 Old 11-30-2008, 05:44 PM   #1
08BLKMS3's Avatar
Posts: 240   (View Stats)
08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future08BLKMS3 has a brilliant future
Default Dual Port BOV question
ok so I'm pretty new with all this turbo stuff. I bought a Turbosmart dual port BOV from SU not too long ago and followed all the instructions. It was running fine for a while but just a few days ago my RPMs have been acting up. As soon as I put it in neutral the rpms go down to about 1000 then back up to 1800 then back down to 1000. Why the hell is this happening? It's beginning to be a pain in the ass.....
08BLKMS3 is offline   Reply With Quote
 Old 11-30-2008, 09:07 PM   #2
ptperformance's Avatar
Posts: 4,123   (View Stats)
Make sure it didn't come loose or you didn't blow the hose off.
 Old 11-30-2008, 10:28 PM   #3
GFish's Avatar
Posts: 286   (View Stats)
GFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond repute
yea a great cheap fix is to go to the hardware store and get some better hose clamps and then check all your other clamps to make sure they are tight. Did it get cold when the problem started.
__________________________
2008.5 Mazdaspeed 3 GT Crystal White Pearl Mica
mods:30% tint front 2 windows 20% all other windows, clear bra on front and custom peace covering rear bumper, corksport mm inserts, and some other good stuff
GFish is offline   Reply With Quote
 Old 12-01-2008, 12:38 PM   #4
08BLKMS3's Avatar
yea it got cold when it started. I did check all the hoses and they all seem tight but I also used the silicon hose that the BOV came with that has no clamps so I'll go and get some. Hopefully that will work. I'll let you guys know.
 Old 03-27-2009, 06:00 PM   #5
Speed3ForMe's Avatar
Posts: 18   (View Stats)
Speed3ForMe will become famous soon enough
Update?
Speed3ForMe is offline   Reply With Quote
 Old 03-31-2009, 02:20 AM   #6
xxtruflipxx's Avatar
Posts: 29   (View Stats)
xxtruflipxx is a jewel in the roughxxtruflipxx is a jewel in the roughxxtruflipxx is a jewel in the rough
I had the same problem I used the stock tubing and it turned out fine dunno why...
xxtruflipxx is offline   Reply With Quote
 Old 04-07-2009, 08:28 AM   #7
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
did you guys reset your ecu after install?
-- Mario Andretti --
 Old 04-07-2009, 09:12 AM   #8
08BLKMS3's Avatar
yea I reset it. All that needed to be done was use the stock tubing with clamps and it went away.
BPV vs. Dual Port BOV reddeerspeed3 MazdaSpeed 3/6 - Turbo Induction 2 09-07-2008 12:54 AM
Turbine housing port work, 311 this is for you!!! ptperformance Mazdaspeed3/6 General Discussion 13 04-15-2008 02:38 PM
D-Link DUB-H7 7 Port USB 2.0 Hub $9.99AR Haltech Hot Deals Section 0 04-03-2008 12:20 PM
If your going to port something... do it right the first time!!! ptperformance Mazdaspeed3/6 General Discussion 16 03-31-2008 04:47 AM
Page generated in 0.30655 seconds with 25 queries
