 Old 03-05-2008, 11:04 AM   #1
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groans: 57
Default Corksport FMIC
Ok so i put on the FMIC and im not really that happy with it. First off the thing needs ALOT of adjusting to get it to fit right. The throttle body hose clamps will not fit. The battery tray now push up against the inlet pipe. The stock tmic cover pushes up against the hot pipe which pushes up against the ecu black cover tray. The ram intake design sits to high and needs to be literally bent to have the hood closed. Theres no threads on the bov flang. Part of the bumper understray will not fit cause you have to cut the bumper to make it fit, which im not willing to do. One of the pipes rests against the rad in two spots. Overall the fit of this thing SUCKS.
Ok so i finish it up and go to start it, starts stumbles and dies. WTF theres no leaks, i try again and again and it eventually starts. Car warmed up and idled fine. Took for a drive and it drives a lil different. Kind of liek on on off switch right were you begin to build boost. The car boosts 17psi and holds it. With the ets it hit 19 and held it...
Drove about 15-20 miles so far not problems really. Car feels strong, but im just not happy with it. Well c if i get any lean codes liek others have reported.
Overall if i knew what i knoiw now, i would have kept my top mount.
Laloosh is offline   Reply With Quote
The Following 3 Users Say Thank You to Laloosh For This Useful Post:
3starmagnum (05-12-2012), SLS MS3 (03-09-2008), V8jester (09-04-2012)
 Old 03-05-2008, 11:13 AM   #2
sleeper3's Avatar
Posts: 675   (View Stats)
sleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant futuresleeper3 has a brilliant future
sorry for your misfortune, but you've confirmed everything that I was worried about with this kit. corksport seems to be really on top of things quality-wise, but when I learned that the MAF housing was larger than stock on this kit, I started really wondering if other things weren't up to snuff as well. I think I am going to stick with the top mount until someone gets a much better front mount solution going.
sleeper3 is offline   Reply With Quote
 Old 03-05-2008, 11:18 AM   #3
Door is THAT Way Mate ---->
Mr._Pickles's Avatar
Posts: 183   (View Stats)
Mr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these parts
I went to an FMIC on my VW. It was originally SMIC. I never got it just right. Fitting was a bit off and I was always jostling pipes around and tightening clamps to try and get it right. I never got it. I put the SMIC back on and just dealt with the heatsoak.
Mr._Pickles is offline   Reply With Quote
 Old 03-05-2008, 11:26 AM   #4
Laloosh's Avatar
Groans: 57
Ill see how i feel about it the more i drive it, for now im "eh" not worth it
 Old 03-05-2008, 12:34 PM   #5
You're probably a lot more handy with a wrench than I am. I wouldn't write it off just yet.
 Old 03-05-2008, 01:35 PM   #6
Laloosh's Avatar
Groans: 57
went out for lunch and its kind of growing me on, but still eh
 Old 03-05-2008, 01:40 PM   #7
Dream's Avatar
Posts: 10   (View Stats)
Dream is on a distinguished road
Got pics?????
--2008 Black Mica MS3--
Dream is offline   Reply With Quote
 Old 03-05-2008, 01:55 PM   #8
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
do you have it set to recirc or vta? if in recirc can you still here your bypass valve?
 Old 03-05-2008, 02:34 PM   #9
Laloosh's Avatar
Groans: 57
its set to vta
 Old 03-05-2008, 02:43 PM   #10
sleeper3's Avatar
I don't want to spend $1100 on an "eh" mod, that's for sure.
The Following 2 Users Say Thank You to sleeper3 For This Useful Post:
rondog7575 (07-15-2013), wolly6973 (12-31-2013)
 Old 03-05-2008, 02:57 PM   #11
Overboost3's Avatar
Posts: 312   (View Stats)
Overboost3 has a reputation beyond reputeOverboost3 has a reputation beyond reputeOverboost3 has a reputation beyond reputeOverboost3 has a reputation beyond reputeOverboost3 has a reputation beyond reputeOverboost3 has a reputation beyond reputeOverboost3 has a reputation beyond reputeOverboost3 has a reputation beyond reputeOverboost3 has a reputation beyond reputeOverboost3 has a reputation beyond reputeOverboost3 has a reputation beyond repute
Groaned at 34 Times in 12 Posts
That's crazy, Laloosh.. you sure you have it in right? Mine doesn't hit anywhere and the only place it's tight is near the A/C pulley(about an inch).
