![]() Join Date: Nov 2009 Location: Lagrange,IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 85
(Thread Starter) | Not Ranked : 0 score so today i saw that the black mount that holds the intake in place broke off so the intake is really just held in by the inlet tube has anyone ever had this problem with this intake and is there anything i can do to fix it? l looked on here but couldn't find anything about it
__________________ 08.5 true red gt, 35/20% tint, resonators deleted, Tenzo R type M's,Cobb SRI, Hypertech tuned, MSD Dashhawk, SU test pipe, AWR RMM, BC coilovers, Turbosmart duel port bov [SIGPIC][/SIGPIC] |
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
| Not Ranked : 0 score that old chesnut. need both cobb sri and tip to run the sri mount. our engine moves a bit on stock engine mounts.
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
![]() Join Date: Nov 2010 Location: Fort Worth, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 227
Groaned at 74 Times in 30 Posts
| Not Ranked : 0 score I asked this question in the gen2 intake sticky. I was curious if I could install it without the mount because I've heard others say it could break due to engine movement. Maybe you can buy just that piece from cobb |
(Thread Starter) | Not Ranked : 0 score thanks for the responses
![]() Join Date: Feb 2011 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
Groans: 46
| Not Ranked : 0 score I am running mine with a custom tip and it is loose. I don't notice and problems. Is there any long term effect or performance impact? Sent from my HTC EVO 4G.
__________________ Current Build: Liquid Silver Metallic Pu - JBR Shifter Bushings, Cobb AP, JBR Chome Molly JBR SSP, ProSport Premium Boost Gauge, 25% e85 Tune PTP HPFP Internals, CorkSport Intake/TIP, Cobb Sport Springs Sold: 2008.5 Black Mica GenWon - Fully Bolted |
Groans: 74
| Not Ranked : 0 score ^^^ i wouldn't install the cobb sri mount with a stock tip (connected to engine) and stock engine mounts. that being said, your safe as kittens since you upgraded both.
![]() Join Date: May 2008 Location: New orleans, la
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 294
| Not Ranked : 0 score This has been going on since day one. I would personally sell that pos cobb sri and get something better. There is no reason why you should have to run without the mount or buy the tip which is most likely bullshit also. Really, cobb refuses to do anything about this and several other hard part issues they've had. Ive ran a cobb sri without the mount for I dont even know how many miles, and between cracked housings and bent air fins ive had several replacment sris from cobb. The mount will always break but did not cause any other issues. |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3771 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
| Not Ranked : 0 score they did adjust the sri after its initial release... rubber spacers now separate the actual intake from the bracket, allowing some movement i just took the sri bolts off and used some zipties to allow some movement but keep it relatively stationary |
| Drag strip = broken motor mount | LuczOr | MazdaSpeed 3 - Engine, Transmission & Driveline | 29 | 07-17-2011 07:26 PM |
| Signs of Broken Tranny Mount? | Alpha | MazdaSpeed 6 - Engine, Transmission & Driveline | 14 | 03-18-2010 02:27 PM |
| Broken Motor Mount? | Jujiro_Prodigy_31 | MazdaSpeed 3 - Engine, Transmission & Driveline | 17 | 03-08-2010 09:14 PM |
| Broken passenger mount...it took a dump literally..... | Betelgeuse | MazdaSpeed 3 - Engine, Transmission & Driveline | 31 | 10-24-2008 06:33 PM |
