![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
(Thread Starter) | Not Ranked : 0 score I've noticed that sometimes when I try to transition from an part throttle dump (say at 16psi, 15psi is spring pressure) to WOT the car will stay at 16psi all the way to redline when it should've been at 20psi until I let off and hit it again. Anyone else have this problem? Is this just inherent with EWG's? Or is something a miss?
__________________ 3rd rebuild on the way...maybe... |
(Thread Starter) | Not Ranked : 0 score I'm bumping this. I've changed my driving habits so that if I'm in part boost, and want to go WOT I'll quick let off and floor it to ensure I'll hit peak boost. Could anybody else tag someone with an EWG to chime in? Also feels like building boost then letting off quickly lends to some bucking and sounds like faint turbo flutter. I read in some posts that low boost flutter isn't a big deal and most efforts to eliminate it (cleaning/lubing) didn't do much. Just want to know if there's anything I can do to stop it or at least smooth out the bucking. I have a gtx3076r with the EWG hotside with a tial 38mm wastegate, stratified 3 port, and go fast bits bypass valve in full recirc. Maybe @Lex; @Justin@Freektune; ? @Code Monkey; @Enki; @Dano; @Tomas; @Voltwings;
__________________ 3rd rebuild on the way...maybe... Last edited by Cheapspeed; 01-20-2016 at 07:54 PM. |
| Not Ranked : 0 score No experience with EWG, but is it recent or has it always been like that? I think there are like 2 or 3 different ways to setup the EWG, maybe try a different configuration?
(Thread Starter) | Not Ranked : 0 score It's always been like that since it was installed. Initially I didn't notice it because I was simply going WOT everywhere when it was installed, but building slowly on the on-ramp trying to transition to full boost that never came has put me in a precarious spot once or twice.
| The Following User Says Thank You to Cheapspeed For This Useful Post: | Code Monkey (01-20-2016) |
| Not Ranked : 0 score I hope it is a glitch of some sort, as I have plans for an EWG....
(Thread Starter) | Not Ranked : 0 score I'm pretty sure I hooked it up like this: I'd have to go back under and look.
Groans: 189
If you hook it up like this, it's going to dump pressure from the top of the WG first, which is going to reduce boost pressure... If you're at a low WGDC, it may not be enough to bleed from the bottom AND the boost source as well. If you really want to use both ports on the wastegate, I'd suggest a 4 port EBCS.
__________________ | |
| The Following 4 Users Say Thank You to Enki For This Useful Post: | Cheapspeed (01-21-2016), Easter Bunny (01-21-2016), Mazdazilla6 (01-20-2016), MS3Shadow (01-20-2016) |
| Not Ranked : 0 score I have this routing in my fail thread, but also this routing as well....
__________________ 3rd rebuild on the way...maybe... | |
Groans: 189
| Not Ranked : 0 score Confirm EBCS config (preferably), provide log of working and non working and map (preferably).
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Actually I know I'm using the top port of the EWG because I have a T fitting. No other setup uses the T. I'll grab logs tomorrow morning.
| Not Ranked : 0 score Who is your tuner? Edit: Nevermind, just read your sig. I was going to point to something similar I experienced but it was in the tune.
| Not Ranked : 0 score IIRC mine is hooked up left side to comp housing, middle to intake and right side to bottom port. Edit: Actually center is comp housing, left is bottom port on ewg and right is to my intake.
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings Last edited by Mazdazilla6; 01-20-2016 at 11:19 PM. |
| The Following 3 Users Say Thank You to Mazdazilla6 For This Useful Post: |
Groans: 189
| Not Ranked : 0 score To clarify: If middle is normally closed, you should have a hard time exceeding spring pressure unless your exhaust setup flows like crazy (low pressure against the wastegate valve) and your EBCS flows like crazy too. Nothing on top port, right?
