 Old 02-21-2016, 01:37 PM   #1
wes3id's Avatar
Posts: 611   (View Stats)
Default custom coolant drain line
So i was installing a BNR S3 on my MS6 and wanted to do braided steel lines for better heat protection. little did i know that the coolant drain line is tapered (going from 1/2" from the TC to 3/8" at the turbo. i picked up some brass fittings at lowes and made this line....not very pretty. does anyone see a problem with this functioning correctly? the stock line was s shaped, so i don't see why a 90* wouldn't work on a drain line
wes3id is offline   Reply With Quote
precision turbo oil feed/drain/coolant dooderek MazdaSpeed 3/6 - Turbo Induction 5 02-02-2012 11:03 AM
K04 oil feed line & oil drain line NJSPEED3 MazdaSpeed 3/6 - Turbo Induction 12 09-14-2009 10:46 AM
Page generated in 0.22043 seconds with 22 queries
