 Old 08-27-2012, 03:12 AM   #1
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Default Cpe exhaust mani with the Tial flange
Thinking of a Gtx3071 with the 1.06AR Tial housing, it should be good for around 600hp @ 33psi.
I am curious about the fitment and overall impressions from someone who actually has the cpe mani and tial housing.
2006 Mazdaspeed 6
 Old 08-27-2012, 03:36 AM   #2
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
@Celestspeed3 will be rocking it.
Not sure if he's got it on his stock block yet, or if he's waiting for his built motor to be finished.
"Exclusivity" - CP-enis
Demodded.
The Seals
06Speed6 (08-27-2012)
 Old 08-27-2012, 03:52 AM   #3
Speeeeeed
06Speed6's Avatar
Thanks, I knee at least one person had to have it. Its expensive but its a sick combo.
2006 Mazdaspeed 6
 Old 08-27-2012, 04:28 AM   #4
Tokay444's Avatar
Groans: 793
I know is a nig to install.
Demodded.
The Seals
 Old 08-27-2012, 09:34 AM   #5
Speeeeeed
06Speed6's Avatar
Yeah that is what I hear.
2006 Mazdaspeed 6
 Old 08-27-2012, 09:36 AM   #6
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
I doubt the gtx71 flows enough for 600hp. You might want to look into the gtx3076.
07 MS3
The original Genpoo Hater
 Old 08-27-2012, 09:52 AM   #7
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
@Realgib3 ran the 3076 with 1.06 for a bit until he blew.
 Old 08-27-2012, 10:09 AM   #8
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
Myself and Fobio will be running the same setup. CPE Tial with GTX3076's with 0.82 housings.
Fobio's car should be ready in a few weeks.
Fueled by the haters.
Celestspeed3 is offline   Reply With Quote
The Following User Says Thank You to Celestspeed3 For This Useful Post:
Fobio (08-27-2012)
 Old 08-27-2012, 10:42 AM   #9
Speeeeeed
06Speed6's Avatar
Nice so at least someone has bought it, has no one actually installed it yet?
2006 Mazdaspeed 6
 Old 08-27-2012, 10:48 AM   #10
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
Marcus, the tial flange mani will be pretty easy to install on your 6. The hard part of the install on a 3 is getting the mani past the firewall and motor but the 6's have a bit more room there. Also on the mazda flange its a bitch to get the turbo studs and nuts on but with the tial flange that is not an issue.
Murdered out 2007 speed3 GT with navi.
mtnrunner is offline   Reply With Quote
The Following User Says Thank You to mtnrunner For This Useful Post:
 Old 08-27-2012, 10:58 AM   #11
Speeeeeed
06Speed6's Avatar
Thats what I wanted to know, now does anyone know if the ATP vband dp fits or do I need a custom dp?
2006 Mazdaspeed 6
 Old 08-27-2012, 11:05 AM   #12
ill be running this setup in the fall.......ATP DP def does not mate up
 Old 08-27-2012, 11:23 AM   #13
Wasnt the next step for CPe to make compatible downpipes?
 Old 08-27-2012, 12:04 PM   #14
Grumpyjap's Avatar
Posts: 1,839   (View Stats)
They're just about in production
The Following 2 Users Say Thank You to Grumpyjap For This Useful Post:
06Speed6 (08-27-2012), mazdafreak (08-27-2012)
 Old 08-27-2012, 04:23 PM   #15
Tokay444's Avatar
Groans: 793
How could they NOT have been released at the same time?
Demodded.
The Seals
 Old 08-27-2012, 05:31 PM   #16
Realgib3's Avatar
Posts: 2,443   (View Stats)
Yes this setup will work and that mani is easy to install (on a 3 at least) with the Tial flange. I actually never got to run the 1.06 with though because my motor blew the day the parts came in lol. The entire setup is on a local genpu and works great though. Good response and power, though he's on very low boost, not really pushing the turbo at all.
WITH THAT SAID...
If you're already going to have to go custom DP and Cp-e mani, I would absolutely suggest a new Precision 5858 CEA .82 vband in/out hotside. It will easily outflow the gtx and have just as good response.
After running a gtx, then a pte, I'm amazed at how well the pte's perform. Plus, waaaay cheaper and no need to run coolant to the turbo which is really nice.
The GTX route would cost like $2300 and the 5858 would be ~$2000 with the Cp-e mani...
The Following 4 Users Say Thank You to Realgib3 For This Useful Post:
06Speed6 (08-27-2012), atvfreek (08-27-2012), Fobio (08-27-2012), Tokay444 (08-27-2012)
 Old 08-27-2012, 05:42 PM   #17
Speeeeeed
06Speed6's Avatar
I want a water cooled turbo, oil cooled turbos are a pain.
2006 Mazdaspeed 6
Tokay444 (08-28-2012)
PG mani w/ Tial 44mm EWG (Thanks Whoosh) yoichi MazdaSpeed 6 - Engine, Transmission & Driveline 22 12-11-2008 02:43 PM
Page generated in 0.36156 seconds with 29 queries
