 Old 12-05-2013, 02:00 PM   #1
btld_ls1's Avatar
Posts: 68   (View Stats)
btld_ls1 is a name known to allbtld_ls1 is a name known to allbtld_ls1 is a name known to allbtld_ls1 is a name known to allbtld_ls1 is a name known to allbtld_ls1 is a name known to all
Default EBCS clicking...
I tried searching and only found one relevant thread and it didnt really answer the question. When I turn the key over the EBCS constantly clicks and is doing it at idle as well. I seem to be having an issue with the car holding boost as well.
My questions is, is the clicking normal or does this indicate a failing or bad solenoid?
2006 MazdaSpeed 6 - Megan lowering springs, 3" catless DP, 3" dumped exhaust, BNR S3, ITV-22, Corksport TIP, SRI, Autotech internals, RMM, ported Intake, TIG, EGR delete, 50/50 E85
btld_ls1 is offline   Reply With Quote
 Old 12-05-2013, 02:54 PM   #2
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
How long have you had the EBCS in? Make sure there no boost/vac leaks, it's all connected up correctly and don't mount it on the firewall.
The grimmspeed EBCS clicking is loud and annoying when you mount it on the firewall. Post logs @ idle and while driving
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
 Old 12-05-2013, 03:30 PM   #3
btld_ls1's Avatar
Guess I should have stated, its the factory solenoid.
 Old 12-05-2013, 03:34 PM   #4
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
Is it mounted close to your firewall? the solenoid will click (duh, it's a solenoid) but if you mount it on your battery tray away from the firewall you won't hear it.
2010 LSM Speed3
#BakeryTuned
The Following User Says Thank You to Roddiy For This Useful Post:
ms6mil (12-05-2013)
 Old 12-05-2013, 03:53 PM   #5
btld_ls1's Avatar
its in the stock location. i understand it will click but its a lot louder then when i first got the car (can hear it in the car over the car running @ idle) , but if its nothing to be concerned with ill do a boost leak test next. Thanks
 Old 12-05-2013, 04:30 PM   #6
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Well if it's louder than when you first got to car and you are having trouble holding the same boost levels as before, then that would point to the fact that something is dying inside it.
Swap it out for someone else's and see if problems/sound goes away. That will pinpoint if the stock ebcs is taking a dump.
 Old 12-06-2013, 07:52 AM   #7
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Be careful pulling the hoses off the OEM EBCS.
The plastic is famous for being brittle and the nipples breaking off very easily.
340hp / 371tq
 Old 12-06-2013, 07:58 AM   #8
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Cut tubing and then run new sillycone type.
Nator is what it does.
clicking noise? newerBlk_ms3 2010 MS3 - Suspension & Brakes 2 08-07-2011 08:42 PM
Clicking noise? litalien18 MazdaSpeed 6 - Engine, Transmission & Driveline 5 07-28-2011 07:01 PM
Clicking? Perhaps it's this ispypsi MazdaSpeed 3 - Engine, Transmission & Driveline 4 05-08-2011 12:41 PM
Clicking noise Spoolme MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 01-23-2010 01:56 PM
Page generated in 0.28704 seconds with 25 queries
