![]() Join Date: Nov 2009 Location: las vegas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 711
(Thread Starter) | Not Ranked : 0 score the god speed manifold looks to be a exact clone of the cosworth and its only $300. they look like the would flow some serious air, but i dont know much about intake manifolds. also on cosworth site there is many more parts and upgrades for our motors, heads, crate engines. there is a guy on the other thread, the EFR full race thread also stating he is doing a speed build with the manifold and it fits fine. also i seen some pics of the godspeed manifold with the cover plate off and it has the trumpet horn things inside. (not sure what they are or do) but on the cosworth site it talks about it.
__________________ T3 Steed Speed twinscroll manifold- GT35R- CPE HPFP- COBB AP- DO METH- PTP BSD/WIN- CPE FMIC 2.5 piping- Twin Gates- CorkSport Exhaust- Full Mounts |
Groans: 793
| Not Ranked : 0 score The only IM I see for duratech/mzr on the cosworth site is an n/a manifold.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
Groans: 136
__________________ |
Groans: 793
| Not Ranked : 0 score No not that one. That's nice. The other I saw was itb's.
(Thread Starter) | Not Ranked : 0 score like..... throttle body plate, to change bolt pattern and drill and tap a hole, not real clear yet still looking into this, but mods seem easy to do. one good thing i read, like 5 pages on, was the god speed one is the exact same clone as the cosworth. close to same quality ect.... and its only 300/ 260 on ebay. dont get me wrong, it might not fit our motors at all. still need to do more research on this.
__________________ T3 Steed Speed twinscroll manifold- GT35R- CPE HPFP- COBB AP- DO METH- PTP BSD/WIN- CPE FMIC 2.5 piping- Twin Gates- CorkSport Exhaust- Full Mounts | |
![]() Join Date: May 2011 Location: Portage, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,113
Groans: 83
| Not Ranked : 0 score The trumpets you're referring to are called ITBs individual throttle bodies. Great for immediate throttle response on N/A builds.
__________________ -#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo -1970 Chevelle - Needs full resto Last edited by MSFer87; 12-25-2011 at 02:27 PM. |
(Thread Starter) | Not Ranked : 0 score just looking over at scotts intake manny thread, man it looks sweet.
| Not Ranked : 0 score The Cosworth mani would require some mods to both the head and the IM, the port injection bosses would have to be filled, the tb flange would have to be cut off and a new one welded on, the IM doesnt have the same number of bolts, the flange around runner 1 may have to be modded, that IM iirc doesnt have individual runners so the head will need to be ported to have 4 intake runners, the vacuum connections are almost certainly different, im not certain where the crankcase evac port is on that IM or if it even has one.
(Thread Starter) | Not Ranked : 0 score after more research i see what your saying and totally not worth the effort and may not even be possible. the SD manny is looking very nice though
| Banned ![]() Join Date: Feb 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score this cosworth intake manifold is the single best intake manifold design ive ever seen for sale on the aftermarket. True F1 quality. When they first debuted this years ago I was begging them to offer this style for an evo and b series honda. they were not interested you guys are lucky it can work... if it were my car I'd do whatever it takes to use this manifold |
| The Following 5 Users Say Thank You to Full-Race Geoff For This Useful Post: | Alpha (12-27-2011), Chimmike (12-27-2011), djuosnteisn (12-27-2011), mason (12-28-2011), paveltol (12-27-2011) |
Groans: 433
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. | |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
| Not Ranked : 0 score Cosworth IM Impressions Hmm... It'd change the cold piping a bit due to the TB angle, but other than that it seems like only some minor grinding, spacing, plugging, and drilling.
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() Last edited by Alpha; 12-27-2011 at 12:54 PM. |
I'll give it a shot, $240 on ebay is a worthy investment, even if it doesn't work, lol.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | ||
| The Following 26 Users Say Thank You to djuosnteisn For This Useful Post: | Alpha (12-27-2011), AZSPEED3 (12-30-2011), BobtailedSnail (04-16-2012), Bucker (01-03-2012), Captain KR (12-27-2011), Cataphract_40 (12-27-2011), charlesfist (12-28-2011), daafisch (12-28-2011), Easter Bunny (12-27-2011), eppopipe (01-03-2012), essejkcamraw (12-30-2011), josurr (12-27-2011), mason (12-28-2011), Nataphen (12-29-2011), NJSPEED3 (12-30-2011), obijack (01-02-2012), paveltol (12-27-2011), qtrmile beast (12-27-2011), RhoadBlock (12-27-2011), RichieRichness (12-30-2011), spnkr21 (12-27-2011), thanox2 (01-02-2012), Tokay444 (12-27-2011), wankular (12-27-2011), wolly6973 (12-28-2011), zpele (01-04-2012) |
| Not Ranked : 0 score Purchased.
