 Old 04-15-2016, 05:07 AM   #1
Emp_ms6's Avatar
Posts: 3   (View Stats)
Emp_ms6 has a little shameless behaviour in the past
Default Cobb TIP fiitment with BNR stage 3
Can anyone tell me if the Cobb TIP is a direct fit with the BNR stage 3 turbo? Looks like the outlet on the turbo is the same size as the TIP
Emp_ms6 is offline   Reply With Quote
 Old 04-15-2016, 05:20 AM   #2
Snowing's Avatar
Posts: 78   (View Stats)
Snowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud ofSnowing has much to be proud of
Groaned at 3 Times in 1 Post
If you're running an s3, why not just get a 3 inch intake?
2012 Mazdaspeed 3
CS SRI + TIP - CS TMIC - CS Catted DP - Autotech HPFP Internals - Denso ITV22
Purple Drank Tune in process
Snowing is offline   Reply With Quote
 Old 04-15-2016, 07:25 AM   #3
Emp_ms6's Avatar
I already had the Cobb tip and the Cobb sri
 Old 04-15-2016, 07:54 AM   #4
If the compressor inlet is the same size as the TIP, then yes it is.
 Old 04-15-2016, 07:54 AM   #5
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
It will fit, yes. Might take a little muscle to do so.
But upgrading to a full 3" intake would be the best idea.
 Old 04-15-2016, 09:26 AM   #6
Snowing's Avatar
IIRC you need a larger than stock intake for that turbo.
Edit: or maybe I'm wrong.
2012 Mazdaspeed 3
First dyno pulls on Stage 1 and Stage 2 Cobb Maps PSmurf78 2010 MS3 - ECU Computer Tuning 11 05-14-2013 05:44 PM
Cobb Stage O Ayaritz MazdaSpeed 3/6 - ECU Computer Tuning 12 09-07-2012 11:49 AM
Stage 2 91 k&n Cobb OTS map. WillyH 2010 MS3 - ECU Computer Tuning 4 02-19-2012 03:38 PM
K&N SRI+COBB HIT+FORGE BOV+COBB AP stage 1 maxmator 2010 MS3 - Turbo Induction 7 08-22-2011 10:10 PM
Cobb AP Stage 1+Cobb SRI - HP/TQ Increase? Hokie D MazdaSpeed 3/6 - ECU Computer Tuning 13 06-13-2011 11:46 AM
Page generated in 0.26876 seconds with 23 queries
