 Old 01-22-2009, 12:40 AM   #1
bombdotcom's Avatar
Posts: 816   (View Stats)
bombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the world
Groaned at 40 Times in 20 Posts
Default crank case breather filter
hey i was wodnering about gettin a breather filter for the crankcase...if im not mistaken i think whoosh has one,
what are the pros and cons to it?
something like this... K&N Crankcase Breather Filter (EVO/DSM) - Modern Automotive Performance
thanks guys
(RIP) 08' MS3---MODS:COBB AP- COBB SRI AND TIP- COBB RSB- COBB KNOB- CP-E TMIC- LIMITED EDITION HKS BOV- CORKSPORT DP AND TP- TRZ REARMOUNT- MD OCC- PTP IM COOLER KIT- COSWORTH BSD- EIBACH PROKIT- TWM SHIFTER BUSHINGS- JBR SHORT SHIFT KIT-
13' CWP MS3
bombdotcom is offline   Reply With Quote
 Old 01-22-2009, 05:08 AM   #2
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
that would be the valve cover breather filter
 Old 01-22-2009, 06:57 AM   #3
pidass's Avatar
Posts: 347   (View Stats)
pidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the world
what does this accomplish?
07 MS3 GT w/Nav + Mods
pidass is offline   Reply With Quote
 Old 01-22-2009, 10:13 AM   #4
mdogg's Avatar
Posts: 841   (View Stats)
mdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the world
Groans: 86
Groaned at 36 Times in 25 Posts
It disconnects the valve cover (potential source of oil) from the intake/inlet.
L76-powered
mdogg is offline   Reply With Quote
 Old 01-22-2009, 10:32 AM   #5
On some MAF cars, its also notorious for pulling in unmetered air, causing you to lean out a bit.
 Old 01-22-2009, 10:43 AM   #6
DaleNixon's Avatar
Posts: 2,079   (View Stats)
DaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the world
Groans: 91
A nice counter to the rich condition from running a BOV VTA!
Gay car #1: 2001 Miata (Gay White)
Gay car #2: 2011 Mazda 2 (Gay Blue)
DaleNixon is offline   Reply With Quote
 Old 01-22-2009, 10:43 AM   #7
MTuning's Avatar
Posts: 362   (View Stats)
MTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond repute
Groaned at 16 Times in 8 Posts
if you are venting the crankcase than it would be beneficial. you probably wont be using a breather filter to accomplish this task though.
MTuning is offline   Reply With Quote
 Old 01-22-2009, 10:47 AM   #8
mdogg's Avatar
Groans: 86
An open breather filter most certainly vents the air/pressure from the valve cover, I'm not sure I understand your comment.
L76-powered
 Old 01-22-2009, 11:07 AM   #9
MTuning's Avatar
peace out
 Old 01-22-2009, 11:24 AM   #10
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
majority of the turbulence occur in the bottom end. too much will cause blow by and increase engine temp which will wear/tear components. the valve cover provides poor air flow due to components acting as a bottle neck. As the valve cover vents, the block is still creating these turbulence. I'm not saying it won't vent from the valve cover but its far better tapping the source. too much pressure with the bottle necks will cause problems. this is especially true in FI vehicles. i'm pretty sure a few members had this problem already.
and if you were pointing out the breather filter..i just meant i would use an open CC on the block instead of a breather filter.
if you use an open OCC on the block of this car vs. using vacuum from the IM to pull "the nasty".....you will be the one with issues
2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008)
2008 Caliber SRT4 / 11.8 @ 120
whoosh@Realtune is offline   Reply With Quote
 Old 01-22-2009, 11:38 AM   #11
MTuning's Avatar
peace out
 Old 01-22-2009, 11:44 AM   #12
i was merely elaborating for mdogg's breather question. I do not have a solution for this on the MZR yet. This has been my solution on my past builds to prevent turbulence when i turn up boost. i know 'someone' has done the OCC. i know there was a problem. i'm not going to get into that because my knowledge on the MZR is not up to par with my other cars. This motor seems to be very picky.