Mine never stumbled at start-up, no CEL, no nothing! It's far smoother than stock.. This is how the car should have come from the factory. I absolutely couldn't be more pleased with the system. I did have to trim the black TMIC cover just a hair to clear the pipe, but that was it.
Overboost3 is offline   Reply With Quote
 Old 03-05-2008, 03:29 PM   #12
Laloosh's Avatar
Groans: 57
The car flat out did not want to idle starting it the frist 2 or 3 times. There are no leaks. The piping doesnt fit right. Im 100% every is installed correct. Ive spent 8 total hours on this fucking with it every which way managable and still nothing. I mean all they gotta do is provide coupler that are a lil longer and all my problems would be solved. You have any underhood shots? When i get home tonight ill take pictures of the "problem areas"
 Old 03-05-2008, 03:35 PM   #13
Overboost3's Avatar
I'm driving my Suburban today so I don't have access to any quick shots. I can snap some when I get home if you'd like.. Let me know specifically what you want to see and I'll post it, or e-mail it to you. I'm sure you know what you're doing, but it does sound like something is off. Mine is a perfect fit.
The Following User Says Thank You to Overboost3 For This Useful Post:
SofaKingAwesome (06-17-2013)
 Old 03-05-2008, 03:46 PM   #14
I was worried about the MAF housing as well including that i would most likely have to change the BPV. I guess the real test will be at the track, BUT.. i bet it looks cool as hell.
 Old 03-05-2008, 06:21 PM   #15
Overboost3's Avatar
Here ya go..
lilred (12-13-2012)
 Old 03-05-2008, 06:23 PM   #16
Overboost3's Avatar
werd to ya mutha!
 Old 03-05-2008, 06:45 PM   #17
Laloosh's Avatar
Groans: 57
That pretty much what mine looks like. Your is touching the ecu tracy as well, and i bet its hitting the tmic cover also.
 Old 03-05-2008, 06:52 PM   #18
Overboost3's Avatar
No, it's not hitting the ECU cover/battery tray or the TMIC cover. I have about an inch between the pipe and ECU cover and about 2 inched between the pipe and TMIC cover, but I did trim back the cover.
atvfreek (02-21-2013)
 Old 03-18-2008, 09:11 PM   #19
ZoomMS3's Avatar
Posts: 94   (View Stats)
ZoomMS3 has a spectacular aura aboutZoomMS3 has a spectacular aura about
does this kit come with the tbolt clamps?
i want them on every piece of tubing.
If not, which sizes and how many of each do i need?
On motor #3
Turbo #2
Now have a SSM 08 STi!!
ZoomMS3 is offline   Reply With Quote
 Old 03-18-2008, 09:12 PM   #20
Laloosh's Avatar
Groans: 57
kit comes with tbolt clamps. 2 of them that go over the TB are too small and i used worm clamps.
 Old 03-05-2008, 04:21 PM   #21
Jesse MS3GT's Avatar
Posts: 356   (View Stats)
Jesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the world
Just feel it out, I think most of us who are neutral on x brand parts are too quick to give a thumbs down. While other who are brand fanbois are too quick to give the thumbs up.
Jesse MS3GT is offline   Reply With Quote
 Old 03-05-2008, 04:24 PM   #22
Laloosh's Avatar
Groans: 57
Yea thats what im going to end up doing. I got the thing for a killer price, kinda of jumped on it without doing much research about it. Well c how it goes, if i stay cel free and the car puts out some track numbers than i cant complain
 Old 03-05-2008, 04:34 PM   #23
Rican219's Avatar
Posts: 120   (View Stats)
Rican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the world
Guess yours is laid out different from mine. I had no issues with fitment. I sprayed soapy water to check for leaks once it did idle. I did have an issue starting mine at first and it stay running but once the ecu learned it was fine.
[SIGPIC][/SIGPIC]www.myspace.com/rican219
MODS:
TWM Short Shifter Stage 2, CPE downpipe Highflow Cat, Corksport 3 inch Catback, SU motor Mount, HKS BOV VTA, Spin on Oil filter conversion, Greddy Turbo timer, H&R Springs, Sport Max wheels, Corksport Strut Tower Brace, Corksport FMIC,Turbine Tech Front Engine Mount, Turbine Tech Rear Diff Bracket and Bushings, PROcede EMS, 2871r, Dash Hawk
Rican219 is offline   Reply With Quote
 Old 03-06-2008, 06:54 AM   #24
sleeper3's Avatar
soapy water would not bubble even with a gigantic leak. just fyi. there is no pressure in the system at an idle.
