![]() Join Date: Mar 2010 Location: Edmonton, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 631
(Thread Starter) | Not Ranked : 0 score Hi Guys, So i've been noticing that my car's been running rich at idle (-20%LTFT), and was wondering if anyone could clear my head with this? To give some background, I'm running an EWG GTX3071 with supporting mods and a stratified tune. I did a boost leak test and the only place i could feel/hear air escaping was through the dump tube of the wastegate itself. I'm not sure if this is normal operation, as this would cause metered air to escape through the wastegate, causing a rich at idle scenario. Cruising and WOT fuel trims are fine. The way I have the EWG setup aligns with grimspeed's instructions: Port 2 to the bottom port of the wastegate, and port 3 to the high pressure boost source. My intake was a custom piece made by PERM, and does not have a intake recirc nipple, so I have port 1 going VTA. Any thoughts/insight on what's going on?
__________________ EWG GTX3071 | PERM 3.5" intake | COBB FMIC | CP-e injector seals | UR downpipe | CS testpipe | HKS catback | KW V1's | Blahblahblah Last edited by Bob-o; 05-27-2016 at 11:21 AM. |
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score If it was working fine (I assume it was if tuned by stratified), then look for things that could have changed. ie. Have you cleaned your MAF sensor? Air filter need cleaned? It seems if you're not throwing a code, then it probably isn't a true leak, or a very small one. If you've changed or modified something, look there. ie. MAF cal, BOV? or BPV? Will the VTA port let un-metered air in or out?
__________________ Max Bolted and Built Stock K04 |
| The Following User Says Thank You to sheston For This Useful Post: | Bob-o (05-26-2016) |
My old EWG was toast and was recently replaced, so i figured it was going to be a loose vacuum line or something, but no dice. I put my finger over the VTA's port, while looking at LTFT's, and it made no difference, but i supposed AFR's or boost would have been better. I made some additional findings this evening in that when i'm cruising, or have any pressure on the gas, LTFT's are -4%. If i lift off, they immediately go to -20%, which includes sitting at idle. I did a lot of searching and some people said purge valve potentially? I'm not sure about that. When i did the EWG, the DP gasket did look a little tired.. would a turbo > downpipe leak cause negative fuel trims? Or am I out to lunch?
__________________ EWG GTX3071 | PERM 3.5" intake | COBB FMIC | CP-e injector seals | UR downpipe | CS testpipe | HKS catback | KW V1's | Blahblahblah | |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
| Not Ranked : 0 score sounds like an exhaust leak, its pretty typical for lean at idle yet no other issues. I would replace that gasket you said already looked shot and go from there
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
![]() Join Date: Jan 2012 Location: Edmonton, Alberta, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,581
Groans: 53
| Not Ranked : 0 score @Bob-o; What's your MAF voltage bobby? Also I do have spare MAF sensors if you need to verify if yours is good or bad. If the resistance is poor (higher voltage than normal at idle) then that would cause a rich idle condition
__________________ 06 Speed 6 rock chipped n' shit Performance: Stratified Tune in progress Old Set-up: CS Ram air intake with 3" HTP inlet + "sig" Vdyno 323 awhp 349 awtq uncorrected Current Set up: JBR 3.5" WP, Perm PCV w/dual catch cans, trunk battery Vdyno 343 awhp 374 awtq uncorrected Corksport CBE ~ Ebay DP ~ Autotech Internals ~ COBB AP ~ BC Racing Coilovers ~ SURE shortcut ~ SURE countershift ~ SURE anchors ~ heavy sphere shift knob by maisonvi (MSF member) ~ CP-E seals ~ BSD ~ baffle pan ~ Dual Corksport OCC ~ CP-E Rear Diff Mount ~ SURE Juggernaught ~ Dashhawk ~ AWR 88 duro trilogy ~ EGR delete ~ 3 bar ~ JBR TIG's ~ Grimmspeed 3 port ~ GT2871R w/ported hotside ~ JBR 3.5 inch intake ~ Perm Tuning PCV Plate ~ Forge V1 BPV ~ ITV22's @ .026" ~ CP-E Helihose |
| The Following User Says Thank You to Swinger13 For This Useful Post: | Bob-o (05-27-2016) |
| Not Ranked : 0 score How long did you hold the VTA closed? It takes time to change the LTFTs, you should look at AFR or STFT.... Good luck. Don't pull your hair out, or you'll look like @Swinger13;'s avatar......
