 Old 01-26-2011, 12:16 PM   #1
deuce_WI's Avatar
Posts: 234   (View Stats)
deuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond repute
Groaned at 6 Times in 2 Posts
Default Corksport Air Straightener - Falling out into air filter
Anyone ever have a their air straightener fall out of the MAF housing and start flopping around in the air filter?
Any suggestions for keeping it stuck in place without risking sucking something through the turbo? No glues or tape that might come off over time.
I thought my car had been acting stupid because of the winter cold, but discovering this during an oil change last night could very well be why the car has been running poorly. But now how to keep it fixed?
deuce_WI is offline   Reply With Quote
The Following User Says Thank You to deuce_WI For This Useful Post:
rfinkle2 (01-26-2011)
 Old 01-26-2011, 12:23 PM   #2
oodavo's Avatar
Posts: 46   (View Stats)
oodavo is a glorious beacon of lightoodavo is a glorious beacon of lightoodavo is a glorious beacon of lightoodavo is a glorious beacon of lightoodavo is a glorious beacon of light
im sure a small drop of crazy glue would be harmless
oodavo is offline   Reply With Quote
The Following User Says Thank You to oodavo For This Useful Post:
ridenfish39 (01-26-2011)
 Old 01-26-2011, 12:26 PM   #3
5.000000yeah
ridenfish39's Avatar
Posts: 1,269   (View Stats)
ridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the world
Groans: 44
Groaned at 30 Times in 18 Posts
That's what I did with mine. My car was stumbling and cutting at low load until I figured out that it fell out. Interesting that I didn't get a cel though.........
Fwiw, that is the only problem I have had and I've been running that intake for 15,000 miles now.
2012 MUSTANG 5.0 // BBK X_PIPE//FLOWMASTER HUSHPOWER //3.73 REAR//SVE DRIFTS//JLT OIL SEPARATOR//BMR LCAS//J+M PANHARD BAR//STEEDA PANHARD BRACE//AIR RAID//BAMA//CAT DELETES// LOUD AS HELL
ridenfish39 is offline   Reply With Quote
 Old 01-26-2011, 12:27 PM   #4
mdl3v8's Avatar
Posts: 410   (View Stats)
mdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the worldmdl3v8 is the leader of the world
My car was running weird and had a misfire/CEL I assume due to the air straightener flopping around the air filter.
I emailed CS, they said to use silicone...
3" JBR TIP + 3.5" Treadstone MAF Housing | GTX2867R | CP-E catted DP | COBB CBE | Autotech Internals | CXRacing Piping + TR8 | DevilsOwn Meth Kit | Forge BPV | JBR Shifter Bushings | DM RMM | JBR PMM | JBR RSB | Moog Front/Rear Endlinks | Koni Yellows
mdl3v8 is offline   Reply With Quote
 Old 01-26-2011, 12:27 PM   #5
wankular's Avatar
Posts: 4,343   (View Stats)
Can you return it under warranty?
2009 MS3 sport MGM
 Old 01-26-2011, 12:30 PM   #6
This is exactly why i reinstalled my stock air box and put in a k&n drop-in. I can't have things flying / flopping etc. around in my intake.
i also don't want to have to "repair" my own with super-glue or silicone. (not that it won't work, simply out of principal)
 Old 01-26-2011, 12:54 PM   #7
deuce_WI's Avatar
Thanks for the replies.
Not sure what I'll do yet, but I appreciate the input. I guess I'll think about it a bit. I'm thinking silicone, maybe just a thin film around the MAF straightener and stuff it back in the housing.
I guess I'm somewhat glad I'm not the only one this has happened to, it just seems like something stupid to be overlooked in the design.
Oh, and I have no idea how long it's been like this, I just noticed it due to it being oil change time, and I generally poke around to make sure everything else looks alright, which this time it wasn't.
 Old 01-26-2011, 12:56 PM   #8
asall667's Avatar
Posts: 1,017   (View Stats)
asall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the world
Groans: 56
Groaned at 37 Times in 18 Posts
hey u can sell it and buy a COBB if u wanted to
asall667 is offline   Reply With Quote
The Following User Says Thank You to asall667 For This Useful Post:
 Old 01-26-2011, 12:58 PM   #9
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
wait, wait, wait... you're saying your air straightener came out of the MAF housing of your CS intake? and the "fix" was for you to glue it in place with silicone?
before i comment, i need to make sure i am understanding correctly.
it's fun to do bad things
The Following User Says Thank You to jack_hammer For This Useful Post:
 Old 01-26-2011, 01:19 PM   #10
mdl3v8's Avatar
I took it out and haven't had any issues, although I understand the air straightener messes with fuel trims? I plan on putting it back on with some silicone when it warms up.
And I can't imagine the hp gains or losses would even be worth mentioning...
Email from CS:
---------- Forwarded message ----------
Date: Monday, November 15, 2010
Subject: SRI Air Straightener
To: me at gmail.com
Hello <mdl3v8>,
We received your inquiry referenced below.