| The Following 27 Users Say Thank You to djuosnteisn For This Useful Post: | Alpha (12-27-2011), AZSPEED3 (12-30-2011), BobtailedSnail (04-16-2012), Bucker (01-03-2012), Captain KR (12-27-2011), Cataphract_40 (12-27-2011), charlesfist (12-28-2011), daafisch (12-28-2011), Easter Bunny (12-27-2011), eppopipe (01-03-2012), Jackis (12-29-2011), josurr (12-27-2011), Mizzle (12-29-2011), Nataphen (12-29-2011), nighthawk358 (01-02-2012), NJSPEED3 (12-30-2011), obijack (01-02-2012), RhoadBlock (12-27-2011), RichieRichness (12-30-2011), silvapain (12-27-2011), spnkr21 (12-27-2011), thanox2 (01-02-2012), themytb (12-27-2011), Tokay444 (12-27-2011), uncorked11 (12-27-2011), wolly6973 (12-28-2011), zpele (01-04-2012) |
Groans: 433
| The Following 2 Users Say Thank You to Chimmike For This Useful Post: | djuosnteisn (12-27-2011), themytb (12-27-2011) |
| Not Ranked : 0 score Dude... If we can get that casting to work with a little bump and grind action I'm TOTALLY gettin the Cosworth mani! ![]() That thing FLOWS. Kid posted a video on an NA 3 and it sounded like VTech on an RSX Type S... SUPER throaty and crazy!
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() |
| The Following User Says Thank You to Alpha For This Useful Post: | djuosnteisn (12-27-2011) |
| Not Ranked : 0 score They have a different runner setup from us.
| The Following 2 Users Say Thank You to 06Speed6 For This Useful Post: | djuosnteisn (12-27-2011), Enki (01-02-2012) |
| Not Ranked : 0 score Since we'd need a spacer similar to a thick TIG to plug the excessive hole near the TB, coulld we not machine our head ports into this on one end and have it taper to match the Cosworth runner? Like a spacer/adapter? I'm a total newb at this stuff and don't know how much tubulence that'd make, but just an idea...
| Not Ranked : 0 score Dustin you a bastard lol, ive been looking for a cheap used cossi mani for over a year
| The Following User Says Thank You to 06Speed6 For This Useful Post: | djuosnteisn (12-27-2011) |
![]() Join Date: Mar 2010 Location: Lewistown, PA (State College)
Rep Power: 1938 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,144
| Not Ranked : 0 score SilverDemon/JM Fabrications Intake Manifold Interest Thread This is a nice peice, but I think ill wait for this one.
__________________ 2010 MS3 - Sold 2015 CX-5 GT AWD - Current ![]() |
| The Following User Says Thank You to trf5000 For This Useful Post: | 06Speed6 (12-27-2011) |
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | |
But still... not too difficult. We'll see how it looks when it shows up. I stared at this mani for a long long time a year ago or so, and just never thought it was feasible. But i guess i've learned a lot since then lol, cause right now it doesn't seem daunting at all.
**edit**... the blank head you sold to alpha, who sold to me ![]() Seriously though, this could be an easy slam dunk. Or a complete waste of $260 (price with shipping). Only one way to find out, hahaha.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com Last edited by djuosnteisn; 12-27-2011 at 01:31 PM. Reason: MSF Database - Automerged Doublepost | |||
| Not Ranked : 0 score I am friends with some of the guys at cosworth - and will try to keep you updated with any info they share with me. I very strongly encourage you NOT to use the godspeed products, they are very poorly made and I expect you will have problems (cracking, warping, vacuum leaks, etc) at least that is my experience with them. I think the cosworth part is a bargain for $750 to be honest. I would really like to see this intake manifold work easily on the mazdaspeeds.. I will stay up on this thread, see if i can help. make sure you guys post pics! |
| The Following 12 Users Say Thank You to Full-Race Geoff For This Useful Post: | 06Speed6 (12-27-2011), Alpha (12-27-2011), AZSPEED3 (12-30-2011), BobtailedSnail (04-16-2012), charlesfist (12-28-2011), djuosnteisn (12-27-2011), Nataphen (12-29-2011), nighthawk358 (01-02-2012), RhoadBlock (12-27-2011), wankular (12-27-2011), wolly6973 (12-28-2011), zpele (01-04-2012) |
![]() | | #24 | ![]() |
The GS piece will simply make a nice shelf ornament in the garage, haha.
![]() | | #25 | ![]() |
Groans: 433
| Not Ranked : 0 score I can't figure out why Cosworth hasn't seen the potential in the MZR yet to start developing stuff for us. I met Eric Hsu years ago just after he first started working for Cosworth. Met him thru an old Nissan buddy of mine who has an online publication and some stuff. You might know who I'm talking about, Geoff, he's over in SoCal. Wish Cosworth would step it up! CAMS PLEASE!
| The Following User Says Thank You to Chimmike For This Useful Post: | Alpha (12-27-2011) |
![]() | | #26 | ![]() |
Friends that want a slightly modified version of their pimptake manifold!