(Thread Starter) | Not Ranked : 0 score LOL i'd have to grow a beard of that scale before i could pull half of it out =P I do have some good news, as well as some bad news. I was able to confirm with boost leak tester it is a vacuum leak, so i can stop pulling my hair out in that respect. Bad news is that its coming from the C ring on the back side of the compressor. Video for visual representation. What would one do in an instance like this? I tried tightening the bolts, but they didn't budge, and I didn't want to break anything :3
| The Following User Says Thank You to Bob-o For This Useful Post: | Code Monkey (05-27-2016) |
Groans: 53
Sent from my LG-D852 using Tapatalk
__________________ 06 Speed 6 rock chipped n' shit Performance: Stratified Tune in progress Old Set-up: CS Ram air intake with 3" HTP inlet + "sig" Vdyno 323 awhp 349 awtq uncorrected Current Set up: JBR 3.5" WP, Perm PCV w/dual catch cans, trunk battery Vdyno 343 awhp 374 awtq uncorrected Corksport CBE ~ Ebay DP ~ Autotech Internals ~ COBB AP ~ BC Racing Coilovers ~ SURE shortcut ~ SURE countershift ~ SURE anchors ~ heavy sphere shift knob by maisonvi (MSF member) ~ CP-E seals ~ BSD ~ baffle pan ~ Dual Corksport OCC ~ CP-E Rear Diff Mount ~ SURE Juggernaught ~ Dashhawk ~ AWR 88 duro trilogy ~ EGR delete ~ 3 bar ~ JBR TIG's ~ Grimmspeed 3 port ~ GT2871R w/ported hotside ~ JBR 3.5 inch intake ~ Perm Tuning PCV Plate ~ Forge V1 BPV ~ ITV22's @ .026" ~ CP-E Helihose | |
| Not Ranked : 0 score Search around. I think I remember someone else having that issue. Don't know how they solved it. Good luck
Groans: 53
Let me know if you need help @Bob-o; Sent from my LG-D852 using Tapatalk
Thanks @Swinger13; ! Once i get it on order I'll let you know!!
| The Following User Says Thank You to Bob-o For This Useful Post: | Swinger13 (05-27-2016) |
(Thread Starter) | Not Ranked : 0 score Small update Phoned ATP and they put me in the right direction for what i'll need to make the repair. In the rare case this may help someone, here is the part needed O-ring (Seal), Orange, Goes between Backplate and Comp Housing, T04E Frame GT/GTX : atpturbo.com New part is due to come this week, hopefully install this weekend =D
| The Following User Says Thank You to Bob-o For This Useful Post: | WetzMS3 (06-01-2016) |
![]() Join Date: May 2013 Location: Mejico, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,088
Groans: 30
| Not Ranked : 0 score Hope everything works out for you man, I had a friend who had a leaking comp housing on his ATP 30r as well
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning |
| The Following User Says Thank You to impossible For This Useful Post: | Bob-o (05-31-2016) |
Lol make sure you back those bolts almost all the way out when clocking the turbo!!
| The Following 4 Users Say Thank You to Bob-o For This Useful Post: |
Groans: 30
| Not Ranked : 0 score Ahh that makes sense
(Thread Starter) | Not Ranked : 0 score This is what the gasket looks like: Shouts out to ATP for the good customer service on the phone, as well as 1 day shipping to Canada! I got 2 just to have a spare... this stuff looks like red vines!
![]() Join Date: Sep 2012 Location: Edmonton, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 124
| Not Ranked : 0 score If you need an extra set of hands let me know.
__________________ 09 SPEED 3 CWP installed: CP-e DP, CP-e FMIC, CP-e CAI, Cp-e TIP, Cp-e S2RMM, Cp-e PSMM, Cp-e DSMM, Cp-e Cat back, HKS SSQV, Steed manifold, DO meth injection with HP Controls controller, Cobb ap, Saiko Michi OCC TWM Short shifter and bushings, Rallysport mud flaps, 5%tint all around, 55 w 8000 k fogs, low and high beams. Led 6000 k switchbacks, Led reverse and turn signals. 18 X 8 45 offset w/245/40's, Raceland Coil overs |
Groans: 53
Don't be that guy though... ![]() EDIT: does ATP have a torque spec for those bolts to hold the comp housing?
