 Old 01-13-2009, 09:38 AM   #1
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
Originally Posted by 08_ms3_gt View Post
i'm running the forge BPV (blue spring, no shims) + HKS SRI and get the occassional pop or two.
i installed an AP recently, and, with V1.03 93oct Stage1+SF my AFR's are reading ~14.7 at cruise and 11.8 at WOT. occassional cuts that might be due to the cold (15*F) but future logs will hopefully diagnose that issue.
my LTFT is generally +or- 8%. my most recent was -6% when on the gas, +8% when off. is this normal? i have read that give or take 8% is okay but obviously 0% is ideal.
+/- 8%? the LTFT should stay about constant after your ECU learns it. since there's 4 different LTFTs, you might see different LTFTs flash by on the screen as you vary your throttle position, but your heavy throttle LTFTs should stay about constant after it's been fully learned. if your heavy throttle LTFTs are varying from -8% to 8%, then something whack is going on with your HKS SRI. usually, it means that the air is too turbulent over the MAF sensor and is confusing the hell out of your ECU, because the thing it's counting on is that the fuel trims will stay about constant under similar throttle conditions.
your WOT AFRs look correct for an AP...have you checked your fuel pressures?
 Old 01-13-2009, 10:00 AM   #2
DaleNixon's Avatar
Posts: 2,079   (View Stats)
DaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the world
Groans: 91
With my Cobb SRI/Forge combo I get +7.6 at cruise and +14.2 under heavy acceleration/WOT. I've already sent logs to Cobb and await their answer as to what could be going on.
My AFR's are fine. Also, no backfires and the knock warning isn't too frequent.
Gay car #1: 2001 Miata (Gay White)
Gay car #2: 2011 Mazda 2 (Gay Blue)
DaleNixon is offline   Reply With Quote
 Old 01-13-2009, 11:26 AM   #3
pewpew
if you're not running rich, then the LTFTs are just where they need to be to account for the way the air flows in the SRI. if you want them adjusted closer to 0, christian can very easily take care of that for you with just a few changes. i had this same problem, and it took christian just one try to drop them from ~14% to <5%. keep in mind, that this is different from the BPV problem, because it simply means that your baseline LTFTs are rather high (which is nothing to panic about)...the BPV problem i'm referring to happens when your BPV artificially takes whatever baseline LTFT you should have been running at and then adds like 5-10% to it...causing you to run pig rich at WOT and bang bang out the tailpipe...=/
Originally Posted by Deadman View Post
im runing hks in vta, currently with like 35 miles on the reflash my ltfts are at:
idle - +16.4%
cruising - -.8%_-2.3%
WOT - -.8%
Whats the good/bad in this?! :|
well, simply looking at the LTFTs doesn't necessarily tell us if you are having a problem. do you run richer than you expect at WOT? does your car backfire on shifts? if not, then i wouldn't worry about it, but i suspect that you DO backfire on shifts because you're venting to air (makes you run really freakin rich on shifts).
Originally Posted by Phantom View Post
I am running a Turbosmart Compact BOV. I will check the AFR's this week and see what I can find out.
ya, if you're running hybrid mode on the turbosmart, you're almost guaranteed to run too rich on shifts (pops and backfires). VTA is guaranteed to run richer than BPV, because you're dumping metered air to the atmosphere...less air, same amount for fuel = rich as a pig. you can either leave it like this and make sure the spring tension is adjusted so that you at least run normally at WOT and deal with the fact that you will pop and backfire on shifts, or you can go conservative and put the valve in full recirc so that it runs as smoothly as stock (clean AFRs and no pops/backfires on shifts...not moreso than stock, anyways).
The Following User Says Thank You to Sacrilicious For This Useful Post:
knarfies (04-10-2012)
 Old 01-15-2009, 01:56 PM   #4
Phantom's Avatar
Posts: 313   (View Stats)
Phantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud of
I am currently running my Turbo Smart in full recirc. The popping I was getting I think is from a spring being too tight. Seems bit better now. Still need to work on the spring tension
Phantom is offline   Reply With Quote
 Old 01-15-2009, 03:01 PM   #5
pewpew
awesome... ya, you just need the spring to be a little bit tighter than it absolutely needs to be in order to hold boost. you don't want to go much farther than that, because you will run into trouble from its being too tight.
