![]() | | #81 | ![]() |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score |
![]() | | #82 | ![]() |
![]() Join Date: May 2008 Location: Brandon, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 667
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score The 2.5L head is identical to the 2.3L except for having one extra oil port. Read thru the link I posted a few posts ago. At least that's for the DTEC. But I don't see the MZR being much different but I haven't seen them in person. Sent from my iPhone using Tapatalk |
![]() | | #83 | ![]() |
Groans: 113
| Not Ranked : 0 score I still haven't read your link but wouldn't the chamber's not match up? How could the chamber on the head of the 2.3 and 2.5 be the same lol? I guess I'll read the link now hahaha |
![]() | | #84 | ![]() |
Groans: 793
| Not Ranked : 0 score If they're getting the extra displacement with stroke and shorter rods, and all else is equal... But I have no experience with either engine or their dtec variants.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
![]() | | #85 | ![]() |
Groans: 113
| Not Ranked : 0 score ugh I'm not reading all that shit, lol. Assuming they kept the same bore size as the 2.3l than I can see how this can be easily done. |
![]() | | #86 | ![]() |
2.3L - 87.5mm x 94mm (bore x stroke) 2.5L - 89mm x 100mm Sent from my iPhone using Tapatalk | |
![]() | | #87 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score So besides the oil port they should be interchangable????
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
![]() | | #88 | ![]() |
| Not Ranked : 0 score Besides the oil port and boring the block out to 89mm, they should be interchangeable. As well as other shit you'll have to do for a full PI swap. |
![]() | | #89 | ![]() |
![]() Join Date: Jan 2011 Location: vancouver,WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 184
You could match the bore but the block would have to be sleeved with something like a darton mid sleeve set up, the oe 2mm sleeve cannot be bored beyond 88mm without totally killing it's intergrity | |
![]() | | #90 | ![]() |
Groans: 113
| Not Ranked : 0 score Ugh that sucks, I figured the bores were going to be off size. I think you guys are better off just using the 2.3l na head. I mean think about it After you bore out the block to a 2.5liter and slap on a different head, you end up with a completely different motor, lmao. |
![]() | | #91 | ![]() |
| Not Ranked : 0 score Yeah pretty much....way cheaper to just do the head work to the 2.3head....lol cheap...no such fucking thing. |
![]() | | #92 | ![]() |
| Not Ranked : 0 score So the 2.3 na head will work then? If so I could pick up an na head, do some work to it and then run the cosworth intake manifold? The exhaust mani bolt up to the na head? Sorry for all the questions I guess If I just went out and looked a lil closer at my head I could answer some of my guestions LOL Thanks guys.
![]() | | #93 | ![]() |
![]() Join Date: Jun 2010 Location: li, merrick, new york
Rep Power: 2273 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,757
| Not Ranked : 0 score Idk why anyone would want to switch from a disi head to a mzr head. Just me maybe , but I'd rather wait on the inj and add an auxiliary fuel system to compensate. There's only a few reasons this platform is making so muck power on these stock and atp turbos and that's the Di doing It's job. Di allows u to have a better angle on the intake valve ( in porting It's called raising the roof, you're not eating up runner volume with dense fuel , lower egt , less hc eating up exhaust volume as well as temps keeping expansion at a minimum also allowing more to escape in a smaller space. If someone does thus I would like to see the outcome though .
__________________ First 500whp stock block mazdaspeed3 (503whp 423wtq) <3 Tokay. |
| The Following 8 Users Say Thank You to kmac For This Useful Post: | 4G63 (01-04-2012), djuosnteisn (01-03-2012), Easter Bunny (01-04-2012), Nataphen (01-03-2012), Tokay444 (01-03-2012), Tomas (01-03-2012), wolly6973 (01-03-2012), zpele (01-04-2012) |
![]() | | #94 | ![]() |
Groans: 433
| Not Ranked : 0 score I also think a good set of production cams could allow the DISI MZR breathe really well. Even with stock IM, if that were the case.
