 Old 02-25-2009, 09:20 PM   #1
Scatt Nasty's Avatar
Posts: 1,204   (View Stats)
Scatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the world
Groans: 94
Groaned at 43 Times in 33 Posts
Default Do Ambient Temps Effect Boost ?
Hey there just had quick question. Last week here in SV,(5000 Ft. elevation) I was able to hold 20 PSI when the temp was in the low 30-40's... But today It was about 70 degrees and I could barely hit 19 PSI in 2nd and no more than 18 in third. I know nothing is loose. So either A) It's the temp or B) My turbo is starting to go (It has been smoking for about 4 months)
321 HP/348TQ-- 13.940 @ 106 /3kft ASL
Scatt Nasty is offline   Reply With Quote
 Old 02-25-2009, 10:03 PM   #2
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
cold air is more dense, so it is not odd that you will see higher boost levels when it is colder out.
 Old 02-26-2009, 12:00 AM   #3
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
bykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the world
Groans: 38
yes as said cold air is more dense so boost will be higher and you will be running slightly leaner due to more air present. This is PART of the cold weather cut this car gets for some people...it boosts higher and isnt ready for it so it cuts.
bykeryder4life is offline   Reply With Quote
 Old 02-26-2009, 02:30 AM   #4
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
If i dont tweek my MBC for temp changes i can see huge differences. I keep it set at 20psi. If the temp drops below 50 degrees that turns to 25psi real quick !!
TRU-BOOST is offline   Reply With Quote
 Old 02-26-2009, 08:30 AM   #5
bnoon's Avatar
Posts: 1,770   (View Stats)
Our weather is up and down so much in winter, I feel like I'm turning the damn knob every other day on my MBC. With my winter tires I'm only set for about 14 psi right now anyway though... and still spin into 3rd. Dang 205's just give it up to easy.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
 Old 02-26-2009, 01:26 PM   #6
Thermonuclear Skeet
FantasmoNegro's Avatar
Posts: 2,810   (View Stats)
FantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the world
Groans: 188
Groaned at 333 Times in 222 Posts
Maybe I am wrong but I thought that our wastegate regulates boost to a specific number no matter what the temperature is. You may spool up faster but not nessecarily more. Again maybe I am wrong, maybe our cars even alow more boost in the cold due to the less chance of temperature sourced detonation.
El Fantasmo Del Negro
Helicopter Cat LIVES
FantasmoNegro is offline   Reply With Quote
 Old 02-26-2009, 03:50 PM   #7
Groans: 38
the WG does regulate boost, but 18psi of hot air is not the same as 18psi of cold air, the cold one is more densely packed with oxygen atoms so even though the turbo is pushing 18psi and thinks it all good the motor is seeing more air due to it being more densely packed with oxygen so it reads higher boost. Thats a basic- not exact -explanation of how I see it.
 Old 02-26-2009, 04:13 PM   #8
phantom6294's Avatar
Posts: 255   (View Stats)
phantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the world
Interesting... there is a thread here where several people, including me have the exact opposite issue -- the colder it gets, the less boost we see.
Theory that made the most sense (to me) is that the car does not target a boost level but rather targets a specific load. Well, since colder air is denser air, less boost is needed to reach a target load, if in fact that is how the ECU is programmed.
phantom6294 is offline   Reply With Quote
 Old 02-26-2009, 07:50 PM   #9
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Hectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the world
Groaned at 9 Times in 6 Posts
Yeah. I was thinking the same thing. I posted in the other thread too.
I see less boost when cold.
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
Hectik1 is offline   Reply With Quote
 Old 02-26-2009, 08:58 PM   #10
Groans: 38
I spike higher when cold but then it quickly cuts from my fuel pressure dropping and then its lower boost to redline. it is lower boost overall so you guys are right on that....
 Old 02-26-2009, 09:49 PM   #11
Um, 18psi is 18psi.... if the ECU is targeting a boost target and reading boost level from the MAP sensor, 18 psi is 18 psi. Yes, the mass flow will change because colder air is more dense... but 18 psi is 18 psi.
The Following 2 Users Say Thank You to phantom6294 For This Useful Post:
djuosnteisn (02-27-2009), FantasmoNegro (02-27-2009)
 Old 02-26-2009, 10:14 PM   #12
Groans: 38
well thats basically exactly what I meant, I said how whether hot or cold the turbo always pushes the same psi but the motor see's more air. just didnt use correct terms. The mass air flow will be greater due to the increased density while the turbo is doing 18psi.
 Old 02-26-2009, 10:41 PM   #13
TRU-BOOST's Avatar
Even on stock boost control my car always sees more boost in the cold. I can tell you this the ecu sure as hell doesnt use the map sensor to determine boost. I had my map clamp set to 2psi and as long as i used stock boost control, i got stock boost levels. I honestly think the map sensor on this car serves only 2 purposes.... 1 to give the ecu an intake air temp reading ti determine proper fueling, because lets face it the temp at the Maf is uselesa on a turbo car. And 2 to trigger overboost cut.
 Old 02-26-2009, 11:41 PM   #14
wassup61's Avatar
Posts: 1,232   (View Stats)
stock boost controller will hold stock boost until the wastegate is maxed (on catless exhaust only i guess<---my experience) and then it will start to creep like crazy.
All wagon, No traction
 Old 02-27-2009, 06:24 AM   #15
bova's Avatar
Groans: 45
this car basically has 3 different mappings for the throttle which controls boost. it bases it off of requested load, boast air temps, barometric pressure and rpm's. there will be more info on this soon.
The Following User Says Thank You to bova For This Useful Post:
Boost Air Temps/Intake Air Temp Stan-O
Cobb Access Port/Maps
20 05-03-2009 12:55 PM
What effect can a hybrid valve have on a map? builthatch MazdaSpeed 3/6 - ECU Computer Tuning 3 01-19-2009 01:47 PM
Hyundai eyes 'halo' effect from Genesis Haltech Automotive News 0 09-17-2008 08:20 AM
Boost drops FMIC intake temps? kingpin748 MazdaSpeed 3/6 - Turbo Induction 4 07-17-2008 08:57 AM
Page generated in 0.36962 seconds with 28 queries
