![]() Join Date: Dec 2009 Location: Grand Rapids, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 104
(Thread Starter) | Not Ranked : 0 score Long story short Cobb is out of stock as well as the 20 or so shops I called over the last couple of days. They will be out for 12 weeks or so. I pretty much have my heart set on Cobb so I am wondering if anyone has ordered the v2 piping kit and used a different core. I looked on Spearco's site and it looks like 5-312 is an exact match. Can anyone confirm this? I called Cobb and they are looking into it but I just thought I would try here to see if anyone had any input or other options. If Cobb doesn't work out I am probably going to get the Turbo XS kit. Those of you running the Turbo XS can you run it with MSCAI? Thanks |
![]() Join Date: May 2009 Location: Duarte, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 472
| Not Ranked : 0 score not sure but i think cobb uses spearco cores... thats why they remove about 400 bucks when you just get the piping kit...which is how much a spearco core would cost. it is also the same exact dimensions with the same style endtanks and mounting points.
__________________ -John ![]() | Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns | Last edited by JohnMS3; 10-24-2011 at 04:46 PM. |
| The Following User Says Thank You to JohnMS3 For This Useful Post: | NoLeftTurn (10-24-2011) |
(Thread Starter) | Not Ranked : 0 score Update: Ordered core from Treadstone. I went with the tr8l which had almost the exact same core size and very similar if not exactly the same endtakes. I will post once installed to see if it was a "true" replacement. |
| Not Ranked : 0 score treadstone is an awesome choice...good quality and decently priced. i believe the only difference between the cobb and treadstone is that the tr8 core is 2" shorter than cobb.
__________________ -John ![]() | Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns | |
| The Following User Says Thank You to JohnMS3 For This Useful Post: | NoLeftTurn (10-26-2011) |
![]() Join Date: Feb 2009 Location: Salt Lake City, Utah
Rep Power: 427 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 626
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Any updates? Does the cobb pipe kit come with mounting hardware for the core or is that up to you?
__________________ 417whp 428tq 12.037@117.2mph |
(Thread Starter) | Not Ranked : 0 score The Cobb V2 Piping kit comes with every thing you need. The TR8L cores end tanks only has one tapped hole wiith a for a single larger screw. The only thing I had to do is slightly drill out the top hole on the intercooler bracket so a larger bolt could be used. I had some bolts in the old coffee can collection that woked so I am not sure what thread the were. I'm sure you could get it from Treadstone though. I wouldn't hesitate to do it again. Worked great. |
| The Following User Says Thank You to NoLeftTurn For This Useful Post: | JohnMS3 (11-14-2011) |
| Master of Hard Parts ![]() Join Date: Sep 2011
Rep Power: 734 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 79
Groaned at 8 Times in 2 Posts
| Not Ranked : 0 score The Spearco core will work for you although there are changes to the core itself between that one and the one that we have offered in the past from COBB. The kit is on back order do to supplier issues with the core. I've been doing everything I can to get a new core in the works that will match or exceed the performance of the previous one. We apologize for the back order and would be happy to answer any questions anyone has if they are thinking they would like to order a v2 piping kit. Thanks, Evan@COBB
__________________ Hard Parts Engineer - Mazda Expert Group 2009 MS3 Sport - Built Motor//Twinscroll 35R//Everything Else - SOLD! 2008 Toyota Tacoma TRD Sport 4x4 - Current Daily Until Next Turbo Car |
