Like Tree4Likes
 Old 01-04-2012, 06:53 PM   #121
pinkcheese's Avatar
Posts: 339   (View Stats)
pinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the world
There are quite a few options available for a PI head, even without going custom. The range of the OEM buckets goes quite a bit of ways I used to have notes on these but seem to have missplaced them. Also there are aftermarket ones from supertech which can go beyond OEM for shimming.
As for cam options for a PI heads Duratec Turbo Cams Selection here are the options.
pinkcheese is offline   Reply With Quote
The Following User Says Thank You to pinkcheese For This Useful Post:
djuosnteisn (01-05-2012)
 Old 01-05-2012, 09:19 AM   #122
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
The cosi manifold looks like it's going to require LOTS of modification to work.
I'll post up some pics over lunch, but it's far from "simply cut a few things off, bolt up and go".
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Cataphract_40 (01-05-2012), Easter Bunny (01-05-2012), wolly6973 (01-05-2012)
 Old 01-05-2012, 09:33 AM   #123
RhoadBlock's Avatar
Posts: 793   (View Stats)
Groaned at 7 Times in 4 Posts
You picked up the Godspeed one right?
2007 MS6 - broked & gone
2006 MS6 - less broked
RhoadBlock is offline   Reply With Quote
The Following User Says Thank You to RhoadBlock For This Useful Post:
 Old 01-05-2012, 10:07 AM   #124
Captain
Yup. But when you see the pictures, you'll understand what i'm saying. Head flange bolt holes don't even line up...
I'll get the pics ready in like an hour or two during lunch.
www.permtuning.com
Tokay444 (01-05-2012)
 Old 01-05-2012, 10:22 AM   #125
driver311's Avatar
Posts: 1,769   (View Stats)
Originally Posted by Tabasco69 View Post
That's crazy talk man....you would be giving up di, plus this would make your ecm incompatible, no more tuning with a gameboy, trust me this manifold is not worth it, the grass only seems to be greener on the other side of the fence....it isn't trust me, have a custom fabed im made you'll be way better off in the end.....I know your stock one sucks ass, looks like it has no plenum what so ever, just a shallow common collector to all of the runners by what I have seen.... but nothing more boost can't offset.
Kmac if you are reading through this thread did you ever get that larger tb to work?, I has been suggested to me to try out a mzr6 v6 tb?
Not giving up the disi, Im more than happy with how my car is pulling (for now) just curious more than anything? I wasnt even sure if the regular mazda motor was direct injection or not to tell you the truth. thats why I was asking. It would be nice if cosworth just made us a mani.
Mazdaspeed
The Following User Says Thank You to driver311 For This Useful Post:
spnkr21 (01-05-2012)
 Old 01-05-2012, 10:24 AM   #126
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
is it possible that you can just cut the flange off and use the stock flange insted? or will the runners not line up properly?
track weight 3220
street weight 3370
The Following User Says Thank You to qtrmile beast For This Useful Post:
 Old 01-05-2012, 01:22 PM   #127
Captain
^^... you may be able to simply reflange, but the runner spacing is still slightly different. It would require a fair amount of porting.... and even then, i'm not sure there is enough material to make it feasible.
Here's the pics:
Overall shot 1:
Overall shot 2:
<insert shitty build quality here> The ebay mani certainly has it's fair share of flaws. The cover plate fitment was dismal. One corner fit flush, while the other 3 were raised significantly. Kinda hard to tell from photos, but you can still see how "raised" it is:
And the second i took it off, the gasket broke lol:
Lots of flash on the v-stacks. Would probably take a significant amount of time to finish em:
Onto fitment photos....
Here's a pic comparing an individual port width, surprisingly similar, despite our 2 port design:
I had an old thermal gasket laying around, so here's a shot with it next to a blank head, just to show it's valid for comparison purposes:
Here's the gasket overlaid on the Ebay mani:
Right off you can see that there are some serious differences between the two. In fact the gasket has 3 holes which aren't even present on the manifold, one of which lines up on the manifolds throttle inlet port. And if you look at the runner spacing, you'll notice that the outer runners are significantly further out on the DISI MZR. Our runner spacing is slightly larger.
Here's a close up of the center section overlay. I lined up the bottom hole:
Here's the left side (cyl 4 side):
Again, you can see how our 4th runner is further out than the duratec.
Here's the right side (cyl 1 side):
And if you were to reflange the manifold to "make" it work... you'd have to make these cuts:
Then you'd have to band-aid any potential holes by runner 4, and pipe out a section for the mazda throttle body (or w/e tbody you choose). And after welding on a new head flange, you'd have to cross your fingers and hope there is enough material to port match the runners.... which i doubt is feasible whatsoever. The casting is fairly thick (read: heavy), but not that thick.
I dunno if it's worth my time to even attempt honestly. If i have a bored day sometime in the future, i may. Or i may just powder coat it and sell it for what i paid, lol.
www.permtuning.com
The Following 11 Users Say Thank You to djuosnteisn For This Useful Post:
06Speed6 (01-22-2012), Cataphract_40 (01-05-2012), charlesfist (01-05-2012), Enki (01-05-2012), Jackis (01-07-2012), NJSPEED3 (01-05-2012), qtrmile beast (01-05-2012), RhoadBlock (01-05-2012), spnkr21 (01-05-2012), Tomas (01-05-2012), wolly6973 (01-06-2012)
 Old 01-05-2012, 02:18 PM   #128
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
So better off starting from scratch.
Or wait...
2012 WRX HB w/mudflaps yo!
 Old 01-05-2012, 02:49 PM   #129
Captain
Or cast our own.... but we've been down that road before, hahaha.
So waiting seems like the most likely outcome.
www.permtuning.com
 Old 01-05-2012, 03:14 PM   #130
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Re-sell on ebay before shit goes down in value. lol
 Old 01-05-2012, 03:42 PM   #131
Captain
Hahahaha... no shit. I just posted it on mazda3forum.... i'll take some compliance pics tonight and whore it out in the ford world too.
www.permtuning.com
 Old 01-05-2012, 05:09 PM   #132
mason's Avatar
Posts: 946   (View Stats)
OK COOL, now we know. sell it! i hope you dont lose anything.
SD manni is looking really sweet!
The Following 2 Users Say Thank You to mason For This Useful Post:
Cataphract_40 (01-05-2012), djuosnteisn (01-05-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/cosworth-godspeed-intake-manifolds-100523/
Cosworth Inlet Manifold ? Mazda MPS Owners Club This thread Refback 12-30-2012 06:04 AM
Cosworth Inlet Manifold • Mazda MPS Owners Club This thread Refback 11-07-2012 06:35 AM
?????? ????????, ????? Cosworth This thread Refback 03-30-2012 02:23 AM
Mazda MPS Owners Club • View topic - Cosworth Inlet Manifold This thread Refback 02-12-2012 04:08 AM
Mazda MPS Owners Club • View topic - Cosworth Inlet Manifold This thread Refback 01-06-2012 03:20 PM
godspeed ewg turd burglar MazdaSpeed 3/6 - Big Turbo Builds 6 06-23-2010 10:29 AM
intake manifolds... bombdotcom MazdaSpeed 3/6 - Turbo Induction 31 01-30-2009 12:26 PM
Intake manifolds?? steedspeed MazdaSpeed 3/6 - Turbo Induction 74 10-25-2008 08:00 AM
manifolds?!?! Grim Mazdaspeed3/6 General Discussion 136 09-13-2008 11:47 AM
Page generated in 0.35182 seconds with 27 queries
