 Old 04-03-2008, 07:03 AM   #1
kneedragger241's Avatar
Posts: 67   (View Stats)
kneedragger241 has a spectacular aura aboutkneedragger241 has a spectacular aura about
Default Does a "stock" MS3 need more fuel delivery?
My car is basically stock, except for a MS CAI and an upgraded BPV.
It's a daily driver that needs to be reliable, so I won't be part of the quest for 375hp and sub-11 second timeslips.
Of course, I do like to take my car to its limits from time to time, running up through the gears to redline or occasionally trying to hit the speed limiter.
Do I "need" an upgraded fuel pump?
2007 True Red Mazdaspeed3
I'm on the MySpace
kneedragger241 is offline   Reply With Quote
The Following User Says Thank You to kneedragger241 For This Useful Post:
TurboWagon (04-03-2008)
 Old 04-03-2008, 07:25 AM   #2
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
nope your good. I would say once you hit top mount/FMIC+intake+test pipe
or Top mount/FMIC+intake + TBE you'll want to start looking into a pump. I haven't said BC because it seems that switching off the stock top mount raises the boost anyway.
 Old 04-03-2008, 07:46 AM   #3
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
if your main requirement is for it to be a DD that is reliable, then the only power mods you should consider are probably the ones you already have. there's other driveability modes that can be helpful (upgrade motor mount, suspension mods, wheels, tires, etc.), but i would definitely just call it a day on the power mods and just chill with what you have.
 Old 04-03-2008, 09:35 AM   #4
ptperformance's Avatar
Posts: 4,123   (View Stats)
If you never plan on turning up the boost, no its not needed. If you plan on adding more boost, then yes I would get one. Reason: when it comes to fuel, its alway good to have to much, to little and things go bad very quick.
 Old 04-03-2008, 09:50 AM   #5
BlackMS3's Avatar
Posts: 1,078   (View Stats)
BlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the world
But "LEAN IS MEAN"!!!!
BlackMS3 is offline   Reply With Quote
 Old 04-03-2008, 06:16 PM   #6
Yes it is but to lean on a DI motor goes bad quick.
 Old 04-03-2008, 02:42 PM   #7
tagkat's Avatar
Posts: 269   (View Stats)
tagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to behold
Wouldn't a DD still be doable with a TMIC/FMIC, TBE, and fuel pump? This is still bolt ons and shouldn't effect the drive to much.
tagkat is offline   Reply With Quote
 Old 04-03-2008, 06:17 PM   #8
Yes and that is why I stated that "if" you turn up the boost pressure you may want to make sure you have the pump upgrade.
 Old 04-03-2008, 06:42 PM   #9
phailerider's Avatar
Posts: 4,639   (View Stats)
If you put an upgraded pump onto your car you will feel a difference. i dont know what else to say. It wont hesitate as much... you'll run better in the cold. You'll feel it coming out of stops at low rpm.
Do you drive the car much in sub 40 temps i would do it. if you dont then maybe not.
If a dp and cai gets occasional fuel cut in the cold.... then that shows how "on the edge" these things really are. I dont see how some of you guys can say you dont "need it". Do you really "need" a cold air intake or any other performance mod?
if 10 engines pop before the warranty out of 1000 new stock cars this year... and the cdfp would have prevented the perfect storm.... and they give noticeable differences in the driving experience then I guess that should be a factor for you.
 Old 04-03-2008, 04:28 PM   #10
enganear's Avatar
Posts: 197   (View Stats)
enganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the world
You may wish to review this thread:
http://www.mazdaspeedforum.org/forum/foru...ck-engine.html
-enganear
enganear is offline   Reply With Quote
 Old 04-03-2008, 08:10 PM   #11
Crossbow's Avatar
Posts: 709   (View Stats)
Crossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the world
Well here's an easy question to answer.
Can an upgraded pump be bolted into place without any type of tuning, and will the car adapt without throwing all the fuel trims into ultra rich states?
Is it similar to most low-pressure fuel pump upgrades? (As in won't effect drivability, but will prevent low fuel situations and allow for future tuning/upgradability?)