do you have time to drop some knowledge on me?
my set up isn't for everyone but has been proven to work
on the block
PCV > to a baffled/filtering media OCC > to an addtl. OEM PCV > to the IM
the valve cover - remove baffle from under side / enlarge hole in back of valve cover / 3/8"NPT tap / 3/8" NPT to -10am 90 degree fitting to 5/8" hose > vented OCC
I added an additional -10 on the valve cover for addtl breathing under high boost but isn't mandatory
if you are overly concerned with the open valve cover, you could follow the same as stated above but add another baffled/filtering media OCC between the enlarged valve cover port to the turbo inlet.
I think one MS3 owner on this site did just that but didn't open up the pin hole vents on the underside of the valve cover which is the key to improved venting
I've done this valve cover mod for a few members and am currently doing it for an MS6 owner in the shop
 Old 01-22-2009, 12:09 PM   #13
phantom3's Avatar
Posts: 1,223   (View Stats)
Groans: 190
I don't get it... what's the problem with plugging the IM and running a OCC VTA from the block. I'm not educated on this, but i don't see how that could cause a problem...
 Old 01-22-2009, 12:34 PM   #14
Deadman's Avatar
Posts: 868   (View Stats)
Deadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the world
Groaned at 31 Times in 16 Posts
my setup is exactly as ron stated. Works great.
Deadman is offline   Reply With Quote
 Old 01-22-2009, 02:04 PM   #15
bova's Avatar
Groans: 45
the problem is the vacuum is needed to pull the gunk of the crankcase. if you plug the manifold you won't have the vacuum on the crankcase and all that gunk just sits in there and will begin to cause some major prolems for you.
 Old 01-22-2009, 02:09 PM   #16
phantom3's Avatar
Groans: 190
by gunk you mean sludge from oil and other debris? If this is the case then why are VTA OCC's run on other cars with out problems? I ran one on my 300zxTT for 3 yrs with no issues? What is it about the MZR DISI that causes problems with this setup?
 Old 01-22-2009, 02:25 PM   #17
bova's Avatar
Groans: 45
i dont have an exact answer i'm just telling you what i know and that if you plan on doing it that way be prepared for hte consequences. maybe whoosh or someone else can chime in.
 Old 01-22-2009, 03:58 PM   #18
MTuning's Avatar
peace out
 Old 01-22-2009, 05:44 PM   #19
bova's Avatar
Groans: 45
because the valve cover does not require that vacuum to evacuate the crankcase. i dont' know if mazda new about all the crap that gets sucked through there, but what you should know is their pcv system sucks and is lousy, you need the vacuum to open the pcv valve they have in place i think. either way there was a guy who plugged the intake manifold and ran a vented occ off the block and he said it started running badly and then he blew his motor there shortly after.
The Following User Says Thank You to bova For This Useful Post:
whoosh@Realtune (01-22-2009)
 Old 01-22-2009, 07:28 PM   #20
phantom3's Avatar
Groans: 190
I think that there may have been more to his motor poping than just an OCC. DISI aside, everything from the top of the pistons down is essentially the same as every other combustion engine.
The reason for the PCV is to vent blow by gasses that get by the ring and into the crank case.
Emission standards state that the gasses must be re-burned (sent through the IM), hence the PCV system. Now the gasses that leak down are only a small percent of what is being produced in the combustion chamber. I can't see that small percent of combustion gas being VTA effecting the over all AFR of the car.
In reality by eliminating the gasses and oil (Which is the real reason for a OCC) from re-entering the IM we are providing a more stable combustion mixture with a stable octane. You don't even need the OCC when VTA except for catching the oil. the gasses are still being VTA which is the same as the breather filter.
The only VTA system that i could see affecting the AFR of the car would be it the valve cover was VTA. due to the fact that under either boost or vacuum condition metered air is going to be released or introduced through the breather filter/OCC. I don't think the real problem here is the crank case.... I believe it to be the VC.
