![]() Join Date: Mar 2011
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Thanks for any feedback. |
![]() Join Date: Aug 2017
Groaned at 18 Times in 7 Posts
| Not Ranked : 0 score the corksport turbo is good especially for the price however it has had some problems with boost creeping at higher boost levels so make sure you port the wastegate if you are planning on running higher boost levels. Some people have chased this problem and have gotten very annoyed with it. If you are just using it as a stock replacement ive heard nothing but good things personally. They are on the cheaper side so don't expect it to last as long as a garrett turbo or anything like that but it should give you 50,000 trouble free miles easily.
__________________ HPFP, Corksport Dp to CBE, cobb SRI and TIP, Cobb big front mount intercooler, corksport RMM, eibach lowering springs, accessport v3 with e50 tune by Will @ pd tuning 22 psi 11.8 AFR |
![]() Join Date: Oct 2015 Location: Central Jerz
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score Get BNR S1. The Corksport (CST4 i'm assuming) is a great option for stock replacement if you plan on adding some power in the future. You will need a tune to safely run the Corksport turbo. But a good stock replacement turbo with the oil problems fixed; BNR S1. You don't even need a tune for it.
__________________ 2010 MS3 - Tuned By Nishan Autotech Fuel Pump Internals OBX R Custom Exhaust Cobb SF Intake & TIH w. Blitz Filter CP-e TMIC Corksport Dual VTA BPV JBR 88 Duro RMM Last edited by Bertospeed3; 05-03-2019 at 11:22 PM. |
| The Following User Says Thank You to Bertospeed3 For This Useful Post: | Db09ms3 (05-06-2019) |
| Not Ranked : 0 score The Corksport CST4 turbo doesn't creep at high boost. It creeps at high flow.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | MSMS3 (05-14-2019) |
(Thread Starter) | Not Ranked : 0 score Thanks much for the feedback! I'll look into the BNR turbo for sure. |
![]() Join Date: Aug 2009 Location: Bryan/College Station, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 137
| Not Ranked : 0 score I have the Corksport and it is an awesome turbo. I run an E30 tune and full E85 at times. BUT. The dynamics of the car will change noticeably. There is a noticeable difference is spool up and low end, kick you in the ass feel of the stock ko4. You essentially need to drive at a higher rpm to get some of the zoom zoom back. The endless power all the way to redline more than makes up for the loss down low but I have serious buyers remorse all the way to 3400 rpm then it’s goooooone and before I can say “shift” I’m bouncing off the rev limiter.
__________________ 2009 Mazdaspeed with 134,000 miles, Corksport Turbo, AT internals, CNT Turbo Back, AP, fully mounted, 3 bar, Freaktuned E25. |
| Not Ranked : 0 score With a stock bottom end, you don't want the kick in the ass spool of a K04. But with my built bottom end, I can hit 20psi by 3000 with the CS turbo and not worry about bending rods.
| Not Ranked : 0 score Do you have upgraded manifolds ? My tuner was unable to do that even with a full 3” exhaust and intake. With the stock ko4 I hit 18psi by 2400 and 23psi by 2800 on E85.... That’s a noticeable spool difference. I tried my hardest to bend rods but either the wheels spun Or IF I had enough traction in 4th the clutch would slip. Smells like dead burnt fish crap. I was probably over 400ftlbs at 2500rpm based on people saying the stock clutch is only good for 400 and some Virtual Dyno runs. I still don’t believe the whole power bends rods with these cars. 1st-4th just spun wheels with to much power. Never did it in it in 5th or 6th. on purpose at least.
(Thread Starter) | Not Ranked : 0 score Ok, I'm not looking for a ton of power, wouldn't mind a bit more though. Currently I have the Mazdaspeed CAI, actually came on the car when I bought it, and the upgraded HPFP offered through COBB. Not really going to do much, I live in Cali and the idiots here like to suppress anything that deals with cars. Y'know cars are the Devil's toys. So, I have to ask, who has experience with the recommended DNR turbos? Looking for comparisons here. Any input? |
![]() Join Date: Sep 2017 Location: Western Mass
Rep Power: 43 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score @jakeypoo, you are not trying hard enough, you can throw rods at stock power levels let alone upgrading stuff. Floor it at 1500 rpm a few times and report back. @zmmzmm3 I have the now named CST4 and I like it, maybe in the future if I get more retarded I'll replace it with either a bigger CS or something else but for now its doing its job well.
__________________ 06 Speed6 White/Black interior Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts To think... this is suppose to be my winter car... because, '72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far '12 1/2 Triumph Daytona 675R stock some how '79 AMC Spirit AMX, 4.6L stroker I6 |
| Not Ranked : 0 score ZMMZMM3 It really depend what you are looking for. The CS claim stock replacement because it is some kind of bolt on because it house larger wheels on stock frame. But it is a larger turbo than stock and that need supporting mods. If you don't plan for it, you shouldn't get that expecting to run on other factory parts... This would be a S1 instead.