When I called, ATP said the TQ spec is 26lbs on the turbine housing bolts. I hope I can fill this thread with as much information as I can to help anyone in the future that might be experiencing the issues i had!
(Thread Starter) | Not Ranked : 0 score Sadface ![]() Still rich at idle. Checked for boost leaks and heard none. The hunt continues. MAF sensor perhaps? Purge valve maybe? Secondary/Primary o2 sensor failing? I'm getting like -20% LTFT's, and a CEL almost every time I drive Chasing these small issues will be the death of this car
Rep Power: 3746 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
| Not Ranked : 0 score I had/have the same problem. Justin tuned it down but I never found the problem. I was thinking about replacing the secondary 02 sensor to rule it out.
__________________ 3rd rebuild on the way...maybe... |
![]() | | #24 | ![]() |
Groans: 211
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'll post an idle and WOT datalog this coming weekend. Would secondary o2 sensor change LTFT's? I thought it just monitored if the primary cat functioned? Or does the primary o2 work with the secondary o2? Oil doesn't really smell like gas more than normal, granted its been a while ive been chasing this problem. What would that lead towards? Thanks for the support so far guys
![]() | | #26 | ![]() |
![]() Join Date: Apr 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 346
| Not Ranked : 0 score Blowbye
__________________ Velocity Red Mica 06 Speed6 (ricer) #834 Some shitty; s300sx fmw turbo, home made fmic setup, home made 4" Intake, 3.5 blowthrough maf, home made downpipe, poorly self tuned. More motor mounts then necessary. Gay and coated white enkei rpf1s with stupid 245/45 tires. Pointless drilled and slotted rotors. Clunky coilovers. Ricer lips and lights. |
![]() | | #27 | ![]() |
__________________ EWG GTX3071 | PERM 3.5" intake | COBB FMIC | CP-e injector seals | UR downpipe | CS testpipe | HKS catback | KW V1's | Blahblahblah Last edited by Bob-o; 09-19-2016 at 05:14 PM. |
![]() | | #28 | ![]() |
Groans: 211
Its normal for the oil to smell faintly of gas due to blowby. But if it smells strongly it can point to a bad screw seal in the HPFP. When bad it allows gas to travel past the pump piston and into the block. Doesn't sound like your issue though.
| The Following User Says Thank You to Thor Hammer For This Useful Post: | Vansquish (09-19-2016) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Maybe I didn't read back thru the thread enough, but you tried a MAF cal? I would clean your MAF then do a CL and WOT MAF cal and see if that fixed it. Looking at your AFRs across the log and your LTFTs make me think you just need to redo that.'
![]() | | #30 | ![]() |
| Your idle LTFTs aren't maxed out, so I'd say that your O2 sensor seems a less than likely culprit as a result. On the other hand, your car is pulling fuel AND running rich at idle (if you're targeting 14.7-ish, that is). That suggests your MAF might be dirty or that you've got air escaping from the system under vacuum (not sure exactly where that'd happen other than the purge valve though). On the other hand, you are also running pretty rich at WOT, so aside from the knock you're registering I would say that it also appears you might have a boost leak.
| The Following User Says Thank You to Vansquish For This Useful Post: | blkspeed307 (09-19-2016) |
![]() | | #31 | ![]() |
I appreciate the help lads, I just wanna get my car to run right D: If boost leak test and cleaning the MAF checks out, perhaps I'll look into purge valve. Also, I was just curious and looked at AFR's while the car was idling. If i wiggle the MAF harness, AFR's change and get richer. Coincidence?
__________________ EWG GTX3071 | PERM 3.5" intake | COBB FMIC | CP-e injector seals | UR downpipe | CS testpipe | HKS catback | KW V1's | Blahblahblah | ||
![]() | | #32 | ![]() |
Rep Power: 3167 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score Got any random plugs missing from your IC piping? A plug on my HTP under-route hot-pipe decided to eject itself after a couple hundred miles of installing it. It was the optional boost source bung right after the compressor exit. Symptom was extremely rich trims in all situations. Never lean, which I was surprised about. I wouldn't try to tune the MAF around it. You most definitely have a leak somewhere is my guess.
