Like Tree4Likes
  • 1 Post By tom10122
  • 3 Post By Djohns
 Old 08-24-2017, 10:29 AM   #1
tom10122's Avatar
Posts: 116   (View Stats)
tom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to all
Default Corksport turbo shrieking
On my way to work today I noticed it sounded off, it sounds like metal on metal shrieking noise. It's loud and shouldn't sound the way it does. It also won't boost past 10 psi (same as when I was running wastegate pressure) any ideas? I have less than 2000 on the turbo.
Sent from my XT1565 using Tapatalk
tom10122 is offline   Reply With Quote
 Old 08-24-2017, 10:56 AM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Have you inspected it? Checked for scoring in the housing or shaft play? That's first.
 Old 08-24-2017, 12:03 PM   #3
tom10122's Avatar
I'm at work right now, I checked it a week ago and it was fine, it just started this morning though, I won't be able to check until tonight.
 Old 08-24-2017, 12:11 PM   #4
The_Boost_Buddha's Avatar
Posts: 102   (View Stats)
The_Boost_Buddha is just really niceThe_Boost_Buddha is just really niceThe_Boost_Buddha is just really niceThe_Boost_Buddha is just really nice
Groaned at 33 Times in 12 Posts
Neutral  :  -1 score
Then how the hell would we know, you just said it yourself, metal on metal, check possible metal on metal contact points. I know you're worried but don't get ahead of yourself. Make a checklist. Everything you touched, messed with, altered, start with most likely and cheapest lol.
The_Boost_Buddha is offline   Reply With Quote
The Following 4 Users Say NO Thank You to The_Boost_Buddha For This Un-useful Post:
Djohns (08-25-2017), g00s3y (08-25-2017), sharksinspace (08-25-2017), zenit (08-24-2017)
 Old 08-24-2017, 10:18 PM   #5
tom10122's Avatar
Somehow the elbow to the intercooler was half off. I had a compression test done a week ago so I guess something wasn't tightened? It legitimately sounded like my turbo was killing itself. All better now.
mazdaspeedmyk likes this.
The Following User Says Thank You to tom10122 For This Useful Post:
zenit (08-25-2017)
 Old 08-25-2017, 06:19 AM   #6
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
No worries man... he will come back in a week or so like "problem solved, removed the tiny stone that was scratching the brake disk" or "connected back the oil feed and drain lines to the turbo, all fine now".
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 08-25-2017, 07:18 AM   #7
tom10122's Avatar
Read nigga read
It's fixed
https://youtu.be/bFtcLJVN8yg
 Old 08-25-2017, 08:29 AM   #8
Djohns's Avatar
Posts: 3,944   (View Stats)
Don't try to come in here and flame people when he had a legitimate question and was looking for ideas before he dove into it. You're dumbass was the one that shut people down on ideas before you even dove into it.
2010 black mica speed3
Soon:built motor
sharksinspace (08-25-2017), tom10122 (08-25-2017), zenit (08-25-2017)
So, about the new Corksport turbo... dale_gribble CorkSport 1859 08-01-2017 01:32 AM
corksport turbo in CA desertbound1024 MazdaSpeed 3/6 - Turbo Induction 4 04-11-2017 05:51 PM
Corksport Turbo EWG Jester2552 CorkSport 60 12-03-2015 06:53 PM
Corksport Turbo Xxblinddzxx Mazdaspeed3/6 General Discussion 9 08-25-2015 08:06 PM
Page generated in 0.30745 seconds with 24 queries