 Old 01-13-2009, 11:39 AM   #6
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world
well, the LTFT does seem constant for a given operating condition, but those separate values are different. i'll have to log to figure out specific values, but i saw 8% when off the throttle/engine braking.
i've been wondering about the air turbulence with my SRI - BUT supposedly the air filter itself acts as a straightener. if my LTFT values remain steady then i won't worry as much about it.
i've looked a bit at the fuel pressure and it looks about right, holding above 1600PSI and hovering around 1700PSI at WOT. no decreases upon running WOT for a couple thousand RPM's. but i haven't done any logs yet, which i would probably need to diagnose the cut - boost, fuel pressure, possibly IAT, etc.
08_ms3_gt is offline   Reply With Quote
 Old 01-13-2009, 11:46 AM   #7
DaleNixon's Avatar
Groans: 91
Sacrilicious, when Christian helped you was this via the Cobb AP? I am on the stock ECU and do not own an Accessport.
If I didn't have the Dashhawk, I wouldn't even be concerned with this problem as the car runs fantastics. Chris @ Cobb did say that my LTFT's are higher than he'd like to see though.
 Old 01-13-2009, 11:59 AM   #8
pewpew
ok, it's perfectly normal to have 4 distinctly different LTFTs for the 4 operating ranges. as long as each individual LTFT is pretty steady, then that's pretty darn normal. as long as your LTFTs are below 15%, you should be good to go.
here's a common misunderstanding: my LTFTs are 10.0%...that seems high...i must have a problem!
the truth to this matter is that all the LTFT means to you is that due to the way the air flows in your intake, the way fuel injectors respond to your ECU's command to inject X amount of fuel; the system has to compensate by Y% after all these sensor/actuator inaccuracies are taken into account to achieve the AFR that it wanted to get. as long as you allow the LTFTs to develop normally after an ECU reset, you will be able to safely do WOT pulls.
where a large baseline LTFT at WOT can be scary: if you have a baseline LTFT of 15%, and you go and reset your ECU and then you don't bother taking the time to relearning your LTFTs before WOTing the shit outta your car, you will now be missing 15% of the necessary fuel to achieve a commanded AFR of say, 12.0:1. if THAT is the case, then you will run way leaner than 12.0:1 and probably end up in like the upper 12s or even 13s...that is pretty scary if you keep blasting it like that...=/ but, if you allow the LTFT to learn itself back up to 15% after an ECU reset, then it will still run perfectly normally and get you that 12.0:1 AFR that your ECU commanded.
long story short: it's nice to be able to tune your LTFTs all down to 0%, because that allows you to WOT without relearning fuel trims after an ECU reset, but even if your baseline LTFTs are rather high (10-15%), as long as you take the time to relearn the LTFTs after an ECU reset, you will have no problems running your car normally.
The Following 4 Users Say Thank You to Sacrilicious For This Useful Post:
08_ms3_gt (01-13-2009), DaleNixon (01-13-2009), shpankey (03-11-2011), Speed3 Geezer (12-10-2009)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/discussion-how-bypass-valves-can-affect-ltfts-18962/
Forge BPV and boost leak question - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-27-2014 04:51 AM
Turbosmart dual port bov? - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 06-28-2012 05:28 AM
Bypass valve small points (+ a boom theory!) - Page 2 This thread Refback 11-30-2011 06:29 AM
Bypass valve small points (+ a boom theory!) This thread Pingback 08-30-2011 04:02 AM
From out of no where SURGE! - Page 3 - MN Mazda Forums This thread Refback 06-17-2009 10:18 AM
Super lean at idle, AFR super high. - Mazda6 / Atenza This thread Refback 01-13-2009 02:21 PM
Factory alarm bypass xcoldricex MazdaSpeed 3/6 - Car Audio & Electronics 1 01-12-2009 07:53 PM
The 2nd O2 sensor does affect AFR after-all. LBV MazdaSpeed 3/6 - ECU Computer Tuning 53 01-09-2009 04:25 PM
LTFTs and Winter MidwestSpeed3 MazdaSpeed 3/6 - ECU Computer Tuning 6 11-12-2008 09:34 AM
Feds investigate valves in Ford tires Haltech Automotive News 0 10-21-2008 12:20 PM
Page generated in 0.36564 seconds with 25 queries