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() | |
| The Following User Says Thank You to Alpha For This Useful Post: | Chimmike (12-27-2011) |
![]() | | #27 | ![]() |
![]() Join Date: Oct 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,548
Groans: 30
| Not Ranked : 0 score Subbing the shit out of this thread
__________________ 2008 GT MS3 - 307 WHP/338 WTQ ATP GTX2867R - HTP 3" Intake - Cobb FMIC pipes + Treadstone TR8L - Cobb Catted Turboback - Cobb XLE BPV - Denso ITV22 plugs - Corksport Injector Seals - KMD HPFP - Cobb AP - CP-E RMM - Southbend Stage 3 Enduro Clutch/Flywheel - Bilstein B8s + Swift Springs - SPC Rear Camber Arms - Hotchkis RSB - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18 1995 Miata Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - 949 Racing XIDA CS Coilovers - IL Motorsports suspension bushings - Racing Beat FSB - 949 Endlinks |
![]() | | #28 | ![]() |
![]() Join Date: May 2008 Location: Brandon, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 667
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score hmmm...should bolt right on to the motor for my build..... |
| The Following 3 Users Say Thank You to RhoadBlock For This Useful Post: |
![]() | | #29 | ![]() |
| The Following 4 Users Say Thank You to Alpha For This Useful Post: |
![]() | | #30 | ![]() |
![]() Join Date: Nov 2010 Location: Moscow, Russia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 208
| Not Ranked : 0 score I think I should keep an eye on this thread.
__________________ Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc.. |
| The Following User Says Thank You to paveltol For This Useful Post: | Alpha (12-27-2011) |
![]() | | #31 | ![]() |
| Not Ranked : 0 score Dustin I didnt know that you got a knock off im, Ive been looking for an actual Cosworth IM. The GS IM should work for a test fit though.
![]() | | #32 | ![]() |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
| Not Ranked : 0 score Sub'd!
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
![]() | | #33 | ![]() |
| Not Ranked : 0 score I hope it fits. Probably going to have to plug the idle control valve (?) hole. Or EGR?
![]() | | #34 | ![]() |
Me too man, haha.
| The Following 5 Users Say Thank You to djuosnteisn For This Useful Post: | 06Speed6 (12-27-2011), Alpha (12-28-2011), BobtailedSnail (04-16-2012), Cataphract_40 (12-27-2011), Tomas (12-27-2011) |
![]() | | #35 | ![]() |
not to mention sfwd1934 is working hard to get other mfgs up and building parts! damn.. now youve got me wanting to buy these and cut them up, welding the evo head flange on there... Last edited by Full-Race Geoff; 12-27-2011 at 04:56 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following 11 Users Say Thank You to Full-Race Geoff For This Useful Post: | 06Speed6 (12-27-2011), 4G63 (01-04-2012), Alpha (12-28-2011), BobtailedSnail (04-16-2012), Cataphract_40 (12-27-2011), Chimmike (12-27-2011), djuosnteisn (12-27-2011), eppopipe (01-04-2012), TriO (12-28-2011), wankular (12-28-2011), zpele (01-04-2012) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score ^^^ You are not allowed to be here. Get back to making EFR manifolds. Time is being wasted. lol
| The Following User Says Thank You to Tomas For This Useful Post: | 06Speed6 (12-27-2011) |
![]() | | #37 | ![]() |
Groans: 433
Glad to hear you're pushing the mzr platform with other manufacturers. Thanks a lot Geoff!
| The Following User Says Thank You to Chimmike For This Useful Post: | Alpha (12-28-2011) |
![]() | | #38 | ![]() |
![]() And yes, let's do it! I've got dibs on the first one! Haha!
| The Following 2 Users Say Thank You to Alpha For This Useful Post: | djuosnteisn (12-28-2011), spnkr21 (12-28-2011) |
![]() | | #39 | ![]() |
Groans: 239
| Not Ranked : 0 score is this what we speak of? 03-10 Focus DURATEC 2.3L turbo INTAKE MANIFOLD PLENUM | eBay
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
![]() | | #40 | ![]() |
| Not Ranked : 0 score It is... but the ebay version is probably trash. Probably make you have to wait til 6k rpm til you can go full boost, hahaha. When i get mine, i'll post up whether or not i think it's viable.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/cosworth-godspeed-intake-manifolds-100523/ | ||||
| Cosworth Inlet Manifold ? Mazda MPS Owners Club | This thread | Refback | 12-30-2012 06:04 AM | |
| Cosworth Inlet Manifold • Mazda MPS Owners Club | This thread | Refback | 11-07-2012 06:35 AM | |
| ?????? ????????, ????? Cosworth | This thread | Refback | 03-30-2012 02:23 AM | |
| Mazda MPS Owners Club • View topic - Cosworth Inlet Manifold | This thread | Refback | 02-12-2012 04:08 AM | |
| Mazda MPS Owners Club • View topic - Cosworth Inlet Manifold | This thread | Refback | 01-06-2012 03:20 PM | |
| godspeed ewg | turd burglar | MazdaSpeed 3/6 - Big Turbo Builds | 6 | 06-23-2010 10:29 AM |
| intake manifolds... | bombdotcom | MazdaSpeed 3/6 - Turbo Induction | 31 | 01-30-2009 12:26 PM |
| Intake manifolds?? | steedspeed | MazdaSpeed 3/6 - Turbo Induction | 74 | 10-25-2008 08:00 AM |
| manifolds?!?! | Grim | Mazdaspeed3/6 General Discussion | 136 | 09-13-2008 11:47 AM |