| The Following User Says Thank You to Chimmike For This Useful Post: | djuosnteisn (01-03-2012) |
![]() | | #95 | ![]() |
Kmac if you are reading through this thread did you ever get that larger tb to work?, I has been suggested to me to try out a mzr6 v6 tb? | |
| The Following User Says Thank You to Tabasco69 For This Useful Post: | kmac (01-03-2012) |
![]() | | #96 | ![]() |
__________________ First 500whp stock block mazdaspeed3 (503whp 423wtq) <3 Tokay. | |
| The Following 5 Users Say Thank You to kmac For This Useful Post: | charlesfist (01-04-2012), djuosnteisn (01-03-2012), Nataphen (01-03-2012), Tabasco69 (01-03-2012), Tomas (01-03-2012) |
![]() | | #97 | ![]() |
![]() Join Date: Nov 2009 Location: las vegas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 711
i feel the same, i want my direct injection! DI was made for turbo cars! Well to some point! the added power befor the turbo gets going along with everything kmac said. GM made the cobalt turbo car DI for the benifits of DI. there will be better DI solutions soon.....
__________________ T3 Steed Speed twinscroll manifold- GT35R- CPE HPFP- COBB AP- DO METH- PTP BSD/WIN- CPE FMIC 2.5 piping- Twin Gates- CorkSport Exhaust- Full Mounts | |
| The Following User Says Thank You to mason For This Useful Post: | kmac (01-03-2012) |
![]() | | #98 | ![]() |
![]() Join Date: Oct 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,548
Groans: 30
__________________ 2008 GT MS3 - 307 WHP/338 WTQ ATP GTX2867R - HTP 3" Intake - Cobb FMIC pipes + Treadstone TR8L - Cobb Catted Turboback - Cobb XLE BPV - Denso ITV22 plugs - Corksport Injector Seals - KMD HPFP - Cobb AP - CP-E RMM - Southbend Stage 3 Enduro Clutch/Flywheel - Bilstein B8s + Swift Springs - SPC Rear Camber Arms - Hotchkis RSB - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18 1995 Miata Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - 949 Racing XIDA CS Coilovers - IL Motorsports suspension bushings - Racing Beat FSB - 949 Endlinks | |
![]() | | #99 | ![]() |
Groans: 239
| Not Ranked : 0 score not if we dress up as ghosts, and burn a lower case t on their lawn. t for ....... time to make cams
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
| The Following 9 Users Say Thank You to dooderek For This Useful Post: | Bucker (01-04-2012), Cataphract_40 (01-04-2012), djuosnteisn (01-03-2012), Easter Bunny (01-04-2012), kmac (01-03-2012), MSFer87 (01-04-2012), RhoadBlock (01-03-2012), Tokay444 (01-03-2012), zpele (01-04-2012) |
![]() | | #100 | ![]() |
(Thread Starter) | Not Ranked : 0 score soon as we prove that 30 psi is no big deal on the stock block! then they will flock to us! we need to get more high power cars out there layin down hard track times putting up bad ass dyno runs ect..... and im thinking more will open up to the DI systems.....
