 Old 01-04-2016, 05:50 PM   #1
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Originally Posted by Sacrilicious View Post
My hypothesis is that our ECU is programmed to expect a low release point, since the stock BPV has a relatively weak spring holding the valve shut. I think that this stock Release Point is expected to be DURING the operation/learning range of the heavy throttle LTFTs. This is the same LTFT that is used during WOT (Open Loop) operation. When you add an aftermarket BPV which raises the Release Point of the BPV such that it puts it out of the operation/learning range of the heavy throttle LTFTs, which means that the ECU will learn these LTFTs with a fully shut valve (vs the slightly leaking recirc of the stock weak spring), which means that more air would actually get into the engine, making the ECU calculate higher LTFTs, since it sees more air in the system than it's used to (making it add more fuel).
Could this be why people are getting rich throttle tip in conditions in between shifts?
My LTFT's are on point at part throttle/closed loop. But during hard acceleration, in between shifts, as I step back on the gas, and boost builds again, I keep getting a rich throttle tip in condition (10:1) that quickly settles out to my target AFR (11.5:1).
Tweaking the MAF CAL in those specific MAF voltage regions doesn't seem to fix this rich throttle tip in condition.
Is it possible that the ECU dumps fuel during throttle tip in between shifts on purpose to protect the engine? Or is it caused by the after market BPV being set too stiff?
Thanks.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/discussion-how-bypass-valves-can-affect-ltfts-18962/
Forge BPV and boost leak question - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-27-2014 04:51 AM
Turbosmart dual port bov? - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 06-28-2012 05:28 AM
Bypass valve small points (+ a boom theory!) - Page 2 This thread Refback 11-30-2011 06:29 AM
Bypass valve small points (+ a boom theory!) This thread Pingback 08-30-2011 04:02 AM
From out of no where SURGE! - Page 3 - MN Mazda Forums This thread Refback 06-17-2009 10:18 AM
Super lean at idle, AFR super high. - Mazda6 / Atenza This thread Refback 01-13-2009 02:21 PM
Factory alarm bypass xcoldricex MazdaSpeed 3/6 - Car Audio & Electronics 1 01-12-2009 07:53 PM
The 2nd O2 sensor does affect AFR after-all. LBV MazdaSpeed 3/6 - ECU Computer Tuning 53 01-09-2009 04:25 PM
LTFTs and Winter MidwestSpeed3 MazdaSpeed 3/6 - ECU Computer Tuning 6 11-12-2008 09:34 AM
Feds investigate valves in Ford tires Haltech Automotive News 0 10-21-2008 12:20 PM
Page generated in 0.30822 seconds with 22 queries