Just asking these questions because the original post would seem to indicate that on general bolt ons, the owner might not be looking for any sort of flash/stand alone tuning.
Crossbow is offline   Reply With Quote
 Old 04-04-2008, 06:26 AM   #12
-enganear
Saw your post... thanks for reminding me it was there.
Asking the question here generated some conversation about the topic that resulted in looking at things from different angles.
A message forum community that frowns upon interactive conversation of previously discussed topics quickly becomes a static website full of FAQ links.
Good questions... ones I didn't think to ask.
You're right about my (lack of) aspirations for tuning this car. Messing with the ECU and boost levels scares me and quite frankly, the car is f***ing fast enough as it is! I can't keep the thing even close to the speed limit unless I set the cruise control and I find myself merging onto the highway at triple digit speeds and exiting turns at double or even triple the posted...
Are there any cops reading this? :-p
I'm on the MySpace
 Old 04-04-2008, 03:56 PM   #13
enganear's Avatar
I only meant to reference the posted datalog in that location illustrating no drop in fuel pressure for a stock engine.
-enganear
 Old 04-04-2008, 06:31 AM   #14
Jesse MS3GT's Avatar
Posts: 356   (View Stats)
Jesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the world
^ Just give it a month or two, it wont be fast to you anymore lol
Gotta love how the human body adapts to torque
Im in the same boat as you, im fine with minor bolt ons, but I dont really want to mess with boost pressures until after my warranty is expired.
There will always be someone faster than you, smarter than you, or better than you in some way. They key is to maintain a presence beside those lesser than you to appear superior
35psi, super cams, ported head, titanium valve springs, titanium rods/pistons, flux capacitor, 88mph mod, cryogenic tranny with welded differential
Jesse MS3GT is offline   Reply With Quote
 Old 04-04-2008, 06:53 AM   #15
Add 2 psi. If your warranty is still intact now... adding 2 psi is the most reversible, cheapest, most noticeable gain you can make.
 Old 04-04-2008, 08:02 AM   #16
I have to agree with this 100%. Anytime you can add either flow mods or volume mods (more air) your going to win on the power scale.
 Old 04-07-2008, 01:56 PM   #17
TotallyNotAmused's Avatar
Posts: 115   (View Stats)
TotallyNotAmused is on a distinguished road
When you mean new fuel pump, I assume you are talking about the CDFP, right? Need one on a basically stock Speed? Nope. Want one? Yeah. My car is, for the most part, stock. Intake, catback, forge. Stock boost. Before the CDFP, I was hitting 5000-5200rpm and just falling flat on my face. Got the CDFP, car pulls clean through to redline, no drop off, nothing.
My review
TotallyNotAmused is offline   Reply With Quote
 Old 04-07-2008, 02:14 PM   #18
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
My review
I was like... "Who is this guy? He didn't buy from me?"
Yea, its Robert. Sierra 117.
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline   Reply With Quote
 Old 04-07-2008, 03:34 PM   #19
Yup. I have like...3 different screen names for 5-6 forums, lol.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/does-stock-mazdaspeed-3-need-more-fuel-2114/
MAZDASPEED 3 - Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 04-04-2008 06:56 AM
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 04-03-2008 07:22 AM
"Vista Capable" Lawsuit On Hold, Awaiting Appeal Ruling Haltech Computers & Technology News 0 04-09-2008 12:50 PM
Pics Aplenty: MANSORY McLaren SLR "Renovatio" and Ferrari 599 GTB "Stallone" Haltech Automotive News 0 04-08-2008 04:20 PM
Volkswagen drops "Passat" sticks with "CC" for new sedan Haltech Automotive News 1 04-03-2008 04:29 PM
Peter Moore: Sports Games on PC Present "Serious Business Challenges" Haltech Computers & Technology News 0 04-03-2008 07:21 AM
Google Proposes "White Space" Wireless Broadband Access to FCC Haltech Computers & Technology News 0 03-26-2008 01:20 AM
Page generated in 0.40058 seconds with 31 queries