![]() | | #101 | ![]() |
![]() Join Date: Apr 2011
| Not Ranked : 0 score Those pictures were taken by TopSpeed which they currently specialize in ford focus's, The focus 2.3 duratec engine does not have VVT. But Ford made a revision in the new 2.5L heads for VVT. The extra oil port is most likely for VVt as this is the common piece missing. And for those of you who haven't seen a DISI or VVT engine for that matter pulled apart they have that oiling hole. The Disi does fit the MZR/duratec heads 2.3 and 2.5. I know for a fact that the 2.3L head needs modification done (oil passage ways, and coolant) to fit the disi bottom end, This information was given to me by a drag racing team out of northern VA who use this block in a tubular drag car. I've seen these engines first hand so it is doable. The 2.5L does have widened oiling and cooling ports which are the primary machining needed for this to work. So it does potentially have the ability to be a direct replacement I hopefully will know here shortly once I can get a hold of one for cheap. |
![]() | | #102 | ![]() |
| Not Ranked : 0 score as far as cams go I think crower will regrind/rework the oe bumpsticks...call them up. |
![]() | | #103 | ![]() |
| Not Ranked : 0 score Regrinds and shit isn't what we want tho. We want full fledged attention. Companies to make DISI specific cams - street & aggressive race/power options. We want DISI specific injectors. DISI specific shit. It's the future. But no tuning companies want to move the fuck forward. Plus the shitty economy isn't helping many of them take the plunge for major R&D for DI products. I'd love to keep the DISI after all that's been happening the past 5 years or so. Low 11s and 500+ whp is still impressive. But I don't want to sit at the edge of the wall waiting for more shit. I'll sacrifice some tq with my PI build. AWD will make up for it off the line. And a small shot of laughing gas can make up for the low end tq too. I love the aftermarket support it's already got - for such a (relatively) simple engine swap. By the time I finish this build I'll be ready for a used 5.0 anyway. |
| The Following 3 Users Say Thank You to RhoadBlock For This Useful Post: |
![]() | | #104 | ![]() |
![]() Join Date: Mar 2010 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,038
Groans: 123
I guess is what I'm saying is that to me in the performance industry companies want to see TRACK TIMES not dyno queen cars who never take a ride down the dragstrip. I guarantee that next spring/summer if all the unicorns come out to play and we get 25, 50, 100 etc Speeds in the low 12s, 11s, and shit even 10s then companies will be banging down doors to help this platform out. As seen by Geoff from Full Race in this thread. Don't give up man ur car is one my my favorite speeds of all time, patience is a virtue ![]() Thread way off track my bad! Dj keep doing what ur doing makes me wish I had stayed around
__________________ 2003 Evo VIII BUILD PLANS: LR 2.0/2.4, 6466, 800+whp. Shooting for 9s at full weight. Time is on my side, gonna take forever. Old: 2009 White MS3. Fully bolted and tuned. Sold | |
| The Following User Says Thank You to 4G63 For This Useful Post: | djuosnteisn (01-04-2012) |
![]() | | #105 | ![]() |
Groans: 433
| Not Ranked : 0 score Companies don't give two shits what the track times are. They care how much money they could make. And there are plenty of MZR DISI guys who would buy cams and intake manifolds. Shit, even stock turbo guys would buy cams.
| The Following 9 Users Say Thank You to Chimmike For This Useful Post: | 4G63 (01-04-2012), BobtailedSnail (04-16-2012), Cataphract_40 (01-04-2012), djuosnteisn (01-04-2012), kmac (01-04-2012), kritz (01-04-2012), MarkyMark (01-04-2012), MSFer87 (01-04-2012), RhoadBlock (01-04-2012) |
![]() | | #106 | ![]() |
![]() Join Date: Dec 2010 Location: Springfield, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,536
Groans: 354
Groaned at 213 Times in 109 Posts
__________________ 2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now) 2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy | |
![]() | | #107 | ![]() |
| Not Ranked : 0 score No but you get that cool ass engine choking sound. lope lope lope lope lope lope |
![]() | | #108 | ![]() |
| Not Ranked : 0 score Idt do cars really lump too much. I think It's very little from what I hear.
![]() | | #109 | ![]() |
Groans: 433
Most of us have increased idle though, so probably not too noticeable.
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. | |
![]() | | #110 | ![]() |
![]() Join Date: May 2011 Location: Portage, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,113
Groans: 83
| Not Ranked : 0 score FYCOHN (FUCK YOUR CAMMED OUT HONDA NIGGA) For those who have never heard a cammed out 4 cyl before
__________________ -#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo -1970 Chevelle - Needs full resto |
![]() | | #111 | ![]() |
| Not Ranked : 0 score I know cars lump , Di doesn't lump as much . @Erich has cams ask him . He would be most knowledgeable on this.