I believe the Crank case should be VTA with an OCC (just so the oil is contained and not leaking everywhere). and the valve cover should connected to the IM with some sort of OCC in between. This would create a dual OCC system which i imagine, most people don't want. That may be why people use 1 OCC for both systems. Less plumbing and only 1 OCC.
Now I have not looked at the PCV system on the MS3 yet, (due to the fact that its currently -24*C outside) so i may have the plumbing for the stock system mixed up in my head. But hey... It makes sense in my head.
 Old 01-22-2009, 07:35 PM   #21
bova's Avatar
Groans: 45
ok well go ahead do it then
if you connect the valve cover to the intake manifold you are asking for more trouble and should just stop now.
 Old 01-22-2009, 07:39 PM   #22
Deadman's Avatar
just run it how whoosh and bova explained... exactly how i have it.
end of story.
 Old 01-22-2009, 09:18 PM   #23
phantom3's Avatar
Groans: 190
I'm just trying to understand "why". That`s all.
 Old 01-23-2009, 05:38 AM   #24
bova's Avatar
Groans: 45
because it wasn't designed to hook the valve cover up to the intake manifold. you do that then you'll end up pressurizing the valve cover when you are in boost unless you run another pcv and thats just dumb. the valve cover draws in air for the crankcase as well as vents.
 Old 01-23-2009, 09:31 PM   #25
bombdotcom's Avatar
hey whoosh any chance u can compile a how to with pics for the valve cover mods and what not. i kno how to do the occ but not what youre talking about.
13' CWP MS3
 Old 01-23-2009, 10:38 PM   #26
builthatch's Avatar
Posts: 616   (View Stats)
builthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond repute
guys/girls, i have some threads up discussing this pretty in-depth. i will find them later, but they are on this forum if you want to l00k.
the long and the short of it is....
the valve cover to intake tube connection can only use a sealed can because of the MAF. wh00sh evidently has a vented setup, but this is a quote of mine from another forum thread about that exact subject-
Originally Posted by builthatch View Post
hose from valve cover to intake manifold? there is no such thing.
boost won't "pressurize the valvecover" (your phrase) if the valve cover is connected to the pre-turbo intake tube. that is impossible.
i guess i should have explained i know 100% how PCV systems work. i think that you might have assumed some things from my last post without completely understanding what i wrote....
i appreciate the help though.
so, assuming i know 100% how a PCV system works, which i do.
take what i asked specifically and see if you or anyone can explain what is happening.
under boost, the PCV closes...the PCV runs from the intake manifold to the block, lol. ok, so the PCV is closed. that means that there is no place for the crankcase pressure to go EXCEPT through the top of the engine now, the valve cover-to-intake tube hose. this spot on the intake tube is after the MAF, but before the turbo.
we know that when the engine is under vacuum, the PCV is opened in various degrees and crankcase vapors are going from the block, through the PCV, into the intake manifold.
when this is occuring, the valve cover-to-intake tube is pulling fresh air from the intake tube. it's a cycle.
ok.
that SAME spot that was previously supplying the crankcase with fresh air.
when the engine is under boost, that line is now the only exit for crankcase pressure because remember the PCV to IM connection is now a no-go, as the PCV is seeing boost and sealing off the block. so now the former air supply line at the valve cover from the intake tube becomes an exit line for crankcase stuff. the valve cover is baffled for a few reasons, and one of them is to prevent actual oil from going into the intake tube during this condition, but of course that doesn't work well. that is why these setups typically end up with oil in the intake tract BEFORE the turbo.
so, the solution for the valve cover issue is...
to run a line from the valve cover to a vented can. this way, under boost, the sole exit available ends up putting junk into the vented can and not the intake tube. also, when the engine is under vacuum and the lower PCV to IM system is working, the vent on the can allows the valve cover to have an air supply like it formerly did, albeit not from the intake tube any longer.
now HERE is my problem, lol.....
the line that you connected to the vented can....
that line WAS going to a spot on the intake tube after the MAF. like, right after it.