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score I also remembered that my intake does not have a recirc nipple, so one of the ports on my EBSC is VTA. Would that cause the rich at idle/under boost? Or is it more complex?
![]() | | #34 | ![]() |
Groans: 211
What do you have for a BPV? Check that. My synapse was leaking at the discharge o-ring. Would have never known without soapy water. If you see changes when wiggling wires the integrity of the connector is compromised. I would replace it with a new one and splice it in or try and repair yours. Do a search on it as its been discussed and solved quite a few times here. Good luck!
![]() | | #35 | ![]() |
Groans: 53
| Not Ranked : 0 score MAF looks fine. I'm thinking one of three things here. 1. Spark plug gap is enlarged and needs to be re-gapped or replaced 2. A hidden boost leak 3. A faulty wideband o2 sensor
| The Following User Says Thank You to Swinger13 For This Useful Post: | Bob-o (09-21-2016) |
![]() | | #36 | ![]() |
Groans: 211
![]() | | #37 | ![]() |
Wideband o2 is a possibility; would not know unless i swapped mine out with a known working one. Thanks for all the help and insight everyone D: Something else I can add is after I replaced the orange o-ring on the turbo, my LTFT's and cold starts were solid. Went up to 2000 RPM, and stayed there until it slowly dropped down. Nowadays upon cold start the car starts up a little rough, and has a hard time holding a certain RPM, and sounds like its misfiring almost until it warms up.
__________________ EWG GTX3071 | PERM 3.5" intake | COBB FMIC | CP-e injector seals | UR downpipe | CS testpipe | HKS catback | KW V1's | Blahblahblah Last edited by Bob-o; 09-21-2016 at 06:02 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #38 | ![]() |
Groans: 211
| Not Ranked : 0 score I bet once you fix your MAF issue things may get a whole lot better. And I never heard of an O2 sensor working intermittently. It either works or it doesn't. I could be wrong.....
| The Following User Says Thank You to Thor Hammer For This Useful Post: | Bob-o (09-21-2016) |
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score Jacked up AFR's / Trims lately This really leads me to think it could be the MAF sensor wiring. My car is a 2009 too
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score January Update: So the car's been sleeping all winter, and I got some random spur of motivation to give it another go. To keep everyone up to date: Car was running rich (LTFT's in the -18-20s) Turbo gasket was leaking (repaired) Suspected MAF ground wire issue (new wire changed in) Still running rich I've run multiple boost leak tests, and came up with nothing quantitative, which led me to lean towards potential injector seals? I had done CP-e seals a few years back, but that was in the dead of winter, and I was not aware at the time that CP-e recommends you put a sealant between the injector and seal, as well as the seal and the head. To test, we ran a compression test, and sure enough, cylinder 3 was a bit lower than the other. ***We only idled the car for maybe 10 minutes to get it somewhat up to temp, which is why the numbers sound a bit low, but consistency across the board is more what we were interested in Results came in as (Cylinder 1-4): 160-159-147-160 So cylinder 3 seems a bit down. The initial cold start was quite rough (coughing, lumpy idle), granted it is on the same fuel from 4 months ago, and it's just been sitting in the garage all winter. Drivability issues follow as: Rich at idle (CEL sometimes present) KR at WOT (log above) Fuel trims very negative I will also note that the spark plug/spark plug hole for cylinder #3 reeked like fuel, and the plug was distinctively more 'wet' than the others. I wonder if the cyl #3 seal let go, or if there's any other directions we could take into consideration?
| P2188 Rich @ Idle | Cheapspeed | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 31 | 03-15-2016 11:16 AM |
| Rich at idle mystery | CW42 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 11 | 07-28-2014 08:55 AM |
| Rich idle, Rich on throttle tip in | MSP6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 39 | 02-17-2013 06:49 PM |
| Rich @ Idle - P2188 | TriO | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 11-02-2011 02:29 PM |
| p2188 - too rich at idle | yearzero | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 05-15-2010 09:53 PM |