And keep in mind an awd 6 would give more load to rise boost than a spinning 3....just compare the boost rise in 3 vs 4th gears.... If you don't believe bent rods, it is probably because you didn't get it for long enough....You can read about LSPI...This is the problem of all kind of new engines....small turbo and a lot of torque. It may still last but you need low BAT and enough octane or the knock will vent the bloc.
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
Been there done that. Been doing it since I bought the car. It was fun doing that when I had the stock turbo but now it just lags till the boost starts building. Over 150,000 miles. I did it 10 times during my test drive. Damn I hope I didn’t just jinks myself. I still love the Corksport. But I just wish I had known that it would feel so much different. Once I learned to drive over 3000 instead of 2000 I was much happier. But I do miss the down low diesel type torque of the ko4.
__________________ 2009 Mazdaspeed with 134,000 miles, Corksport Turbo, AT internals, CNT Turbo Back, AP, fully mounted, 3 bar, Freaktuned E25. | |
![]() Join Date: Jun 2009
| Not Ranked : 0 score The BNR S1 is what you want. It is true plug and play, everything is in the right place, oil lines, water lines, vacuum and boost lines, flanges - everything. That is because it uses a K04 outer shell, but modified internally for a Garrett GT28 guts. The journals and seals are GT28 size and design. It requires no tuning change - the flow, both on the impeller and compressor side is identical to the K04. Ask me how I know, having gone through two K04 replacements before setting on the BNR S1. This solves the problem. They just don't smoke. BNR makes several stage upgrades. You want the basic S1. The others require tuning and in most cases, upgraded hardware.
Jeff23. I’ve known that name for a long time. I agree with the awd fact you mention. I also agree that LSPI is a pita and will bend rods and blow holes in blocks. But lspi can happen at 263 hp or 500hp. My assumptions and opinions are based virtual dyno graphs and not psi. Probably not the best source. But good enough. Most importantly I don’t agree that the Corksport is a replacement for the ko4. Its a different beast. I nice one but different.
| Not Ranked : 0 score I still have stock intake and exhaust manifolds. If I can remember tonight, I'll post an old datalog. I believe I was making 20psi by 3000 when the weather was cold. It's harder to do when it warms up.
| Not Ranked : 0 score Just my opinion but these are not the cars you want if you like to lug the engine down and/or have low end torque...
| Not Ranked : 0 score We both agree on that too. Not sure if my sentence was confusing but i was trying to say the same...Someone with a factory car that just want a factory replacement turbo shouldn't buy the CS but a BNR S1
In case I forgot to say it, its not cheap, but not more than buying a new K04 from Mazda . . . and it will not smoke.
(Thread Starter) | Not Ranked : 0 score Sounds like the BNR S1 would be a better choice. I might do as much as a couple of bolt-ons in the future. My main concern is the smoking turbo, California smog program y'know. I have been happy with the car, it's a blast! If anything gets done in the future it'll be a rebuild. I might install an ethanol injection plate/spacer plate after the TB. That would mostly be for a cleaning charge into the intake. |
![]() Join Date: Mar 2019 Location: cincinnati, oh
| Not Ranked : 0 score I would say that if you are looking for the same power, and just more reliable then go for the s1. My opinion is your having to break everything down and pull that SoB out of your car. I would say put a bigger turbo, like the CS, thats the one I have, and get a mild tune. I just dont like having to pull the thang off and have to deal with all that trouble. The BNR s1 is like $950, the CST4 is $1000 plus a couple of supporting mods like boost solenoid, bar map that is free with the turbo. Your going to all that trouble of pulling it out, might as well upgrade and be done with it. |
| Not Ranked : 0 score Getting what he needs (BNR S1) now will save him so much money later because getting a CST4 will open up a rabbit hole of mods.
| Not Ranked : 0 score $350 for the HPFP internals and $130 boost solenoid, and $200 for E tune. I agree, if money is really tight then might not want to do that. I guess it depends on what you are looking to do in the future. |
![]() | | #24 | ![]() |
| Not Ranked : 0 score What he "needs" is a BNR s1. Everything else is cool but would be considered a "want"
__________________ 2010 MS3 - Tuned By Nishan Autotech Fuel Pump Internals OBX R Custom Exhaust Cobb SF Intake & TIH w. Blitz Filter CP-e TMIC Corksport Dual VTA BPV JBR 88 Duro RMM |
![]() | | #25 | ![]() |
| Not Ranked : 0 score You are correct. He said that he would be looking for a bit more power, so my argument was if your getting in there and switching the turbo out, go ahead and do it all while your in there. |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah, just a stock replacement. As much fun as it is to mod the engine, I'm getting to the point where I just want to cruise anymore. Hell , I might be the oldest guy on this site, anyone here older than 55? Old and broken, more broken than old though. I'm even thinking of letting go of my '87 MR2 and getting rid of my 4X4 cause I can't handle getting beat like that any more. I've had my fun. Really! As of late I've enjoyed driving my wife's '97 E36, soft suspension, slushbox, anemic power, HEATED seats, great for a bad back, old fart car. Although my opinion is the E36 is the best looking 3 series BMW has made, it was the worst. |
![]() | | #27 | ![]() |
| Not Ranked : 0 score To be honest with ya, if I would have known about the bnr s1 as complete stock upgrade, with no issues, just without the smoking, I probably would have done that. After ripping out two turbos though, I said I wasnt going to do it again, and got in there for hopefully the final time for my car. |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Theres something you dont hear everyday. I dont think Ive ever heard anyone say they prefer the looks of the e36. I love e46s, e30s and of course e92 but the e36 never did anything for me.