| The Following User Says Thank You to Enki For This Useful Post: | Mazdazilla6 (01-20-2016) |
| Not Ranked : 0 score Nada OP what spring do you have in the wastegate? This is from Lex in my build thread:
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings Last edited by Mazdazilla6; 01-20-2016 at 11:07 PM. | |
| The Following 2 Users Say Thank You to Mazdazilla6 For This Useful Post: | Easter Bunny (01-21-2016), Enki (01-20-2016) |
| Approved MSF Vendor ![]() Join Date: Mar 2014
Rep Power: 2489 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,022
| Not Ranked : 0 score Where is your boost source coming from for the ewg. Is it coming from a quick tap in the intercooler hot pipe? Or are you tapped off your bov hose? Sent from my iPhone using Tapatalk
__________________ Custom Tuning for Mazdaspeed, Ford, and Subaru ![]() Website- http://www.freektune.com/ PTE 6062 633HP/523TQ First gen2 in 10's- 10.93@137 Atco NJ 11/14/15 ![]() Quickest/Fastest Mazdaspeed First Gen 1 in the 9's 9.94@149.5 4/22/2017 New England Dragway |
| The Following User Says Thank You to Justin@Freektune For This Useful Post: | Voltwings (01-21-2016) |
As it is, my P1 goes to my Hotpipe, T, and bottom port on the EWG. P2 goes to top port, but the side top port because when I post the pictures you'll see the top port is blocked. P3 goes to my intake. I'll post logs a little later this evening. Spring pressure is set to 15psi.
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings | |
Would there be any danger if that's not correct?
I would recommend to set it up according to the picture that you posted or the routing that I have.
![]() Join Date: Nov 2010 Location: Riverhead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,457
Interesting you blew your dipstick with one high boost pull. Are you running any sort of crankcase mods, like vented cap, vented can, perm plate, etc? | |
| The Following User Says Thank You to Boost_creep For This Useful Post: | Mazdazilla6 (01-22-2016) |
By the way, did some logs, and my car is really down on power by about 30whp. I'm barely breaking 300whp. Car is running really rich too. I'm gonna e-mail Freak cause something isn't right (amongst other things). My AFR's at WOT are in going as low as 10.14.
(Thread Starter) | Not Ranked : 0 score uploadfromtaptalk1453418273456.jpguploadfromtaptalk1453418282178.jpguploadfromtaptalk1453418288327.jpg
![]() | | #24 | ![]() |
| Not Ranked : 0 score It's a Mazdaspeed, what could possibly go wrong.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Mazdazilla6 (01-21-2016) |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Okay, so that was bad. Swapped P1 and P2. Warmed the car up, slowly went into boost on the on ramp. Let off, then built boost again, decided to floor it. Car hit 30.22psi of boost and 140%IDC. Babied it home and swapped lines back to original positions. I took several logs trying to replicate the condition (which I believe I did) but I have to sort through all the logs to find them.
| The Following User Says Thank You to Cheapspeed For This Useful Post: | Code Monkey (01-21-2016) |
![]() | | #26 | ![]() |
If you set it up according to the photo you posted earlier then I'm guessing your tune is commanding some high duty cycle and with the setup in the picture you need to command a lower duty cycle.
![]() | | #27 | ![]() |
Here are the logs. I posted the overboost after I straight swapped P1 and P2. Then there is the roll into boost that falls short of full boost (I gradually depress the pedal staying in high load), and then there's full boost where I floor it, usually hitting 18-19+psi in this cold weather. Hot weather will bring me up to 20-21psi.
| The Following User Says Thank You to Cheapspeed For This Useful Post: | Mazdazilla6 (01-21-2016) |
![]() | | #28 | ![]() |
Possibly something faulty with the boost controller? Edit: To be clear, I feel guilty for the overboost situation. Swapping lines around like that is definitely something you should consult with your tuner about. Routing lines wrong or in a fashion that doesn't work with the tune can blow an engine.