if i leave that spot open, obviously metered air that passed the MAF will be going out of that hole to the underhood area.
ok, so i cap it.
well, capping it causes the ECU to wonder why the bit of metered air that was supplying the valve cover with fresh METERED air under vacuum as described above is now not supplying the valve cover with air but in fact going into the turbo now, to be compressed enroute to the combustion process.
i know this because the fuel trims change automatically when this area is capped. that is because the ECU is seeing more air enter the turbo system now, esp under vacuum conditions when it previously was supplying the crankcase.
what is going on there? i think this might be over the heads of alot of people. i'm going to consult some of the more respected technical people out there like Jeff Evans and Mase, but i'd like to know exactly how this could be accomplished on modern MAF cars without issues because i know the change is showing issues on what i'm working with.
ok, so re: the bottom portion-
the bottom connection (crankcase/PCV connection) IMO can use a vented can. i don't believe that the IM needs to pull anything. crankcase pressures will evacuate themselves pretty effectively. the only reason PCV systems are routed to the IM in the first place is because we can't do what they used to do and dump it onto the road while driving. the crank case vapors, etc are pulled into the IM, burned up, and the cat handles it at the end.
dadasracecar or something had this vented type setup and claimed nothing ever showed up in the can, and then grenaded his engine, but i think the two are not related.
if worse comes to worse, just run the common sealed can setup that cobb details in their accessport PDF. you'll be environmentally friendly, and if you have media in the can, you'll do a decent job of preventing alot of the junk from going into the IM.
неприкасаемый / '08 Mazdaspeed3 GT / '07 Si sedan / END OF AN ERA / 6'4", 333lbs
***week old AP FOR SALE!!!! click here*** SOLD SOLD SOLD
builthatch is offline   Reply With Quote
The Following User Says Thank You to builthatch For This Useful Post:
phantom3 (01-24-2009)
 Old 01-24-2009, 09:15 AM   #27
mdogg's Avatar
Groans: 86
what do you think you will gain from venting the PCV rather than using a closed CC? I sure wouldn't want to be the 2nd person to try (given what happened the first time).
L76-powered
 Old 01-24-2009, 10:06 AM   #28
builthatch's Avatar
the perf advantage is that the vapors from the crankcase will not get into the intake manifold what so ever, so they won't pollute the intake charge. that shit is nasty- it dilutes the charge with oily garbage and lowers the effective octane rating of the fuel. however, not to make this too complicated, but, i'm curious how detrimential it can be on DI vs. port injected, since the fuel doesn't get that much of a chance to interface with the garbage like it does on a port injected car....anyway, the bottom line is, no matter what, it pollutes the intake charge.
the disadvantage is that is pollutes the environment even more.
 Old 01-24-2009, 06:53 PM   #29
phantom3's Avatar
Groans: 190
Thank you. this is exactly what i was trying to say along with you other post, but i guess I'm not that great with words... lol.
 Old 01-24-2009, 10:36 PM   #30
bova's Avatar
Groans: 45
ok so if dadasracecar ran the vented can and nothing ever collected in it that just goes to show you that all the shit we are getting in our closed catch cans is not being pulled out of the crankcase and just being backed up inside there.
 Old 01-25-2009, 11:08 AM   #31
builthatch's Avatar
3 things come to mind about his case:
how long did he run that setup for, in terms of time for stuff to collect?
and when the can is vented, there is a very easy route for most things to escape the can, especially during temperate changes, etc. on a closed system, only when the car is running, and under vacuum, does anything escape. that leaves alot of opportunity for things to appear in the can due to condensation, etc. most of that crap that people are seeing in the cans is water, water that by default sort of emulsifies with some of the junk in the vapors (fuel, mostly oil) so it won't necessarily evaporate easily or be pulled in to the IM. but, if the can is vented, the liquid will have very little chance to collect and emulsify like that. this is evident by standing near an engine with a vented can and also looking at the filter atop these cans....the filter gets greasy and the car stinks when it's running because the stuff eminating from the filter.
lastly- what else did he have on his car to potentially contribute to it grenading? there were a ton of variables there.
