 Old 01-12-2009, 05:54 PM   #1
booya620's Avatar
Posts: 697   (View Stats)
booya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the world
hmmm.. I wonder if a difference can be seen the forge spring shim combos, time to do some logs. nice article.
2008 Sunlight Silver MAZDASPEED 3
[SIGPIC][/SIGPIC] MODS: COBB SF SRI, Mazdaspeed CBE 3", Street Unit 62a Rear Motor Mount, Street Unit Shifter Bushings, COBB Shift Weight, Forge Bypass Valve (Blue Shim).
booya620 is offline   Reply With Quote
 Old 01-12-2009, 05:59 PM   #2
See, about time Ming started acting Asian!
aaronc7 (01-12-2009)
 Old 01-12-2009, 08:35 PM   #3
sk33ny's Avatar
Posts: 26   (View Stats)
sk33ny has a spectacular aura aboutsk33ny has a spectacular aura aboutsk33ny has a spectacular aura about
Great read, thanks for sharing your information.
sk33ny is offline   Reply With Quote
The Following User Says Thank You to sk33ny For This Useful Post:
Sacrilicious (01-13-2009)
 Old 01-12-2009, 08:16 PM   #4
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
if you see problems with running too tight, it will be with the red spring + 2 shims. results will vary, of course, but red spring + 2 shims is waaaay tighter than it needs to be for partial throttle operations.
if you use the blue spring + 0/1/2 shims or red spring + 0 shims, the LTFTs seem to be pretty damn well behaved.
The Following User Says Thank You to Sacrilicious For This Useful Post:
usmc_adams (05-30-2010)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/discussion-how-bypass-valves-can-affect-ltfts-18962/
Forge BPV and boost leak question - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-27-2014 04:51 AM
Turbosmart dual port bov? - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 06-28-2012 05:28 AM
Bypass valve small points (+ a boom theory!) - Page 2 This thread Refback 11-30-2011 06:29 AM
Bypass valve small points (+ a boom theory!) This thread Pingback 08-30-2011 04:02 AM
From out of no where SURGE! - Page 3 - MN Mazda Forums This thread Refback 06-17-2009 10:18 AM
Super lean at idle, AFR super high. - Mazda6 / Atenza This thread Refback 01-13-2009 02:21 PM
Factory alarm bypass xcoldricex MazdaSpeed 3/6 - Car Audio & Electronics 1 01-12-2009 07:53 PM
The 2nd O2 sensor does affect AFR after-all. LBV MazdaSpeed 3/6 - ECU Computer Tuning 53 01-09-2009 04:25 PM
LTFTs and Winter MidwestSpeed3 MazdaSpeed 3/6 - ECU Computer Tuning 6 11-12-2008 09:34 AM
Feds investigate valves in Ford tires Haltech Automotive News 0 10-21-2008 12:20 PM
Page generated in 0.32320 seconds with 25 queries
