 Old 09-03-2013, 09:33 AM   #1
anthmash's Avatar
Posts: 11   (View Stats)
anthmash will become famous soon enough
Default Downpipe or stock DP ?
I recently just picked up a 2006 ms6 and il loving it to death. It's a fast car but there's always room for improvement and so the modifying begins lol. I already have the corksport Sri+TIH, autotech HPFP, and Cobb AP running a stage 2 ots map. Other modifications I've done are muffler deletes just to get a nice sound but now I'm after more power in my list for wanting more and I figured a downpipe would be the best thing to get next as I'll see the most power gains there, but I'm worried that even if I get a high flow catted DP I won't pass emissions, since it's removing both cats and replacing it with only one. So I was wondering if anyone has gone down the route of catted downpipes and still been able to pass emissions ? Not to keep the environment happy, just so I don't have to swap out every 2 years lol
Sent from my iPhone using Tapatalk - now Free
anthmash is offline   Reply With Quote
 Old 09-03-2013, 09:36 AM   #2
ms3rick's Avatar
Posts: 2,959   (View Stats)
Find a smog guy....
Sold:
2010 MS3 siLver.
Official 60-100mph Times
Official Video battles
Official Youtube Channels
 Old 09-03-2013, 09:39 AM   #3
Spectrix's Avatar
Posts: 332   (View Stats)
Groaned at 7 Times in 3 Posts
At your point, power is going to come more from ignition changes than hardware.
For your money, a test pipe, some E85 and an e-tune from one of the capable tuners on this forum would net you infinitely more power than a catted downpipe on its own. It's much easier to swap out for emissions too.
 Old 09-03-2013, 10:16 AM   #4
anthmash's Avatar
I was thinking about a test pipe too, the sure m6 test pipe is what I would get. Any noticeable power gains or just frees up restriction ?
 Old 09-03-2013, 10:51 AM   #5
jk_ms3's Avatar
Posts: 1,390   (View Stats)
Groans: 40
Please don't get Sure crap. Do a quick search to see what an awesome company they really are. Your best bet is to donate and pick one up for cheap in the for sale section.
(Also, I understand the irony of me saying that, seeing as I have a Sure TP on my car, but I got it used from a local. It's a nice pipe, but I'm not sending any of my money to Sure or Street Unit.)
On deck: VG Sharkfin Antenna
 Old 09-03-2013, 10:54 AM   #6
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
E85 and tune. DP won't make you go fast on an OTS map. E85 + DP, and no we're talkin...
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 09-03-2013, 10:56 AM   #7
Just buy a used OEM TP and gut it, swap in the catted OEM come inspection time.
 Old 09-03-2013, 11:07 AM   #8
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Depends on what state you are in. If they do a visual inspection you will fail. If they just scan for codes you can make it pass.
Soon to come.
WHO KNOWS? A.D.D. FTW!
 Old 09-03-2013, 11:47 AM   #9
anthmash's Avatar
I can't get my hands on e85 where I am, it's to much of a mission to go to the closest gas station that supplies it so that's out of the question, maybe WMI would be a god way to go but I'm not sure if i have to upgrade the top mount or might as well go fmic for that
If I get a TP I plan on swapping it come inspection time anyway lol
As I have a totally stock exhaust (minus muffler deletes) would it be a good idea replacing just the midpipe to a 3 inch TP (using sure as an example, or even CS) if the exhaust goes from 2.5 to 3 back to 2.5 ? Or would a catback exhaust make sense pairing it to a test pipe for that reason ?
Last edited by anthmash; 09-03-2013 at 11:47 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-03-2013, 01:33 PM   #10
Spiral1183's Avatar
Posts: 250   (View Stats)
Spiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the world
Just so I'm understanding, are people saying a dp isn't worth it over just a tp? I'm about to pull the trigger on a long catless dp, but if a tp will get me equal gains I don't see why I shouldn't go that route
2007 Black Mica Mazdaspeed6 GT - Stockness
Spiral1183 is offline   Reply With Quote
 Old 09-03-2013, 01:57 PM   #11
JgamB's Avatar
Posts: 2,566   (View Stats)
That was my conclusion after a good bit of research as well - no regrets now that I'm tuned. No busted O2 sensors / CELs / bitch bolts to get go / exhaust stank in the car / super fast stock out.
The UR test pipe I bought through Edge was superb workmanship, and I wanted the hangers.
 Old 09-03-2013, 02:06 PM   #12
Fail_6's Avatar
Posts: 2,305   (View Stats)
Fail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the world
TP is NOT equal to a DP. I'm not sure where that consensus is coming from.
Test pipe merely replaces a section of the full stock DP, but the cat is still present, and arguably that's the biggest restriction present, other than the smallish piping. The DP upgrades to a hi flow cat, or no cat at all, and increased diameter increases the air flow path. I'm not sure if people are actually suggesting a test pipe would provide the same flow increase, but it does not.
Regardless, though I can't speak for the cats installed on CPE, ATP, etc DPs, I had an aftermarket Random Technology cat iinstalled on my existing catless DP for optimal catted results, and passed the emissions test fairly easily.
