 Old 12-02-2008, 02:12 PM   #1
red07's Avatar
Posts: 290   (View Stats)
red07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant future
Default ETS 3.25" impressions
Got that ETS installed the past weekend.
For all you guys that are considering this as an upgrade, mechanically it's like 2.5-3 out of 10. I'm pretty much a noob, and got it done by myself in under 2 hours.
A couple of hints for installation: get some cardboard and cover both sides of the ETS before you install, that way it's protected from bumps, tools, and plain bad luck. I would use those same pieces to cover up the stocker TMIC as well, for storage, and tape up the hot/cold side ports. I would also consider doing any intake mods at the same time, and if you're looking to upgrade the driver side trans mount, do that too, since you'll be in the same general area as the TMIC. I would lastly check ALL of your clamps. Mine were tight, but I was lucky, there are some stories floating around of guys w/ weird underboosting, stutter, knock retard etc etc because their clamps weren't tight.
If people want an install writeup, I can do one, but sorry no pics, didn't want to grease up my camera.
Driving: well, I crudely datalogged, and the ETS definitely takes longer to heatsoak. However, heatsoak it does.
Once you get driving though, the boost air temps drop dramatically, and in a hurry, only a couple of seconds to lose 25+ degrees of BAT. The stocker doesn't cool off as much. The drop is even more dramatic at full throttle.
AFR's seem stable: 14.7 at idle, 11/12's at full throttle. LTFT's are steady for me, in the 8 range.
I recommend this, especially for guys that are starting to fully bolt up.
Last edited by red07; 12-02-2008 at 02:34 PM. Reason: getting forgetful in my dotage...
red07 is offline   Reply With Quote
The Following User Says Thank You to red07 For This Useful Post:
skeeter149 (12-02-2008)
 Old 12-02-2008, 02:16 PM   #2
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
sweet i have been eyeballin one of the polished ones on SU but i think they are on backorder... dammit
09 MGM MS3
 Old 12-02-2008, 02:19 PM   #3
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
odd you had to take the battery out, but yeah i felt the same about mine.
 Old 12-02-2008, 02:31 PM   #4
red07's Avatar
In retrospect I didn't have to, but I wanted a bit more room to get at the boost tube clamps. I also checked and tightened all the clamps as a precaution, so I pulled it.
I had better go edit my first post, now that I think about this more.
 Old 12-02-2008, 02:45 PM   #5
bnoon's Avatar
Posts: 1,770   (View Stats)
Damn dude, under 2 hour install??? Were you not able to reach the bolts on the clamps or what? I installed a used ETS before I built my air/water setup and it's a 20-30 minute job at most to swap out to another TMIC. Where did you spend most of your time??? I'm not trying to make fun, I'm genuinely shocked...
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
The Following User Says Thank You to bnoon For This Useful Post:
breakfstincluded (09-27-2013)
 Old 12-02-2008, 03:15 PM   #6
red07's Avatar
I know that's damned slow, but at least I'm honest. I was moving slow, and due to this being my first turbocar, I was paranoid about missing steps, so I took care to pull everything off and organize them along the garage wall in order of removal. I also spent time putting away the stocker TMIC, locktited all the bolts, cleaned hardware, looking for sockets, etc. At a guess, total time from walking out to washing hands was 1.5 hours, which is <2.
Wait till I try the sway bars, that ought to be a 2-month job based on my (lack of ) skills!
 Old 12-02-2008, 03:15 PM   #7
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
yeah its a good tmic! you loose less boost vs stock too...
 Old 12-02-2008, 03:34 PM   #8
red07's Avatar
Oh nuts, you just reminded me of datalogging boost on stocker vs ETS...
Seems to me that I gained ~1# of max boost, which is fine w/ me, the car pulls hard, especially in 3rd/4th.
 Old 12-02-2008, 04:09 PM   #9
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Hectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the world
Groaned at 9 Times in 6 Posts
I will say it again.....I NEED ME ONE OF THESE!
Thanks for the impressions.
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
Hectik1 is offline   Reply With Quote
 Old 12-02-2008, 04:20 PM   #10
red07's Avatar
I got lucky timing-wise, John @ PTP had a couple for sale at a very good price new. I believe he's out of them, so I won't post a price, but suffice it to say that it was <$80 shipped over the price of some of the used ones on this board.
If you don't *need* one right now, I believe that SU and Protege garage are both working on upgraded TMIC's. When theirs come out, prices may drop on the ETS and/or people will sell theirs off to get the next latest'n'greatest.
One of my biggest reasons for getting this vs a FMIC is that it will be a lot easier to return to stock for the dealership visits.