also remember there are a ton of people all over the world run these vented types of cans aspirating the block, on all engines great and small; our engine from that standpoint is no different. it's DI, yes, but that is about it and is a seperate issue from anything else we are discussing here. from a rotating assemby and crankcase perspective, it's the same as any other engine.
if you are uncomfortable with the idea, a sealed can is DEF better than nothing, but i don't think it's as ideal as a vented can, that's all.
phantom3 (01-25-2009)
 Old 10-17-2017, 11:03 AM   #32
Shottachris's Avatar
Posts: 31   (View Stats)
Shottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these parts
Groaned at 64 Times in 26 Posts
Great knowledge
TopFlightInc! NYC
2011 speed 3 GT daily driver
Mods: big turbo , fuel internals , sure short shifter , forge BOV , FMIC , JBR motor mounts all around , BC coil overs , staggered advan wheels 18 x9.5 25+ offset front 18x 10.5 15+ offset rear , 3in catless down pipe , occ , Custom 3inch intake , Cobb strut bar ,Cobb v3 ,vtcs delete stock intake mani ,
Shottachris is offline   Reply With Quote
The Following 5 Users Say NO Thank You to Shottachris For This Un-useful Post:
5doorsoffury (10-17-2017), Djohns (10-17-2017), Fstrnyou (10-17-2017), JSmith (10-17-2017), Pu Manchu (10-17-2017)
 Old 10-17-2017, 12:42 PM   #33
Djohns's Avatar
Posts: 3,944   (View Stats)
Jesus fucking Christ. 8 year thread bump?? The person you quoted hasn’t even logged on since 2013.
2010 black mica speed3
Soon:built motor
 Old 10-17-2017, 01:47 PM   #34
 Old 10-17-2017, 01:49 PM   #35
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
@shadowms3; this shotta fagot keeps shit posting.
crapatalk it sucks for free
monkey.bones.007 is online now   Reply With Quote
The Following 4 Users Say Thank You to monkey.bones.007 For This Useful Post:
 Old 10-17-2017, 02:01 PM   #36
Djohns's Avatar
I vote for a ban since he’s a douche!!
Soon:built motor
The Following 2 Users Say Thank You to Djohns For This Useful Post:
Fstrnyou (10-17-2017), monkey.bones.007 (10-17-2017)
 Old 10-17-2017, 07:42 PM   #37
Jonb82's Avatar
Posts: 416   (View Stats)
Yo cuz don’t come at me wit dat nagative shit. I got enuf goin on in my lif. My mans told me I’m not man enuf ands I got to be tha botum now. Don’t even talk shit cuz I’m not goin to respond
Sent while probably pooping
Djohns (10-17-2017)
 Old 10-17-2017, 10:20 PM   #38
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Vote to at least temporarily ban
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 10-17-2017, 10:21 PM   #39
Djohns's Avatar
Read his other post and you’ll want him perma banned.
Soon:built motor
monkey.bones.007 (10-18-2017)
 Old 10-17-2017, 10:28 PM   #40
Fstrnyou's Avatar
I've seen his other useless posts...
Other rides:
History:
Breather filter: Good or bad? Hectik1 MazdaSpeed 3 - Engine, Transmission & Driveline 37 02-20-2013 08:24 PM
Oil Filter Adapter Rcimp MazdaSpeed 3 - Engine, Transmission & Driveline 2 11-17-2008 05:01 AM
Notching the 2.3L DISI Crank and Timing Gear. y2kc0wb0y MazdaSpeed 3 - Engine, Transmission & Driveline 35 10-19-2008 04:35 PM
Air Filter MS3-oholic MazdaSpeed 3/6 - Turbo Induction 4 05-19-2008 11:51 AM
Eton Arc FR250 3-in-1 Crank Radio, Flashlight and Cell Phone Charger - $31.99 + Free Shipping Haltech Hot Deals Section 0 03-27-2008 01:10 PM
Page generated in 0.57960 seconds with 36 queries
