| aspiring turbo guru ![]() Join Date: Dec 2008 Location: Minnesota
Rep Power: 240 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 245
| Not Ranked : 0 score
i've been wondering about the air turbulence with my SRI - BUT supposedly the air filter itself acts as a straightener. if my LTFT values remain steady then i won't worry as much about it. i've looked a bit at the fuel pressure and it looks about right, holding above 1600PSI and hovering around 1700PSI at WOT. no decreases upon running WOT for a couple thousand RPM's. but i haven't done any logs yet, which i would probably need to diagnose the cut - boost, fuel pressure, possibly IAT, etc. | |
![]() Join Date: Oct 2008 Location: Western Hemisphere
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
Groans: 91
| Not Ranked : 0 score Sacrilicious, when Christian helped you was this via the Cobb AP? I am on the stock ECU and do not own an Accessport. If I didn't have the Dashhawk, I wouldn't even be concerned with this problem as the car runs fantastics. Chris @ Cobb did say that my LTFT's are higher than he'd like to see though.
__________________ Gay car #1: 2001 Miata (Gay White) Gay car #2: 2011 Mazda 2 (Gay Blue) |
| pewpew ![]() ![]() Join Date: Apr 2008 Location: NoVA
Rep Power: 760 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,124
Groaned at 9 Times in 9 Posts
here's a common misunderstanding: my LTFTs are 10.0%...that seems high...i must have a problem! the truth to this matter is that all the LTFT means to you is that due to the way the air flows in your intake, the way fuel injectors respond to your ECU's command to inject X amount of fuel; the system has to compensate by Y% after all these sensor/actuator inaccuracies are taken into account to achieve the AFR that it wanted to get. as long as you allow the LTFTs to develop normally after an ECU reset, you will be able to safely do WOT pulls. where a large baseline LTFT at WOT can be scary: if you have a baseline LTFT of 15%, and you go and reset your ECU and then you don't bother taking the time to relearning your LTFTs before WOTing the shit outta your car, you will now be missing 15% of the necessary fuel to achieve a commanded AFR of say, 12.0:1. if THAT is the case, then you will run way leaner than 12.0:1 and probably end up in like the upper 12s or even 13s...that is pretty scary if you keep blasting it like that...=/ but, if you allow the LTFT to learn itself back up to 15% after an ECU reset, then it will still run perfectly normally and get you that 12.0:1 AFR that your ECU commanded. long story short: it's nice to be able to tune your LTFTs all down to 0%, because that allows you to WOT without relearning fuel trims after an ECU reset, but even if your baseline LTFTs are rather high (10-15%), as long as you take the time to relearn the LTFTs after an ECU reset, you will have no problems running your car normally. | |
| The Following 4 Users Say Thank You to Sacrilicious For This Useful Post: |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/discussion-how-bypass-valves-can-affect-ltfts-18962/ | ||||
| Forge BPV and boost leak question - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-27-2014 04:51 AM | |
| Turbosmart dual port bov? - 2010 Mazda 3/Mazdaspeed 3 Forums | This thread | Refback | 06-28-2012 05:28 AM | |
| Bypass valve small points (+ a boom theory!) - Page 2 | This thread | Refback | 11-30-2011 06:29 AM | |
| Bypass valve small points (+ a boom theory!) | This thread | Pingback | 08-30-2011 04:02 AM | |
| From out of no where SURGE! - Page 3 - MN Mazda Forums | This thread | Refback | 06-17-2009 10:18 AM | |
| Super lean at idle, AFR super high. - Mazda6 / Atenza | This thread | Refback | 01-13-2009 02:21 PM | |
| Factory alarm bypass | xcoldricex | MazdaSpeed 3/6 - Car Audio & Electronics | 1 | 01-12-2009 07:53 PM |
| The 2nd O2 sensor does affect AFR after-all. | LBV | MazdaSpeed 3/6 - ECU Computer Tuning | 53 | 01-09-2009 04:25 PM |
| LTFTs and Winter | MidwestSpeed3 | MazdaSpeed 3/6 - ECU Computer Tuning | 6 | 11-12-2008 09:34 AM |
| Feds investigate valves in Ford tires | Haltech | Automotive News | 0 | 10-21-2008 12:20 PM |
