Like Tree3Likes
  • 1 Post By Vansquish
  • 1 Post By MD1032
  • 1 Post By monkey.bones.007
 Old 05-28-2017, 05:53 PM   #1
Klapamos's Avatar
Posts: 19   (View Stats)
Klapamos will become famous soon enough
Groaned at 7 Times in 3 Posts
Default Do I need fuel pump internals?
Hey all,
So I'm having my engine rebuilt with forged rods/Pistons and a BNR S1 or S2 turbo. No others mods at this time...will I need an upgraded fuel pump if we turn up the boost a little during the tuning session? Eventually I plan to upgrade the pump internals but not until I upgrade intake, intercooler and maybe add a down pipe. This will be my daily especially during the winter, but I do have a second car.
Klapamos is offline   Reply With Quote
The Following 4 Users Say NO Thank You to Klapamos For This Un-useful Post:
MD1032 (06-01-2017), Swinger13 (05-30-2017), tegxsi (06-01-2017), Vansquish (05-31-2017)
 Old 05-28-2017, 06:25 PM   #2
SpoolinSpeed3..757's Avatar
Posts: 48   (View Stats)
SpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of light
Short answer is yes
Sent from my SM-G930P using Tapatalk
SpoolinSpeed3..757 is offline   Reply With Quote
The Following 2 Users Say Thank You to SpoolinSpeed3..757 For This Useful Post:
MD1032 (05-30-2017), Vansquish (05-30-2017)
 Old 05-28-2017, 10:55 PM   #3
Varomnia's Avatar
Posts: 459   (View Stats)
If you're throwing that much time and money into a build, what's another $350 for internals? Once and done.
The Following 3 Users Say Thank You to Varomnia For This Useful Post:
MD1032 (05-30-2017), MSMS3 (06-01-2017), Vansquish (05-30-2017)
 Old 05-29-2017, 01:06 AM   #4
omgzilla85's Avatar
Posts: 84   (View Stats)
omgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to behold
There are so many threads that will tell you HPFP internals before anything else.
Sent from my Nexus 5X using Tapatalk
2007 True Red MS3 GT - AP V3 - BNR S4 - eBay DP - JBR Tru 3.0 - TR8 FMIC - TS BPV - Autotechs - JBR EBCS - 3 BAR - JBR PMM - CS RMM - CS Shift Plate - DM OCC - Koni Yellows - Eibach Pro-Kit - Enkei Evo Xs - Freektuned
omgzilla85 is offline   Reply With Quote
The Following 2 Users Say Thank You to omgzilla85 For This Useful Post:
 Old 05-29-2017, 08:15 PM   #5
cyber-ms3's Avatar
Posts: 197   (View Stats)
cyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond repute
Groaned at 6 Times in 2 Posts
Originally Posted by Klapamos View Post
Hey all,
You should search the other threads regarding this topic. This platform has been around for a long time and there is close to nothing that hasn't been discussed yet. Guys have had issues with fuel pressure with intake and a tune.
The first thing that should be done is the fuel pump. Not number 3 or 4 on the list!
cyber-ms3 is offline   Reply With Quote
The Following 2 Users Say Thank You to cyber-ms3 For This Useful Post:
 Old 05-29-2017, 08:28 PM   #6
distortion's Avatar
Posts: 66   (View Stats)
distortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud of
Yes, you should upgrade the pump unless you want to risk blowing your rebuild...
2011 Black Mica W/Tech Package
Cobb AP|CP-E HPFP|Corksport SRI/TIP|Corksport TMIC|UR Test Pipe|Corksport Cold Air Box|Corksport Rear Sway Bar|JBR Shifter Bushings|Corksport RMM|Techna Fit Stainless Brake Lines|Ultraguage|Stratified E85
distortion is offline   Reply With Quote
The Following 2 Users Say Thank You to distortion For This Useful Post:
 Old 05-30-2017, 06:01 AM   #7
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
You need internals, end of story. Buy some used ones on MSF/MSO or Facebook. They're cheap.
