 Old 07-29-2017, 10:20 AM   #1
Speed3Pedro's Avatar
Posts: 111   (View Stats)
Speed3Pedro is a jewel in the roughSpeed3Pedro is a jewel in the roughSpeed3Pedro is a jewel in the rough
Groaned at 8 Times in 4 Posts
Default Defective turbo or wastegate?
So I got my BNR S3 installed about 2 months ago. After the base tune from Freek, I was running only 8psi so he had me add more preload. 8psi turned into 13psi after 6 turns of the wastegate actuator rod. After that, he still had me add more preload because I still wasn't hitting the correct numbers. 13psi turned into 16psi. He had me add more preload again, but the rod only allowed two more turns until it was maxed out and its only pushing 17psi when Freek said I should be seeing close to 22psi. Not only that, but my boost is fluctuating in the higher RPMs. Here are the 3 3rd gear and 1 4th gear wot logs I sent to Freek and you can see it skip sometimes even from 17psi to like 14psi. Any idea what could be going on? Tested for boost leaks already and had none. datalog7_3rdgearwot_C.csv
datalog8_3rdgearwot_C.csv
datalog9_3rdgearwot_C.csv
datalog10_4thgearwot_C.csv
Speed3Pedro is offline   Reply With Quote
 Old 07-29-2017, 10:59 AM   #2
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
Contact BNR. Maybe it's a bad WGA.
2018 Audi RS3
2007 Acura TSX 6MT
Speed3Pedro (07-29-2017)
Any wastegate options that will fit ms6 stock turbo!? Ms6ownersblike Mazdaspeed3/6 General Discussion 7 04-06-2016 08:21 PM
Feeling like an idiot, need help with my turbo/ebcs/ wastegate hookup Zbrit00x Gen2 MS3 General Discussion 5 07-17-2012 03:32 PM
For You BT/Turbo Noobs - I haz Wastegate? helmetface MazdaSpeed 3/6 - Turbo Induction 9 09-20-2011 06:20 PM
Page generated in 0.23757 seconds with 22 queries
