdaspeed3 w/tech
The Following 2 Users Say Thank You to [R]usty For This Useful Post:
macdiesel (11-24-2015), robbspeed (11-24-2015)
 Old 11-24-2015, 03:38 PM   #7
mrjoshyman's Avatar
thanks for the reply! how much of this stuff do you need? seems like the cheapest option is only about 1.5oz: Arp Ultra Torque 100 9909 Assembly Lube 50ml 1 69oz Fastener Assembly Lubricant | eBay
nickspeed3 likes this.
 Old 11-24-2015, 04:14 PM   #8
mktx01's Avatar
Posts: 185   (View Stats)
mktx01 is infamous around these partsmktx01 is infamous around these partsmktx01 is infamous around these parts
Amazon.com: ARP 100-9910 Ultra Torque Assembly Lubricant - 10 oz. Brush Top Container: AutomotiveAmazon.com: ARP 100-9910 Ultra Torque Assembly Lubricant - 10 oz. Brush Top Container: Automotive
mktx01 is offline   Reply With Quote
 Old 04-25-2016, 02:51 PM   #9
nickspeed3's Avatar
Posts: 2   (View Stats)
nickspeed3 is an unknown quantity at this point
Default Lubricant
Forgive me for asking but didn't Cobb have their own lubricant designed specifically for their BPV? I bought mine two years ago and should have dropped the extra couple of $$ and picked up a bottle. Anyone else know what I'm talking about? I couldn't find it on their website anymore sadly... if not i'll just buy the ARP and say F it because I know that stuff works very well and have seen it used on other BPV.
nickspeed3 is offline   Reply With Quote
 Old 04-25-2016, 03:31 PM   #10
frothy's Avatar
Posts: 1,067   (View Stats)
@nickspeed3;
COBB specifically recommends the ARP lube in their BPV maintenance instructions, so it's doubtful they ever had anything developed of their own.
In newer iterations of their instructions, they've since tacked on Super Lube as another recommendation:
macdiesel (04-25-2016)
Best Maintenance, maintenance/mod you have done? Beans Mazdaspeed3/6 General Discussion 17 01-23-2014 05:44 PM
60k maintenance? cocoleveo7686 MazdaSpeed 6 - Engine, Transmission & Driveline 6 04-22-2013 05:14 PM
40k maintenance SpdFreak MazdaSpeed 6 - Engine, Transmission & Driveline 7 12-26-2011 12:22 AM
DIY - Maintenance help rrussell50 MazdaSpeed 6 - How-To's 7 05-07-2011 10:27 AM
08 MS3 Maintenance bbonkboy MazdaSpeed 3 - Engine, Transmission & Driveline 12 12-04-2009 02:10 AM
Page generated in 0.34595 seconds with 25 queries