![]() | | #112 | ![]() |
| Not Ranked : 0 score There's a couple better sounding cammed SRT4s & Evos on youtube that actually have an exhaust on them so they don't sound so raspy. Orrrr you can do like I did and fry your MAF sensor. Your car will run like shit but it sounds fucking rad at start up & idle lol
__________________ 2007 MS6 - broked & gone 2006 MS6 - less broked Last edited by RhoadBlock; 01-04-2012 at 09:08 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #113 | ![]() |
| Not Ranked : 0 score One thing to remember with cams, is that you'd have to buy a set of cam followers (or several sets of varying thickness), and make sure tappet clearance is in spec. It wouldn't be as simple as just "dropping them in"... at least not if you wanna do it right. But beyond that... it shouldn't be toooooo difficult.
![]() | | #114 | ![]() |
1. Figure out a profile that would be more aggressive. Just an aggressive street profile. Not even a crazy stage3/4 drag profile...yet. 2. Make the cams and provide an appropriately sized set of followers for them. Install them for R&D. 3. Have PERM play around with tuning for them. 4. Revise if needed. R&D with PERM again. 5. Mass produce. 6. Enjoy thousands of dollars from MSF members. | |
| The Following User Says Thank You to RhoadBlock For This Useful Post: | djuosnteisn (01-04-2012) |
![]() | | #115 | ![]() |
| Not Ranked : 0 score Hahaha, PERM would be happy to do that.... :phillyb:
But i agree... minor detail only. And it really wouldn't be that hard to do.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
![]() | | #116 | ![]() |
(Thread Starter) | Not Ranked : 0 score someone put a tread up with the everyone to sign up and start emailing them to different cam companies? unless this has already been done..... sounds like a good idea to me. also i remember i talked to this dude cobb told me about when i was ready to tune my big turbo setup and he wouldnt tune me at all because i was on the stock block. he had no idea the hurdles we made with tuning ect.... and im sure thats the case alot with aftermarket companies. they have no idea were we are at with this platform. they gave up in 2008 and havent looked back.
| The Following User Says Thank You to mason For This Useful Post: | djuosnteisn (01-04-2012) |
![]() | | #117 | ![]() |
Groans: 30
| The Following 2 Users Say Thank You to Cataphract_40 For This Useful Post: | djuosnteisn (01-04-2012), RhoadBlock (01-05-2012) |
![]() | | #118 | ![]() |
Groans: 793
| Not Ranked : 0 score I'd buy vvt killer cams in a heart beat.
![]() | | #119 | ![]() |
![]() | | #120 | ![]() |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/cosworth-godspeed-intake-manifolds-100523/ | ||||
| Cosworth Inlet Manifold ? Mazda MPS Owners Club | This thread | Refback | 12-30-2012 06:04 AM | |
| Cosworth Inlet Manifold • Mazda MPS Owners Club | This thread | Refback | 11-07-2012 06:35 AM | |
| ?????? ????????, ????? Cosworth | This thread | Refback | 03-30-2012 02:23 AM | |
| Mazda MPS Owners Club • View topic - Cosworth Inlet Manifold | This thread | Refback | 02-12-2012 04:08 AM | |
| Mazda MPS Owners Club • View topic - Cosworth Inlet Manifold | This thread | Refback | 01-06-2012 03:20 PM | |
| godspeed ewg | turd burglar | MazdaSpeed 3/6 - Big Turbo Builds | 6 | 06-23-2010 10:29 AM |
| intake manifolds... | bombdotcom | MazdaSpeed 3/6 - Turbo Induction | 31 | 01-30-2009 12:26 PM |
| Intake manifolds?? | steedspeed | MazdaSpeed 3/6 - Turbo Induction | 74 | 10-25-2008 08:00 AM |
| manifolds?!?! | Grim | Mazdaspeed3/6 General Discussion | 136 | 09-13-2008 11:47 AM |
