![]() | | #41 | ![]() |
![]() Join Date: Jul 2019 Location: Central NJ
Rep Power: 10 ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score
Thanks man for the input, greatly appreciate it! At this rate, I'm inclined towards the CST4 because of better pricing. Also because of the dude above you saying his has been running 2 years strong. I would purchase the TP but don't want to risk emissions (not sure if i'll pass smog in NJ). Tomorrow I'll be purchasing the CTS4, the EBCS, and an AP + Freektune since I already have my HPFP, RMM, and CS TIP/AEM CAI. Around the summer I'll invest in the ETS TPIC & possibly go for the CS TP (very hesitant). Last question, I see everyone goes with the grimspeed EBCS but there are more options, is this also a brand preference thing? or would you recommend another one? If there are multiple posts on this I'll keep researching. Thanks man! I'll more than likely go with the CST4 so I avoid having to purchase a new intake. Plus you gave me the warm and fuzzy's knowing yours is still going strong. Last edited by 55suarod; 01-10-2020 at 03:18 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #42 | ![]() |
![]() Join Date: Jun 2013 Location: Statesboro, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score I just swapped my smoking k04 for a CST4. I also installed a corksport catted downpipe at the same time. (I already had an intake) I'm still early in the tuning process (I purchased a freektune) but at higher rpms it's quite noticeable. But it also is a bit sluggish compared to the k04 in the 2500-3000 range. Hopefully this gets better as the e-tune progresses (we are starting very conservative due to high mileage of my car) just my initial observations. |
![]() | | #43 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
![]() | | #44 | ![]() |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
You don't need anything fancy like CS EBCS. We can't alter the wastegate frequency on the factory ECU to take true advantage of it. It does look and mount nicely though.
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT | |
| The Following User Says Thank You to tegxsi For This Useful Post: | MSMS3 (01-12-2020) |
![]() | | #45 | ![]() |
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 01-13-2020 at 01:24 PM. | |
![]() | | #46 | ![]() |
| Not Ranked : 0 score I have a JBR silicone intake, JBR EGR delete, and JBR EBCS. No issues.
| Stock turbo replacement Costs and Alternator question | Dasleeper | Mazdaspeed3/6 General Discussion | 26 | 02-04-2013 05:14 PM |
| stock turbo replacement upgrade | 671 grains of reason | MazdaSpeed 3/6 - Turbo Induction | 63 | 09-17-2011 09:14 AM |
| Corksport FMIC Turbo Inlet Vs. Stock | kingpin748 | MazdaSpeed 3/6 - Turbo Induction | 8 | 07-18-2008 12:53 AM |