 Old 03-06-2008, 08:29 PM   #25
Rican219's Avatar
I know that but the idle would change if there was leak
MODS:
 Old 03-05-2008, 08:03 PM   #26
Overboost3's Avatar
Oh, mine doesn't hit in the back corner of the TMIC cover like yours does. Did you try pushing the pipe a little deeper? I don't like how that sounds.
 Old 03-05-2008, 08:05 PM   #27
Overboost3's Avatar
I have a couple of t-bolt clamps for the TB if you need 'em.
 Old 03-05-2008, 08:11 PM   #28
Laloosh's Avatar
Groans: 57
that pipe is as far as it will go, as for the clamps, its only the 2 tbody clamps so im not that concerned.
 Old 03-05-2008, 08:45 PM   #29
HiggyMS3's Avatar
Posts: 357   (View Stats)
HiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the world
Thats a nice looking set up, I kinda like the way they set up the new intake also.
2010 Victory Red HHR SS
2008 CPW MS3 (SOLD)
2004 Black SRT-4 (SOLD)
HiggyMS3 is offline   Reply With Quote
 Old 03-06-2008, 01:21 PM   #30
driver311's Avatar
Posts: 1,769   (View Stats)
Thats weird Chris it seemed to bolt right up to my car decently!
Mfinlay04 likes this.
The Following 3 Users Say Thank You to driver311 For This Useful Post:
Mfinlay04 (03-06-2013), SarcasticOne (03-03-2013), smoogs12 (03-04-2013)
 Old 03-06-2008, 01:49 PM   #31
sleeper3's Avatar
how do you feel about yours so far?
Ribs. I had ribs for lunch. That's why I'm doing this.
sleeper3 - 2.234, 8.742 @ 84.18, 13.365 @ 106.75 (I/IN/IC/MM)
 Old 03-06-2008, 02:24 PM   #32
Laloosh's Avatar
Groans: 57
Good ole check engine light. p2177
yea this things a winner. Tell you guys what though, the car does pull hard with it. I htink im going to stick a silicon couple in the maf housing to make it about 2.6.
 Old 03-06-2008, 02:52 PM   #33
sleeper3's Avatar
plus more turbulent...
I really expected more out of corksport. now I'm doubting their other products...
 Old 03-06-2008, 03:08 PM   #34
Laloosh's Avatar
Groans: 57
same thing as the cpe intake. The maf is smaller then the surrounding piping. Ill knife edge the silicone to make it as smooth as possible. Well there goes my day tomorrow.
BPASPEED (07-09-2012), Status Update (03-03-2014), trekkie1031 (02-27-2014)
 Old 03-06-2008, 08:30 PM   #35
Rican219's Avatar
I haven't had any issues with mine no CEL's. Have you called them with your issues? They are a great company they will work with you if you ask.
MODS:
 Old 03-06-2008, 08:28 PM   #36
driver311's Avatar
Im just glad my fujita still works with the txs fmic. It was alot simpler install once I knew what I was in for. The corksport Chris is running was gonna go on my car but I wanted to run my intake and I was running a forge. He made it work. Though I did bolt it on and no problems. WEIRD
Atleast its pulling hard. Hopefully its not running lean. Ill get the dh back asap.
 Old 03-11-2008, 07:52 AM   #37
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
Did you email CS and ask/let them know about their MAF housing being too big?
 Old 03-11-2008, 08:31 AM   #38
ptperformance's Avatar
Posts: 4,123   (View Stats)
Laloosh hit me up, I will post some pictures of our kit when I get it on the car.
 Old 03-12-2008, 08:49 AM   #39
sleeper3's Avatar
I'd be interested in what you come up with too!
 Old 03-12-2008, 10:08 AM   #40
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
looks like i'm staying with my top mount which will be here next week.
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline   Reply With Quote
The Following User Says Thank You to mrlilguy157 For This Useful Post:
occschemguy (03-12-2008)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/corksport-front-mount-intercooler-74/
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-25-2008 04:47 PM
Corksport Ram Air Box bova MazdaSpeed 3/6 - Turbo Induction 3 04-08-2010 06:42 PM
Corksport FMIC Kit bova MazdaSpeed 3/6 - Turbo Induction 22 06-12-2008 08:44 PM
Going all corksport exhaust it looks like... Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 20 03-26-2008 11:22 PM
CorkSport DP + Vibrant SLS MS3 MazdaSpeed 3 - Engine, Transmission & Driveline 9 03-24-2008 10:57 AM
Page generated in 0.61625 seconds with 35 queries