![]() | | #29 | ![]() |
![]() Join Date: May 2016 Location: Sarastoa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
__________________ 2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub Other Mods: FIAMM 72112 Low Note Horn alongside stock Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks | |
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score Like I said, my opinion. Some people think the AMC pacer is the best looking car out there..... |
![]() | | #31 | ![]() |
| Not Ranked : 0 score E36 with some sort of appearance package looks pretty good to me, but my favorite 3 series look is E46.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | Vansquish (05-17-2019) |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score I like the E36 for it's smoother lines. I think it was the last model before they started looking like the designers used CAD to design the body. |
![]() | | #33 | ![]() |
I just sold my well-maintained Speed 3 in January to another board member here. I had one vehicle too many and one had to go. I could not maintain the full size Armada SUV for towing my boat, the Volvo XC-90 for the wife, my new Audi Q5 (supercharged variant) and the Mazda. I do all my own wrenching and maintenance. I hated to see it go, but the Audi is actually quicker in a straight line, even with just a larger bolt on crank pulley, ECU and TCU tune than was the Mazda. And it has all the creature comforts (but at over twice the price). Knocks off mid 12's in the quarter just by pushing the go pedal to the floor, letting it shift and keeping it in its lane. I'm about to increase that pulley ratio and get it retuned and should drop into the high 11's with no other changes. AWD 0-60 is amazing - 4.2 seconds now and probably 3.9 soon. I do miss the agility of the Mazda, though. The Audi is an AWD midsized SUV, much higher center of gravity, and weighs a very porky 4,400 pounds. I admit to bias, but I do think that Audi has won the styling/beauty contest with BMW in recent years. I still hang out here, just to try to share what I hopefully learned from 10 years of ownership and the help of some really wise and experienced members here. I'm trying to pay back for that great help over the years.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 05-17-2019 at 12:05 PM. | |
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score 69? I don't feel so alone now. I've had one Audi in my live, 5 cylinder turbo S4. It was a monster, tuned out to over 600 at the wheels. The offer was too good to keep the car! I do all my wrenching too. But with all the injuries and abuse my body has endured I'm slower at repairing my car than continental drift. Took 2 weeks to change the timing chain in my 3. Main reason for not doing a lot of mods, and looking for a replacement part that won't need to be worked on sooner than not. |
| The Following User Says Thank You to ZMMZMM3 For This Useful Post: | MSMS3 (05-17-2019) |
![]() | | #35 | ![]() |
![]() Join Date: Jul 2019 Location: Central NJ
Rep Power: 10 ![]() ![]() ![]() Thanks: 4
Looking for the most affordable Turbo option because I'm getting an AP and full tune along with it. | |
![]() | | #36 | ![]() |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score BNR S3 is a closer match to CST4. I wouldn't bother with the S1 or S2 if you are going with a custom tune.
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
![]() | | #37 | ![]() |
I'm nervouse about the CS turbo because of what I have read and I think S3 requires a couple of other mods I dont think I can afford now. | |
![]() | | #38 | ![]() |
| Not Ranked : 0 score I believe the only "extra" mod for the S3 vs the CST4 is the intake. Since you "just installed" a CS TIP, you may be able to sell it as almost new and put that towards an intake for the S3. If you would prefer the S3 over the CST4. I've have put almost 2 years of service on my CST4 and was pushing 26-28PSI for the last 6 months.
![]() | | #39 | ![]() |
Groans: 87
With either turbo, the minimalist approach would be adding a 3-port EBCS for better boost control. With a conservative tune you can run the stock downpipe although I do recommend running a test pipe (secondary cat delete). S3 does have a slightly larger compressor inlet. Aftermarket intakes will fit but it will be a tight squeeze. With the CS TIP you can easily change the coupler.
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT | |
![]() | | #40 | ![]() |
| Not Ranked : 0 score You would need a tune and a compatible intake but everything else really depend on how far you want to push the new turbo. You could even run a 600hp turbo dialed down to 350 but you would'nt like the useless added lag that came with it. I think you should consider a BNR-s3/CST4 and just tune it for the mods you have and this way, it will last longer than a tiny one pushed beyond the limits like the k04...
| Display Modes | |
| Stock turbo replacement Costs and Alternator question | Dasleeper | Mazdaspeed3/6 General Discussion | 26 | 02-04-2013 05:14 PM |
| stock turbo replacement upgrade | 671 grains of reason | MazdaSpeed 3/6 - Turbo Induction | 63 | 09-17-2011 09:14 AM |
| Corksport FMIC Turbo Inlet Vs. Stock | kingpin748 | MazdaSpeed 3/6 - Turbo Induction | 8 | 07-18-2008 12:53 AM |