Are you using a dab of silicone when you install it?——Also unless you are getting a check engine light I would not use it.——In the 07-09 speeds you loose a bit of HP using it.——It is only provided because a lot of people were saying they need it.——
Please contact me if you have any questions, comments, or concerns.
Thank you,
<Person at Corksport>
CorkSport Performance LLC
The past 3+ times I have taken the air filter off of my SRI the air straightener has been laying in the filter. When I installed the SRI it may not have been fully seated in the MAF housing, but each time I have put it back on it has been fully seated.
Do you have any suggestions for keeping the air straightener in place?
2007 MS3
Thanks,
<Me>"
 Old 01-26-2011, 01:30 PM   #11
 Old 01-26-2011, 01:51 PM   #12
Groans: 549
To: me at gmail.com
Hello <mdl3v8>,
Thank you,
lol... i guess put silicone on it? i figured it was permanently attached. i dunno. i'd be reluctant to put any type of matter in there, be it silicone, glue, or whatever. perhaps see if you can find someone to give it a couple zaps with a welder?
 Old 01-26-2011, 01:55 PM   #13
Russ's Avatar
Posts: 10   (View Stats)
Russ is a jewel in the roughRuss is a jewel in the roughRuss is a jewel in the roughRuss is a jewel in the rough
I don't want my horsepower to be loose...
Russ is offline   Reply With Quote
The Following User Says Thank You to Russ For This Useful Post:
thehead (01-27-2011)
 Old 01-26-2011, 02:03 PM   #14
^lol
 Old 01-26-2011, 07:25 PM   #15
CorkSport's Avatar
Posts: 3,416   (View Stats)
Use 4 small dabs of silicone on the edge and pop it back in. That is what we use to secure them. it also allows you to pull it out if needed in the future.
Derrick
WWW.CORKSPORT.COM
 Old 01-26-2011, 09:19 PM   #16
Groans: 549
why not make it permanent during manufacturing? what's the risk/benefit?
 Old 01-26-2011, 09:33 PM   #17
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
wow!
at 104000 2 bent rods
tuned by nishan
 Old 01-27-2011, 09:07 AM   #18
deuce_WI's Avatar
The housing is aluminum, the insert is plastic.
Cost to manufacture 1 piece out of aluminum is probably stupid expensive and not worth it.
Anyhow, the car seems much happier again with it in. I wish I would have known about this sooner.
 Old 01-27-2011, 09:19 AM   #19
Groans: 549
oooohhhhh.......
the sure, cp-e, and even pg intakes all have aluminum inserts. i kinda just figured they all did. except, of course, for the cobb. but the entire maf housing is plastic and the air straightener is integrated.
 Old 01-27-2011, 10:02 AM   #20
indianaryan's Avatar
Posts: 496   (View Stats)
Groans: 39
A little silicone won't hurt. Just make sure that it has bonded to the aluminum and the plastic before you throw it back on the car. You don't want your engine sucking that stuff in.
2010 Silver Mazdaspeed3
indianaryan is offline   Reply With Quote
 Old 02-13-2011, 10:04 PM   #21
boostedjavery's Avatar
Posts: 20   (View Stats)
boostedjavery will become famous soon enough
had the same problem with my corksport...so i applied locktite to the outer lip of the air splitter and it hasnt fallen out since..been about a month already....anything similar will work..silicone bein the best probally.just make sure its dry before you go sucking it up though your intake..
boostedjavery is offline   Reply With Quote
 Old 11-11-2013, 08:58 PM   #22
1sicms3's Avatar
Posts: 18   (View Stats)
1sicms3 is a jewel in the rough1sicms3 is a jewel in the rough1sicms3 is a jewel in the rough
This also happened with mine, popping po171, po300, po172 , the issue got worse ,it some how broke and blocked the air flow to my maf sensor..I would start the car then it would cut back off..after checking vacuum pressure, sparkplugs, fuel pressure , purge solenoid, cleaned maf sensor..I gave up and took it to the dealer. .and sure enough there haneded me pieces of the air straightener. .craziness if I knew that a air straightener could come loose like that before hand i would have glued it in place ..I'm lucky nothing happened to my turbo
1sicms3 is offline   Reply With Quote
 Old 11-12-2013, 02:14 PM   #23
CorkSport's Avatar
Let me know if you find out where the FMIC kit you purchased came from. It should not have been installed with the kit.
-Derrick
WWW.CORKSPORT.COM
Corksport filter very close to my BPV? 03SVTCobra 2010 MS3 - Turbo Induction 46 06-11-2010 07:24 AM
Yikes!!! CP-e SRI falling apart!?! Ironside 2010 MS3 - Turbo Induction 37 05-02-2010 01:01 PM
Gasoline prices falling below $2 in some markets Haltech Automotive News 0 11-12-2008 02:20 PM
Moody's may cut GM, Chrysler on falling SUV demand Haltech Automotive News 0 07-16-2008 07:40 AM
Page generated in 0.41120 seconds with 34 queries
