![]() Join Date: Oct 2008 Location: Orlando, FL
Rep Power: 253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 396
(Thread Starter) | Not Ranked : 0 score any help is appreciated Thank You -Dan |
| The Following User Says NO Thank You to asiandude74 For This Un-useful Post: |
![]() Join Date: Mar 2008 Location: orange county
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,807
Groans: 137
| Not Ranked : 0 score warm it up and see whats happens. mine did the same thing at first, but then i said fuck it and went for a drive and by the time my car was warm it was fine.
__________________ 2008 STi Intake Turboback AP |
| The Following User Says Thank You to danesti For This Useful Post: | asiandude74 (02-16-2009) |
| Not Ranked : 0 score r u sure u put everything back ok? did anything pop off?
| The Following User Says Thank You to superskaterxes For This Useful Post: | asiandude74 (02-16-2009) |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4956 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| Not Ranked : 0 score i sprayed some of that copper gasket shit at the DP/turbo connection...guess i sprayed too much.....eh prob not the best idea, my car idled like shit and smoked a whole bunch for like 10 mins. Did you use anything like that? |
| The Following User Says Thank You to aaronc7 For This Useful Post: | asiandude74 (02-16-2009) |
im pretty sure except my friend broke the bpv to cold pipe bolt and i had to use zip ties. I dont know if that would be the problem. | |
![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,642
Groans: 78
Groaned at 48 Times in 31 Posts
| Not Ranked : 0 score Did you reset the ECU? Would that screw it up?
__________________ In reality I love lenny |
| The Following User Says Thank You to kingpin748 For This Useful Post: | asiandude74 (02-16-2009) |
![]() Join Date: Dec 2008 Location: Cincinnati
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 658
Groans: 60
| The Following User Says Thank You to jayspeed3 For This Useful Post: | asiandude74 (02-16-2009) |
![]() Join Date: Apr 2008 Location: San Diego
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 577
Groans: 38
| Not Ranked : 0 score my car didnt stall when I put a dp on and then started it, check over everything front to back that you had taken off. O2 sensors should be in place, hooked up to the car. the top one should be in the bung closest to the firewall if your DP has two bung-holes (beavis and butt-head). If you took any intake and intercooler stuff off check it again, and get a new bolt for the BOV so you dont get a vac leak which would make a rough idle maybe stall. Do you have any CEL's? |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score hahahahaha no one read that he's holding his valve on with a zip tie? go get a fucking bolt and report back |
| The Following User Says Thank You to phillyb For This Useful Post: | danesti (02-17-2009) |
![]() Join Date: Mar 2008 Location: abc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,081
Groans: 147
Groaned at 34 Times in 29 Posts
| Not Ranked : 0 score boost leak. . . vacuum leak.. . . . . . fuck off, its the same thing got ot fucking bed you fuckfffs and welches graep juices
__________________ "08, I hate to break it to you, but if it gives kevin a boner, its porn" ![]() NATOR PERFORMANCE Nylon washer sponsered |
Groans: 147
| Not Ranked : 0 score get sme kraft sangles
| Not Ranked : 0 score You zip tied you bov on? I dont need to say anymore.
Groans: 1,940
| Not Ranked : 0 score it could be the leak caused by the zip tie. that's what i was eluding to. please get that shit fixed and report back |
| The Following User Says Thank You to phillyb For This Useful Post: | asiandude74 (02-17-2009) |
![]() Join Date: Oct 2008 Location: Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
Groans: 190
| Not Ranked : 0 score IF the BPV is not sealed correctly due to the bolt breaking off and leaking air into the system post MAF, then at idle your running uber lean causing it to stall. Replace the bolt, reset the ECU again, and then i bet your problem goes away.
__________________ My mission is to go fast. ![]() Currently Designing: The golden girdle of the gods The CF "fuck your face" IM |
| The Following 2 Users Say Thank You to phantom3 For This Useful Post: | aaronc7 (02-17-2009), asiandude74 (02-17-2009) |
Groans: 370
| Not Ranked : 0 score yeah i missed the whole ziptie thing...haha. fix that |
| The Following User Says Thank You to aaronc7 For This Useful Post: | asiandude74 (02-17-2009) |
| aspiring turbo guru ![]() Join Date: Dec 2008 Location: Minnesota
Rep Power: 240 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 245
| Not Ranked : 0 score you mean to tell me that a zip tie can't offer the torque-down capability of a 10mm bolt? god what is the world coming to. OP - get it fixed, odds are your issues will go away. you might as well double-check your other clamps to make sure they're tight as well, since even a legit clamp that is loose will cause a boost leak. |
| The Following User Says Thank You to 08_ms3_gt For This Useful Post: | asiandude74 (02-17-2009) |
![]() Join Date: Feb 2009 Location: Santa Barbara CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score Hi, my car is running funny. I replaced some botls with zip ties. Any ideas on what could be causing the problem?