I've attached pictures of the section the test pipe replace vs a full aftermarket DP, as well as the stock cat vs the Random Tech cat
2006 Black Mica MS6 GT
FreekBuilt Longblock, Manley 9.5:1, Manley H Beams, BW S300SX 6268 1.00 A/R, Dual Tial 38mm MVR EWG, Twinscroll Tubular Top Mount, EGR Delete, Labontes Stage 2 Meth Kit w/ D10, Grimmspeed 3 port EBCS, 3 Bar Map Sensor w/ Matt Jackson Harness, PERM 4" Intake, Cp-E HPFP, CX Racing FMIC, HKS SSQV V3, NGK IX 6510's, Toyota Injector Seals, PERM Catless 3" Turboback w/ dual Magnaflow Magnapaks, PERM Top Mount Valve Cover, PNP Intake Mani, BSD, ACT ZX4-HDG6, Bilstein HD Shocks, H & R Springs, Stoptech Slotted Rotors w/ API Ceramic Pads, JBR Heavy Shift Knob
Stock motor w/ GT2871r:
380 awhp, 375 awtq @ 24 psi (e85 only)
- 13.1 @ 110, 2.1 60 ft
Fail_6 is offline   Reply With Quote
The Following 2 Users Say Thank You to Fail_6 For This Useful Post:
anthmash (09-03-2013), Code Monkey (09-03-2013)
 Old 09-03-2013, 02:32 PM   #13
MizzyMS3's Avatar
Posts: 511   (View Stats)
MizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the world
^^ we know a dp does not equal a tp when it comes to replacing actual hardware. They mean that they can get 90% of the performance for 10% of the headache of install and not have to worry about emissions
2012 CWP MS3 w/ Tech Package
Cobb AP V3 Purple Drank Tuned (E33 mix) | HTP 3.5' Intake | eBay Catless DP | UR CBE | CX-Racing FMIC | Autotechs | Turbosmart Dual Port BOV | JBR Short Throw Shifter | JBR Stage 2 SSP | JBR 88 duro RMM | RallyArmor Mudflaps | Eibach pro kit + Koni Yellows + SPC Camber Arms | NGK step colder
MizzyMS3 is offline   Reply With Quote
The Following 4 Users Say Thank You to MizzyMS3 For This Useful Post:
anthmash (09-03-2013), Code Monkey (09-03-2013), Fail_6 (09-03-2013), JgamB (09-03-2013)
 Old 09-03-2013, 02:56 PM   #14
anthmash's Avatar
Thank you for clearing that up lol I don't want people being confused, the option of a tp was presented to me and I am now leaning that way but one of my questions still exists, if I go to say a 3 in TP should I go ahead and do a 3 in catback as well ? That's where I now need clarification. To me it would seem that it would make sense because having the stock 2.5 in dp go into a 3 in TP and back to the remaining stock 2.5 exhaust would create back pressure of some sort
 Old 09-03-2013, 02:58 PM   #15
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Fwiw, I gutted both stock cats and haven't gotten a cel
 Old 09-03-2013, 04:05 PM   #16
anthmash's Avatar
Cel isn't what I are about, I couldn't care less if I got one it's the fact of if I were to get a catted 3 inch DP I would like to know if I could pass emissions with just that. But now after some convincing I'm turning away from that and considering a test pipe with a 3 inch catback instead, so that come emissions check time I can swap the TP for the stock cat and change them out again after I pass
 Old 09-03-2013, 04:22 PM   #17
Well the cel is what makes you fail emmisions, so you saying you wanna pass emmisions one would assume you care about cels...
The Following User Says Thank You to Dizzy Turbo For This Useful Post:
xx5PEEDxx (09-03-2013)
 Old 09-03-2013, 05:19 PM   #18
anthmash's Avatar
I realize that but if I get a cat I won't have one if I decided to go cat less I would but that's irrelevant because I'd fail like that anyway. The reason I don't care is as follows, for example, if I went only a test pipe and for some random reason I get a cel I wouldn't give a shit because I know it's from the tp. But the cel due to that is irrelevant because when it comes time to get an emissions test I will swap out the tp for the stock catted mid pipe and swap back after the test is done
 Old 09-03-2013, 05:37 PM   #19
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
For people that are worried about emissions and inspection and have no plans of BT a test pipe should suffice for your power expectations. An upgraded tmic or big core fmic is a good idea as well if you really want to maximize flow on the k04.
I say FYIN.
Fuck your inspection niggah. Find a guy for that (not hard) and just go full catless.
 Old 09-04-2013, 06:39 AM   #20
I'm just trying to tell you that my car is catless and I passed emmisions fine, that is all.
 Old 09-04-2013, 06:51 AM   #21
KusteLokal's Avatar
Posts: 2,664   (View Stats)
KusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the world
Groans: 124
Op what state are you in?
1995 Miata 1.8
2006 MS6 Sold
KusteLokal is offline   Reply With Quote
 Old 09-04-2013, 07:44 AM   #22
jk_ms3's Avatar
Groans: 40
I just have the 3" test pipe with a stock dp and cbe, and I really like it. I noticed a good deal more power with it and an S-OTS tune (which really is where your gains are going to come from). When I eventually change out the cbe I'll probably do the dp with it, but for now I like this setup just fine. You're not going to see all of the power gains of a full dp, but it's WAY easier to change out if you're worried about emissions.
The Following User Says Thank You to jk_ms3 For This Useful Post:
Lex (09-04-2013)
Page generated in 0.42992 seconds with 34 queries
