 Old 01-02-2012, 10:12 AM   #1
arnobg's Avatar
Posts: 61   (View Stats)
arnobg is a splendid one to beholdarnobg is a splendid one to beholdarnobg is a splendid one to beholdarnobg is a splendid one to beholdarnobg is a splendid one to beholdarnobg is a splendid one to beholdarnobg is a splendid one to behold
Default Corksport turbo inlet pipe fit my ms6?
I know someone locally selling their Corksport stainless turbo inlet pipe off of their ms3. Will it fit my ms6 or are the stock inlets different on the ms3 and ms6?
arnobg is offline   Reply With Quote
 Old 01-02-2012, 10:21 AM   #2
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
yes
 Old 01-02-2012, 01:20 PM   #3
arnobg's Avatar
Originally Posted by bova80 View Post
yes
Is this a good inlet? With my Sure SRI it wont throw a CEL will it?
 Old 01-02-2012, 02:16 PM   #4
bova's Avatar
Groans: 45
it's fine. they is plenty of info out there. searching is your friend.
 Old 01-03-2012, 01:14 AM   #5
cletusb's Avatar
Posts: 488   (View Stats)
Just double check because some corksport TIPs have an extra port compared to other TIPs as the CS intake system is a slightly different design placement of the valve cover from memory
 Old 01-05-2012, 06:58 AM   #6
boost2dms6's Avatar
Posts: 237   (View Stats)
boost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the worldboost2dms6 is the leader of the world
Groaned at 6 Times in 4 Posts
I have the CS tip and it fit perfectly on my MS6. Very quality piece. I say get it.
boost2dms6 is offline   Reply With Quote
 Old 01-18-2012, 12:29 PM   #7
arnobg's Avatar
Well I got it but it doesn't seem right.... It looks like the bracket coming off the top goes a lot higher than it should for a ms6
 Old 01-18-2012, 12:37 PM   #8
arnobg's Avatar
here it is
 Old 01-18-2012, 12:42 PM   #9
mrtheandrew's Avatar
Posts: 468   (View Stats)
mrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the world
if it does go a lot higher, acquire drill, problem solved.
mrtheandrew is offline   Reply With Quote
 Old 01-19-2012, 06:35 AM   #10
arnobg's Avatar
Well not only is that piece higher but it looks like the vacuum tube is shorter than others I've seen for the 6 and that it doesn't bend as high. Idk it just looks different to me are you sure there aren't different ones for the 3 and 6 because on corksports website it asks if it's is for a 3 or 6
 Old 01-19-2012, 06:43 AM   #11
SJP0tato's Avatar
Posts: 322   (View Stats)
Give 'em a call & ask, IME Corksport is excellent with customer service.
SJP0tato is offline   Reply With Quote
 Old 01-19-2012, 07:54 AM   #12
arnobg's Avatar
Will do
 Old 01-19-2012, 08:21 AM   #13
Fucking A Gene, really? Dood. It will fit and the vacuum hose is at Auto Zone for like $1 a year or some shit.
And donate, ya brownie.
Last edited by Raider; 01-19-2012 at 08:21 AM. Reason: MSF Database - Automerged Doublepost
 Old 01-19-2012, 12:05 PM   #14
arnobg's Avatar
I'm not talking about a vacuum hose I'm talking about the tube opening under the opening that the intake clamps on.
I called corksport he seemed to not know the answer if it will fit or not said there's been variations.
The way the thing is bent and the bracket is it just looks like its going to sit lower than the stock one.
 Old 01-19-2012, 12:39 PM   #15
It will be fine.
bova (01-19-2012)
 Old 01-19-2012, 12:42 PM   #16
bova's Avatar
Groans: 45
listen to Raider, it's fine.
 Old 01-19-2012, 10:00 PM   #17
chuckms6's Avatar
Posts: 1,618   (View Stats)
chuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the world
if anything test fit it before buying and if it dont fit dont buy it. but personally im 99% sure it will fit.
DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's
SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's)
chuckms6 is offline   Reply With Quote
Turbo inlet pipe (t.i.p) bieberhole69 MazdaSpeed 3/6 - Turbo Induction 75 12-08-2010 07:23 AM
turbo inlet pipe numbnuts22715 Mazdaspeed3/6 General Discussion 38 04-01-2008 07:28 PM
Page generated in 0.36555 seconds with 28 queries