__________________ I've got a belly full of white dog crap, and now you lay this shit on me? |
| The Following User Says Thank You to UltimateWhiteGuy For This Useful Post: | martyxattack (02-17-2009) |
| The Following User Says NO Thank You to UltimateWhiteGuy For This Un-useful Post: |
| The Following User Says Thank You to wisniaPl For This Useful Post: | asiandude74 (02-17-2009) |
| Not Ranked : 0 score Meow!
| Banned ![]() Join Date: May 2008 Location: DC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 348
| Not Ranked : 0 score Good read |
| The Following User Says Thank You to y2kc0wb0y For This Useful Post: | asiandude74 (02-17-2009) |
Groans: 137
a rare one for me +1... sorry white guy.. you killed that one.. no need to beat a dead horse
__________________ 2008 STi Intake Turboback AP | |
| The Following User Says Thank You to danesti For This Useful Post: | asiandude74 (02-17-2009) |
![]() | | #24 | ![]() |
![]() Join Date: Jun 2008 Location: Atlanta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 98
| Not Ranked : 0 score Hey man I had to use duct tape my HKS on for a couple days when it blew off and I had to get a new Oring and it worked fine.Dont want to have to do it again but it worked.
__________________ I BUSTED SOCKS CHERRY AND IT WAS GOOOOD![]() I'VE BEEN PLAYING DUMB FOR SO LONG ITS NOT A GAME ANYMORE IF IT WAS WORTH THE TIME IT TOOK YOU TO GET EVEN THAN WHY DIDNT YOU TAKE A LITTLE MORE AND GET AHEAD? |
| The Following User Says Thank You to SneakyP86 For This Useful Post: | asiandude74 (02-17-2009) |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score I got it to run it was the bpv. Just had to use vise grips to get that stud out. Thanks guys. Also another question, my vaccum when i first started it up it was jumping to 10 then back down then back up. Is this a problem? It seems when warmed up it doesnt do it but cold starts before dp never did that. |
| The Following User Says Thank You to asiandude74 For This Useful Post: | magoo (02-22-2009) |
![]() | | #26 | ![]() |
| Not Ranked : 0 score you were running rich since you are losing metered air and that's why you were stalling. If it ran long enough, you'd get a fault code. after a few seconds idling the vacuum should be constant. |
| The Following User Says Thank You to Lex For This Useful Post: | asiandude74 (02-17-2009) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Did you reset your ECU this time if not try doing that.It needs to relearn again,it will take a few cycles of the key for it to be normal (or as normal as this car gets).
![]() | | #28 | ![]() |
![]() | | #29 | ![]() |
Groans: 190
| Not Ranked : 0 score at idle he would be in vacuum (gaining unmetered air), and running lean.
![]() | | #30 | ![]() |
Groans: 190
It doesn't hurt to reset it again.
__________________ My mission is to go fast. ![]() Currently Designing: The golden girdle of the gods The CF "fuck your face" IM | |
| The Following User Says Thank You to phantom3 For This Useful Post: | asiandude74 (02-17-2009) |
![]() | | #31 | ![]() |
| Not Ranked : 0 score is it necessary to reset the ECU or just baby it for ~50 miles until the LTFT's reach their new values? i swapped from Forge BPV to stock, i didn't reset the ECU but my LTFT's were holding steady @ adjusted values after ~50 miles (and a bunch of key cycles). |
![]() | | #32 | ![]() |
Groans: 190
| Not Ranked : 0 score Why chance anything going wrong? This car is pretty picky. I always reset.
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score hey guys thanks for the help it seems to be going good now. Now im just gonna drive normally and in a few miles im gonna go crazy! lol |
![]() | | #34 | ![]() |
Groans: 1,940
| Not Ranked : 0 score good shit man. glad you got the help you were looking for. now the next time some idiot zip ties his valve to the cold pipe and stalls, at least he can search for this fail thread... hahahahahaha... i'm just being an ass...you live and learn. and trust me, i've fucked up almost every single install on my car. |
![]() | | #35 | ![]() |
![]() Join Date: Apr 2008 Location: Atlanta, GA
Rep Power: 334 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 247
SneakyP where did you find a replacement o-ring? Were you able to find it at the hardware store or did you go to autozone? | |
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
__________________ I BUSTED SOCKS CHERRY AND IT WAS GOOOOD![]() I'VE BEEN PLAYING DUMB FOR SO LONG ITS NOT A GAME ANYMORE IF IT WAS WORTH THE TIME IT TOOK YOU TO GET EVEN THAN WHY DIDNT YOU TAKE A LITTLE MORE AND GET AHEAD? | |
![]() | | #38 | ![]() |
| Not Ranked : 0 score lol... that bolt was defintially your problem.
__________________ On motor #3 Turbo #2 Now have a SSM 08 STi!! |
![]() | | #39 | ![]() |
| Not Ranked : 0 score Glad you got it working bro.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | asiandude74 (02-22-2009) |
| WTF Catless CEL problem, yea just look anyway | superskaterxes | MazdaSpeed 3/6 - ECU Computer Tuning | 32 | 05-01-2011 03:43 PM |
| Corksport Downpipe Installation problem | ItalianSA | MazdaSpeed 6 - How-To's | 32 | 03-28-2011 06:43 PM |
| devils own problem!!! help!! | samsel450r | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 6 | 02-10-2009 12:33 AM |
| Lights problem. | Demi | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 12-15-2008 10:53 PM |