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | Cheapspeed (01-21-2016) |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score So apparently 30+psi will blow out my dipstick. Didn't notice it last night in the dark. Oil everywhere. Glad the pressure didn't blow my block. Gonna take some logs at my normal logging spot to see if there's any noticeable change in performance.
| The Following User Says Thank You to Cheapspeed For This Useful Post: | Code Monkey (01-22-2016) |
![]() | | #30 | ![]() |
![]() Join Date: Jun 2011 Location: Tacoma Wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,346
Same thing happened to me at 30psi. Switched to a vented oil fill cap and VTA OCC and never happened again. On the ewg I have mine routed like this and it's perfect. ImageUploadedByTapatalk1453508231.175750.jpg
__________________ Blacked Out 2010 Black Mica MazdaSpeed 3 Performance: Speed Performance 10.6:1 Built motor, CP-e Exhaust Mani, GTX3071, Tial MVR EWG, JBR 3.5" SRI, Cobb AP V3, Autotech HPFP, Guardian Angel, eBay Downpipe, CP-E Triton CBE, Treadstone TR8L Intercooler, CX Racing FMIC Piping Kit, JBR Crashbar, NGK Plugs, PNP Intake Manifold, CoolingMist WMI system w/failsafe, DM Throttle Body Spacer with Dual D07 Nozzles, | |
| The Following 3 Users Say Thank You to England15j For This Useful Post: |
![]() | | #31 | ![]() |
Groans: 189
| Not Ranked : 0 score Lol.
![]() | | #32 | ![]() |
Groans: 189
| Not Ranked : 0 score Crancase evac will cause you to lose that much power, or more.
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score I bought a touch-up from Justin and will just baby the car in the meantime. Not hard staying out of boost on the 3076. I need to get a beater so I can let the car sit for a while. I've beat the shit out of this thing and it still reliably gets me to work. It's pretty amazing.
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score Blew the dipstick out again doing the logs I sent to Freek. Hose at the TB was pushed back. Fixed that, and checked my plugs (they looked pretty good). Did 2 logs again, still running 10 AFR's at WOT but no dipstick blowout. I looked at my old logs on this revision if anything I was running leaner then. He gave me a blind fix to my IDC issue where I was hit 107% IDC if not higher and the car stuttered (as in he didn't view any logs for it). Here' one of those old logs, and here the ones I just took, same map.
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here's logs from this afternoon that I sent to Justin. Still rich AFRs, but power isn't abnormal for 65*ambients and up to 117*bats after 3 back to back pulls.
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score Quick update. Rerouted all my lines as @Mazdazilla6; and Justin said to. Also remade another gasket for the bpv, double checked all fitting and boost tubes. Haven't done a boost leak check yet because I'll have to borrow compressor and gauge from somebody. So I've still managed to replicate the issue where part throttle boost won't translate to full boost at WOT, still annoying but tolerable. However I did take another set of logs and they're looking decent again, WOT AFR's look good. Car doesn't act noticeably different from my previous hose routing but I'm glad it's fixed anyway. Car was struggling to hit 100% IDC and it's a little down on power. It's been a while since I've driven in weather this warm, but I don't recall having difficulty maxing out the injectors before. Maybe the tune needs to be adjusted now? I have a pre-ebcs log and post-ebcs fix log to compare, similar boost temps.
| The Following User Says Thank You to Cheapspeed For This Useful Post: | Mazdazilla6 (01-29-2016) |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score Looks like the car is doing much better now. Freek adjusted some boostload tables post EBCS vac line fix. The dark green and red are the new logs. I posted one the green log if anybody wants to look and give me some feedback.
| boost tuning, not hitting easy boost targets? | Caldazar | MazdaSpeed 3/6 - ECU Computer Tuning | 11 | 05-18-2012 06:09 PM |
| Not hitting Stage 2 boost targets (boost leak?) | Bubba Ho-Tep | 2010 MS3 - ECU Computer Tuning | 15 | 04-26-2012 08:25 PM |
| not hitting boost targets | exentix | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 7 | 04-13-2012 05:57 PM |
| Not hitting boost targets | jvella22 | Mazdaspeed3/6 General Discussion | 2 | 04-08-2012 08:26 PM |
| Not hitting boost targets again (AP).. | dsmluck | MazdaSpeed 3/6 - ECU Computer Tuning | 28 | 08-01-2011 05:35 PM |