 Old 12-02-2008, 05:38 PM   #11
CWPspeed3's Avatar
Posts: 51   (View Stats)
CWPspeed3 is an unknown quantity at this point
ETS is selling the 3.25" for $499 currently on their website, seems like a pretty good price and way lower than the TRZ one thats coming out, who knows how long that sale will last though.
CWPspeed3 is offline   Reply With Quote
 Old 12-02-2008, 05:51 PM   #12
red07's Avatar
499? That's a good price. The last few used ETS TMIC's were 400-450 IIRC, although in all fairness at least one of them had the powdercoating option.
Is that shipped, or is shipping extra?
 Old 12-02-2008, 06:01 PM   #13
booya620's Avatar
Posts: 697   (View Stats)
booya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the world
I ordered the street unit 3.25 TMIC that's replacing the ETS on their website. It's selling for the old price of the ETS, but I also got the 7% thanksgiving discount. I'm hoping that it will be a quality piece and live up to what I've seen from the company so far.
2008 Sunlight Silver MAZDASPEED 3
[SIGPIC][/SIGPIC] MODS: COBB SF SRI, Mazdaspeed CBE 3", Street Unit 62a Rear Motor Mount, Street Unit Shifter Bushings, COBB Shift Weight, Forge Bypass Valve (Blue Shim).
booya620 is offline   Reply With Quote
 Old 12-02-2008, 06:06 PM   #14
CWPspeed3's Avatar
Sorry, that must have only been a black friday price only its back up to $595 on their website.
 Old 12-02-2008, 06:08 PM   #15
red07's Avatar
Ah, well, sorry to hear that for all of you still looking to get this.
 Old 12-02-2008, 06:53 PM   #16
desperado callado's Avatar
Posts: 170   (View Stats)
desperado callado is a splendid one to beholddesperado callado is a splendid one to beholddesperado callado is a splendid one to beholddesperado callado is a splendid one to beholddesperado callado is a splendid one to beholddesperado callado is a splendid one to behold
What are your other mods?
The mass of men lead lives of quiet desperation. What is called resignation is actually a lack of boost.
Mods: Defi Blue Racer Boost Gauge, 2nd Fiamm Horn (Low Tone) SU Mid-Pipe. Cobb Adjustable Shifter (now "functioning as intended" with 20mm allen bolts and locking nuts), CP-e Nano SRI. Sometime in the not-too-distant future: Airbox (?) and SU/ETS 3.25 TMIC
desperado callado is offline   Reply With Quote
 Old 12-02-2008, 09:45 PM   #17
red07's Avatar
ETS, MSCAI run as a shorty, AP flash V103B stage 1 + MSCAI, RPMC turbo inlet, TRZ motor mount.
 Old 12-03-2008, 07:47 AM   #18
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
... just a heads-up for ya: Leaking Intercooler at Cold Pipe - Mazda6 / Atenza
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
LBV is offline   Reply With Quote
 Old 12-04-2008, 01:39 PM   #19
tbone's Avatar
Posts: 55   (View Stats)
tbone is an unknown quantity at this point
how does it ride?
tbone is offline   Reply With Quote
 Old 12-04-2008, 02:51 PM   #20
red07's Avatar
LBV, I'll have to keep an eye out for that. So far I think it's fine. I did a visual check before install, to make sure I didn't see any pinholes or incomplete welds, and it looked good there. The welds aren't the best, but then again they covered all the seams, so good enough for me. Keeping an eye on the boost shows me steady #'s during idle/cruise, and appropriate boost #'s during WOT.
How does it ride? Very well, no fuel cut so far. The coldest I've done a hard run so far was @ 48 degrees in 3rd gear, no cut of any sort, the car pulled hard all the way to 5800, when I ran out of room. Keep in mind I'm running my MSCAI as a shorty, so the underhood temps may very well be keeping the air from being too dense due to the cold.
The total combo of my mods gives me boost as low as ~2600-2700 RPM's, although I'm never foot-to-the-floor below 3000, I "squeeze" into the throttle as opposed to violently mashing it straight down. So far max boost I've seen is 17.2 around 4000RPM's. No weird boost spikes (yet).
I have to download that datalogging upgrade on my AcessPort and get some hard #'s: boost, AFR, knock retard, boost air temp, fuel pressure.
Spy Shots: BMW X6 5.0iS puts the "sport" in "sports activity coupe" Haltech Automotive News 0 07-28-2008 06:30 AM
Separate "Appearance" from "Wheels/Tires" KaiserSoze Website Help/Feedback 1 04-21-2008 08:33 PM
Pics Aplenty: MANSORY McLaren SLR "Renovatio" and Ferrari 599 GTB "Stallone" Haltech Automotive News 0 04-08-2008 04:20 PM
Volkswagen drops "Passat" sticks with "CC" for new sedan Haltech Automotive News 1 04-03-2008 04:29 PM
Page generated in 0.38025 seconds with 30 queries
