![]() Join Date: Mar 2012 Location: Ottawa, Ontario, Canada
Rep Power: 0 ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score Thanks |
![]() Join Date: Nov 2014 Location: Stuart, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 303
| Not Ranked : 0 score Turbo will fit but will not perform the same. You will lose your top end. You need a K04 ending in 881 or 882.
__________________ 08 Speed 3 GT, Cosmic Blue Installed - BNR s3, 3 BAR MAP, Cobb 3 Port EBCS, HTP 3" Intake, CS TMIC, CNT Catback Exhaust, Manzo TP, CS and JBR Hoses, TRZ RMM, Autotech HPFP Internals, Forge v1 BPV, Cobb AP v2, Nitto NT555 225/40/18 Tires, Block8Head Gauge Pod, Corksport Steering Wheel, NGK 6510, Step Colder Plugs, JBR Short Shifter, JBR Shift Bushings, Rallyarmor Flaps, Corn Tuned by Freek Installing Next - EBC Yellow Stuff Pads, JBR VTA OCC Next to Buy - Suspension stuff, Brake lines and Rotors, Relentless Manifold |
| Not Ranked : 0 score A decent bit, the cx7 turbo has a smaller turbine so it spools hard early then peters out. I don't have numbers but trust be you don't want a cx7 turbo in your speed. You should donate and go VIP. You will get access to the for sale section and mazdaspeed K04's pop up often and for pretty cheap.
(Thread Starter) | Not Ranked : 0 score OK thanks
| Not Ranked : 0 score It will fit. The k04 turbos on the speed 6, speed 3 (both gens) and the cx7 are interchangeable. The cx7 turbo is smaller as stated but the 6 and 3's are the same. The gen 2 turbo will most likely be a 882 which i believe is the one with better seals. The 6 and earlier 3's have a 881.
| The Following User Says Thank You to fasteddie128 For This Useful Post: | chochobeelai (10-29-2015) |
| Our White Paper for the Mazdaspeed Replacement Turbocharger | CorkSport | CorkSport | 0 | 05-20-2015 12:50 PM |
| Strange turbocharger behaviour | EmPeEs6 | MazdaSpeed 3/6 - ECU Computer Tuning | 25 | 11-21-2013 05:26 AM |
| Rumormill: Next Subaru WRX to use electric turbocharger? | Haltech | Automotive News | 0 | 05-03-2012 01:00 PM |
