 Old 11-12-2009, 06:55 PM   #1
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
Default For the EWG gurus
this is with my tial 38mm v band. When i got tuned it was perfect 20psi across the board using the grimmspeed EBCS. as soon as i got on the street it was all over spiking 25psi. anyway we could not tune it lower so We decided to Run straight wastgate pressure. So right now running straight wategate pressure my boost goes straight up to 20psi and stayes pegged there. It worked out perfect cause i wanted a good 20psi tune. Anyway when i was on the dynojet it only boosting 18psi.
What is going on there? why would it boost different if im running straight wastegate pressure. Does anyone have any clue what spring i might have. It does not spike, just stayes pegged at 20 WOT but only 18 on dynojet. does the car really boost less with less load even on straight wastegate pressure? also what spring pressure does it look like i have. When i ordered the tial i stated 1.1 bar witch is 15.9 psi or did i get the wrong one? im confused.
The Following User Says Thank You to For This Useful Post:
SpeedSixxx (12-10-2009)
 Old 11-12-2009, 07:30 PM   #2
a dynojet is not a load based dyno so boost will always be lower then the street.
stop being lazy and take your fucking wastegate apart already. you've already gone crazy guessing lol
 Old 11-13-2009, 08:16 AM   #3
wassup61's Avatar
Posts: 1,232   (View Stats)
EBCS with the EWG doesnt really work all that well, I tried stock with and without pills, and the perrin and would get erratic boost, switched to an MBC an all is well now.
Your car only hits 18 pounds on the dyno because there isnt enough load to generate the boost you run on the street (your not pulling aroudn 3152-3400 lbs (if you are lenny lol... love you)
All wagon, No traction
Oil Catch Can gurus, please step in! steven88 MazdaSpeed 3/6 - Turbo Induction 10 10-31-2008 06:50 AM
Wheel Gurus Please Help Yahdy Ras MazdaSpeed 3/6 - Wheels & Tires 11 04-25-2008 10:34 PM
Page generated in 0.24193 seconds with 21 queries