2007 Mazdaspeed3 GT
 Old 05-30-2017, 11:40 AM   #8
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
2012 NASA Spaceship Gray MS3
The Following 4 Users Say Thank You to KiwiFlavor For This Useful Post:
MD1032 (05-30-2017), monkey.bones.007 (05-30-2017), MSMS3 (06-01-2017), Vansquish (05-30-2017)
 Old 05-30-2017, 05:21 PM   #9
dealerjohn1's Avatar
Posts: 268   (View Stats)
dealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the world
Are you Fucking kidding me?
dealerjohn1 is offline   Reply With Quote
 Old 05-30-2017, 06:09 PM   #10
PadreDave's Avatar
Posts: 27   (View Stats)
PadreDave will become famous soon enoughPadreDave will become famous soon enough
Yep. I used the CS kit and it made a huge benefit in daily driving by smoothing out the normal clutch release and the general smooth running of the engine.
PadreDave is offline   Reply With Quote
The Following 3 Users Say NO Thank You to PadreDave For This Un-useful Post:
MSMS3 (06-01-2017), tegxsi (06-01-2017), Vansquish (05-30-2017)
 Old 05-30-2017, 09:48 PM   #11
Police - Grammarhead
Vansquish's Avatar
What the hell are you talking about? The HPFP has absolutely nothing to do with your clutch, and should have no appreciable impact on engine smoothness. In fact, if anything it should make your car's engine's NVH worse.
KiwiFlavor likes this.
The Following 5 Users Say Thank You to Vansquish For This Useful Post:
KiwiFlavor (05-31-2017), MD1032 (05-31-2017), monkey.bones.007 (05-31-2017), MSMS3 (06-01-2017), Varomnia (05-30-2017)
 Old 05-31-2017, 05:33 AM   #12
MD1032's Avatar
Groans: 143
2007 Mazdaspeed3 GT
The Following 4 Users Say Thank You to MD1032 For This Useful Post:
KiwiFlavor (05-31-2017), monkey.bones.007 (05-31-2017), Vansquish (05-31-2017), zenit (05-31-2017)
 Old 05-31-2017, 08:14 AM   #13
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
I'm ready.
crapatalk it sucks for free
The Following 3 Users Say Thank You to monkey.bones.007 For This Useful Post:
AwAfrican (06-01-2017), KiwiFlavor (05-31-2017), Vansquish (05-31-2017)
 Old 05-31-2017, 01:10 PM   #14
PadreDave's Avatar
Disregard my previous post....I forgot which forum it was on.....
MSMS3 (06-01-2017), tegxsi (06-01-2017), Vansquish (05-31-2017)
 Old 05-31-2017, 01:15 PM   #15
Vansquish's Avatar
Even if it was on a different forum, you should think twice about spreading such misinformation. There's enough "Fake News" out there without the Mazda community adding to it.
monkey.bones.007 (05-31-2017), Varomnia (05-31-2017)
 Old 06-01-2017, 05:33 AM   #16
Posts: 2,826   (View Stats)
OP: You should know that on this issue, if you have to ask, if you even think about it, the answer is "yes."
The stock fuel pump is marginal as it is when new. Using an old pump with worn stock internals with probably a 100,000 miles on them is unthinkable if you "turn up the boost" even once. It takes less than one second of leaning out to destroy your engine. The damage can happen too fast to see it real time logging. Only if you were running a recorded data log at the time of the catastrophic engine failure and analyze the file later might you see a few cells of low rail pressure and wide injector bandwidth immediately preceeding the terminal event.
MD1032 (06-01-2017)
 Old 06-01-2017, 05:12 PM   #17
Klapamos's Avatar
Hey all,
Thanks for the responses! My knowledge of the MS3 is limited. I talked with my mechanic and he is going to check to see if the previous owner installed the upgraded internals. If not I'll have the extra work completed.
 Old 06-01-2017, 07:51 PM   #18
Djohns's Avatar
Posts: 3,944   (View Stats)
Stop crying. You said something entirely stupid, big deal we've all done it and we've all had to listen to the shit that follows. That's just life. Be thankful that these guys actually care enough to correct you on your mistakes so you don't sound so misinformed if a conversation like this were to ever come up again.
2010 black mica speed3
Soon:built motor
 Old 06-01-2017, 08:13 PM   #19
Unsolicited dick pic just for you.
Djohns (06-01-2017), MD1032 (06-02-2017)
Fuel Pump internals help Vlad Gen2 MS3 General Discussion 20 07-28-2012 03:53 PM
Fuel pump internals - is this the right one? Uranium9v MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 05-04-2011 06:56 AM
Page generated in 0.39637 seconds with 33 queries
